Xtext 2.0 plugin product installed [message #714639] |
Thu, 11 August 2011 07:13 |
Caner Messages: 98 Registered: July 2011 |
Member |
Hi All
I have a Xtext plugin which has been implemented with Xtext 2.0 as well.
When I have installed the plugin on an Indigo, I have validations,coloring, and code completion features which are working fine, However Hovering stuff is not working (hovering is working fine when I run my code),
What might be reason? Do you have any idea?
BR
Caner
PS:
After I installed my plugin on INDIGO, I am crating an somthng.mydsl file and than start codding, when i checked the hovering whether is it working ornot
I am getting this error as below;
java.lang.Error: Unresolved compilation problem:
The method getDocumentation(EObject) of type myDSLEObjectDocumentationProvider must override a superclass method
But I have already overriden this method :I
Is it wrong with something IEObjectDoc
[Updated on: Fri, 12 August 2011 08:25] Report message to a moderator
Re: Xtext 2.0 plugin product installed [message #714794 is a reply to message #714639] |
Thu, 11 August 2011 14:05 |
Member |
at at com.example.mydsl.ui.DSlEObjectDocumentationProvider.getDocumentation(mydslEObjectDocumentationProvider.java:24)org.eclipse.xtext.ui.editor.hover.html.DefaultEObjectHoverProvider.getDocumentation(DefaultEObjectHoverProvider.java:107)
at org.eclipse.xtext.ui.editor.hover.html.DefaultEObjectHoverProvider.getHoverInfoAsHtml(DefaultEObjectHoverProvider.java:80)
at org.eclipse.xtext.ui.editor.hover.html.DefaultEObjectHoverProvider.getHoverInfo(DefaultEObjectHoverProvider.java:91)
at org.eclipse.xtext.ui.editor.hover.html.DefaultEObjectHoverProvider$2.getInfo(DefaultEObjectHoverProvider.java:499)
at org.eclipse.xtext.ui.editor.hover.DispatchingEObjectTextHover.getHoverInfo(DispatchingEObjectTextHover.java:38)
at org.eclipse.xtext.ui.editor.hover.AbstractEObjectHover$2.exec(AbstractEObjectHover.java:69)
at org.eclipse.xtext.ui.editor.hover.AbstractEObjectHover$2.exec(AbstractEObjectHover.java:1)
at org.eclipse.xtext.util.concurrent.AbstractReadWriteAcces.readOnly(AbstractReadWriteAcces.java:32)
at org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(XtextDocument.java:86)
at org.eclipse.xtext.ui.editor.hover.AbstractEObjectHover.getHoverInfo2(AbstractEObjectHover.java:65)
at org.eclipse.xtext.ui.editor.hover.AbstractCompositeHover.getHoverRegion(AbstractCompositeHover.java:67)
at org.eclipse.jface.text.TextViewerHoverManager.computeInformation(TextViewerHoverManager.java:140)
at org.eclipse.jface.text.AbstractInformationControlManager.doShowInformation(AbstractInformationControlManager.java:1131)
at org.eclipse.jface.text.AbstractHoverInformationControlManager$MouseTracker.mouseHover(AbstractHoverInformationControlManager.java:519)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:207)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
[Updated on: Fri, 12 August 2011 07:51] Report message to a moderator
FUDForum. Page generated in 0.03271 seconds
