Home » Archived » BIRT » Dynamic Text(Use Logic Statements in Dynamic Text)
Dynamic Text [message #715293] Sat, 13 August 2011 02:22 Go to next message
Dear All,
I am currently looking how to use the Dynamic text control in BIRT.
I am having an issue:
I have 3 fields in my dataset: Address1, Address2, Address3
I want to display the 3 fields concatenated in a dynamic text that i set to HTML and Dynamic. The 3 addresses are then separated by a comma (","). Yet, if an address is blank (""), i dont want to show it.
So, in the edit window, i added the following code with a javascript if statement:
if(<VALUE-OF>row["Add1"]</VALUE-OF> == "")
else
<VALUE-OF>row["Add1"]</VALUE-OF> + ",";
Unfortunately, it does not seem to work. Could anyone please please advise me here how to use it properly?
Thanking you in advance
Karvesh
Re: Dynamic Text [message #715296 is a reply to message #715293] Sat, 13 August 2011 03:04 Go to previous messageGo to next message
Dear All,
Myself again. After some searching and struggling, the nearest I could get to is:
<VALUE-OF>if(row["Add1"] == "") {"";}else{row["Add1"]+", \n";}</VALUE-OF> <VALUE-OF>if(row["Add2"] == "") {"";}else{row["Add2"]+", \n";}</VALUE-OF> <VALUE-OF>if(row["Add3"] == "") {"";}else{row["Add3"];}</VALUE-OF>
It seems to handle it ok. The only issue now is that i cannot get the addresses to appear on a separate line. The javascript special character for new line "\n" does not seem to force the following addresses on a new line...
Any idea here please?
Thanks in advance
Karvesh
Re: Dynamic Text [message #715785 is a reply to message #715296] Mon, 15 August 2011 10:39 Go to previous messageGo to next message
Try adding +"<br>" and use the format=HTML attribute:
<VALUE-OF format="HTML">if( true){
"<br>";
}</VALUE-OF>
Jason
On 8/13/2011 3:04 AM, karvesh wrote:
> Dear All,
> get to is:
> new line...
> Thanks in advance
> Karvesh
Re: Dynamic Text [message #715794 is a reply to message #715785] Mon, 15 August 2011 11:08 Go to previous message
Dear Jason
thanks for the tip. its working!
Karvesh
Previous Topic:MySql Nested Select
Next Topic:Question on log4j configuration for ReportEngine logs when using Viewer
Current Time: Thu Oct 30 00:22:40 EDT 2025
Powered by FUDForum. Page generated in 0.04590 seconds
