Re: running php script on remote system [message #78407 is a reply to message #75541] |
Sat, 16 August 2008 05:13 |
Originally posted by: zhonghaicheng.163.com
John Enevoldson wrote:
> We are trying to run php scripts on a remote system using pdt 1.0.3 (build
> R20080603) but find that we have to manually export the script from the
> project to the remote server first. We are not sure if this is a bug or if
> we are doing something wrong:
> Steps taken are:
> 1.Add new php project
> 2.Create new php file.
> 3.From the php script edit window right click and select "run as", "open
> run dialog..."
> 4.Select php web page and the configuration for our remote server.
> 5.Under "File" we select our php script in the project created.
> 6.Select run.
> We now get error 404, object not found - not so surprising since we see
> that the php file is not on the server. However, if we manually export the
> file first to a destination that matches that entered in step 5 above and
> rerun then it works fine.
> We would have expected the php file to be automatically moved to the
> server.
> Is this working as designed or have we missed something ?
> Thanks for any help.
> Best regards,
> John.
I'v met the same problem, but i found that it's ok in this version
pdt-1.0.0.R20070917-debugger-5.2.10.v20070905-all-in-one-win 32, there's a
option in setting php web servers, in this version,the pdt could export
project to server itself. I don't know why pdt can't publish project to
server in version after pdt-1.0.3,is this function canceled in the new
version? have you solved this problem yet?
FUDForum. Page generated in 0.03193 seconds
