(no subject) [message #715327 is a reply to message #715230] |
Sat, 13 August 2011 10:52 |
Ed Willink Messages: 7655 Registered: July 2009 |
Hi Ted
In http://journal.ub.tu-berlin.de/eceasst/article/view/444 I describe
the re-engineering the Eclipse OCL grammar from LPG (LALR) to Xtext LL.
In a naive LL, the change in recursion would be a problem. In practice
Xtext's EBNF capabilities (*, ?, +) are left recursive, and so far from
being deficient Xtext is actually much better.
The generated ANTLR grammars are huge and so one activity I would like
to progress is an Xtext to LPG transformation so that, for compile-only
purposes, a somewhat faster and much smaller grammar can be used while
retaining the power of Xtext as a model-integrated grammar with
auto-generated editor tooling.
If you're interested in Xtext to LALR mapping let me know.
Ed Willink
On 12/08/2011 22:01, ted stockwell wrote:
> Hi All,
> I have developed a Java parser combinator library that supports left
> recursive grammars.
> I am in the process of releasing it here:
> http://code.google.com/p/lingwah/
> I would like to integrate my parser into XText and thus eliminate the
> need to left factor XText grammars. I have not used XText a lot, I
> once downloaded it and created a simple example.
> So... I have a couple of questions...
> .. is ANTLR the only barrier to supporting left recursion in XText?
> .. is it possible to replace ANTLR? If so how would I go about doing
> this?
> Thanks...
> ted stockwell
FUDForum. Page generated in 0.03019 seconds
