Home » Eclipse Projects » Eclipse Platform » Identify when Eclipse is closed(Which class is involved?)
Identify when Eclipse is closed [message #713933] Tue, 09 August 2011 08:30 Go to next message
Hi all,
I am working on Eclipse XML editor source code and in particular on plug-in org.eclipse.wst.xml.ui.
I would like to know which class/classes are involved when Eclipse in closing, that means when user selects File->Exit (or similar on other not Windows OS).
Marco
Re: Identify when Eclipse is closed [message #713947 is a reply to message #713933] Tue, 09 August 2011 09:16 Go to previous messageGo to next message
Originally posted by:
On 2011-08-09 14:30, MarcoGT wrote:
> Hi all,
> not Windows OS).
It depends what you want to achieve. E.g. you can override
preWindowShellClose of your WorkbenchWindowAdvisor, but there are other
similar life-cycle functions of your RCP application. If you are not
defining your own RCP appliaction, you could also add a listener of type
IWorkbenchListener via IWorkbench#addWorkbenchListener and handle the
preShutdown event.
HTH & Greetings from Bremen,
Daniel Krügler
Re: Identify when Eclipse is closed [message #713955 is a reply to message #713947] Tue, 09 August 2011 09:40 Go to previous messageGo to next message
Uhm...I have a problem.
I created a class which implements IWorkbenchListener
public class CleanResources implements IWorkbenchListener {
	public void postShutdown(IWorkbench arg0) {
		// TODO Auto-generated method stub
	public boolean preShutdown(IWorkbench arg0, boolean arg1) {
		//TODO: my code here
		return false;
But, of course, this class should be called by someone somewhere, shouldn't it? How?
Thanks and greets from Munich Smile
[Updated on: Tue, 09 August 2011 09:53] by Moderator
Re: Identify when Eclipse is closed [message #713966 is a reply to message #713955] Tue, 09 August 2011 09:51 Go to previous messageGo to next message
> @Override
> @Override
> System.out.println("ciao");
> return false;
> shouldn't it? How?
I answered this question in my previous reply (you need to register your
listener).
- Daniel Krügler
Re: Identify when Eclipse is closed [message #713976 is a reply to message #713966] Tue, 09 August 2011 10:02 Go to previous messageGo to next message
Uhm...thanks...but I do not understand in which classes of mine I have to register this listener
What I have to do I basically delete a file on the hard disk when Eclipse closes
[Updated on: Tue, 09 August 2011 11:07] by Moderator
Re: Identify when Eclipse is closed [message #714234 is a reply to message #713976] Wed, 10 August 2011 02:18 Go to previous message
On 2011-08-09 16:02, MarcoGT wrote:
> And how can I register the listener?
Well, the documentation of IWorkbenchListener refers to
IWorkbench#addWorkbenchListener,so you need an instance of IWorkbench to
register, right? If you check the interface documentation of IWorkbench,
you are delegated to org.eclipse.ui.PlatformUI#getWorkbench, so here you
could go. I strongly recommend to study the (very short) interface
documentation of the related types, which usually give you the right answer.
- Daniel Krügler
Previous Topic:limit search results OR hide search view toolbar icons dynamically
Next Topic:limit search results OR hide search view toolbar icons dynamically
Current Time: Fri Oct 31 18:26:24 EDT 2025
Powered by FUDForum. Page generated in 0.04662 seconds
