Re: [mwe2] Resolving platform:/plugin [message #714942 is a reply to message #714941] |
Thu, 11 August 2011 20:21 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Ed,
your are right.
Could you please file a ticket and describe your usecase, especially why
you had to use platform:/plugin instead of platform:/resource uris.
Sebastian
On 11.08.11 21:57, Ed Willink wrote:
> Hi Sebastian
> Thanks. Yes, scanClassPath solves the need to mess around with an
> eclipse_home, but it is still necessary to have
> uriMap = Mapping {
> from = "platform:/plugin/org.eclipse.xtext.common.types/"
> to = "platform:/resource/org.eclipse.xtext.common.types/"
> which seems a little redundant if scanClasspath has found all the plugin
> resources.
> Regards
> Ed Willink
> On 11/08/2011 16:27, Sebastian Zarnekow wrote:
>> Hi Ed,
>> please try to set StandaloneSetup#scanClassPath to true.
>> That should take care of most of the other configuration that you did.
>> Regards,
>> Sebastian
FUDForum. Page generated in 0.03282 seconds
