Home » Language IDEs » PHP Development Tools (PDT) » Unable to define servers
| Re: Unable to define servers [message #75178 is a reply to message #75160] |
Tue, 08 July 2008 04:20   |
Tried to, but still not working.
On error seems to be key binding conflict with WindowBuilder (which
should not be a big issue).
Further down I see classes missing- this is with the current 2.0 nightly
build. I'm a little clueless though which one is the root cause here?
!SESSION 2008-07-08 10:14:10.765
eclipse.buildId=I20080617-2000
java.version=1.6.0_10-beta
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.jface 2 0 2008-07-08 10:14:57.687
!MESSAGE Keybinding conflicts occurred. They may interfere with normal
accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2008-07-08 10:14:57.687
!MESSAGE A conflict occurred for ALT+SHIFT+D H:
Binding(ALT+SHIFT+D H,
ParameterizedCommand(Command(com.swtdesigner.gwt.launch.juni tGWTLaunchShortcut.debug,Debug GWT JUnit Test,
Category(org.eclipse.debug.ui.category.run,Run/Debug,Run/Deb ug command
category,true),
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
ParameterizedCommand(Command(org.eclipse.php.deubg.ui.phpexe Shortcut.debug,Debug PHP Script,
Debug PHP Script,
category,true),
,,true),null),
!MESSAGE A conflict occurred for ALT+SHIFT+X H:
Binding(ALT+SHIFT+X H,
ParameterizedCommand(Command(com.swtdesigner.gwt.launch.juni tGWTLaunchShortcut.run,Run GWT JUnit Test,
Run GWT JUnit Test,
category,true),
,,true),null),
ParameterizedCommand(Command(org.eclipse.php.deubg.ui.phpexe Shortcut.run,Run PHP Script,
Run PHP Script,
category,true),
,,true),null),
!ENTRY org.eclipse.osgi 4 0 2008-07-08 10:15:29.140
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.php.core (393).
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.php.internal.core.PHPCorePlugin.start() of bundle
org.eclipse.php.core.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1028)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:368)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:33)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:441)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
org.eclipse.php.internal.server.ui.PHPServersConfigurationBl ock.populateServerList(Unknown
Source)
org.eclipse.php.internal.server.ui.PHPServersConfigurationBl ock.initialize(Unknown
Source)
org.eclipse.php.internal.ui.preferences.AbstractConfiguratio nBlockPreferencePage.initialize(Unknown
Source)
org.eclipse.php.internal.ui.preferences.AbstractConfiguratio nBlockPreferencePage.createContents(Unknown
Source)
org.eclipse.jface.preference.PreferencePage.createControl(Pr eferencePage.java:235)
org.eclipse.php.internal.ui.preferences.AbstractConfiguratio nBlockPreferencePage.createControl(Unknown
Source)
org.eclipse.jface.preference.PreferenceDialog.createPageCont rol(PreferenceDialog.java:1466)
org.eclipse.jface.preference.PreferenceDialog$14.run(Prefere nceDialog.java:1223)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
org.eclipse.jface.preference.PreferenceDialog.showPage(Prefe renceDialog.java:1217)
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.sho wPage(FilteredPreferenceDialog.java:570)
org.eclipse.jface.preference.PreferenceDialog$10.run(Prefere nceDialog.java:700)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
org.eclipse.jface.preference.PreferenceDialog$9.selectionCha nged(PreferenceDialog.java:696)
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:842)
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:840)
org.eclipse.jface.viewers.StructuredViewer.handlePostSelect( StructuredViewer.java:1153)
org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected( StructuredViewer.java:1178)
org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(O penStrategy.java:250)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:244)
at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java: 418)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPrefer encesAction.java:65)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
Caused by: org.eclipse.core.internal.resources.ResourceException:
Resource '/ASOLoader' is not open.
org.eclipse.core.internal.resources.Project.checkAccessible( Project.java:116)
org.eclipse.core.internal.resources.Project.getDescription(P roject.java:357)
at org.eclipse.php.internal.core.PHPCorePlugin.convertProjects( Unknown
Source)
at org.eclipse.php.internal.core.PHPCorePlugin.start(Unknown Source)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1003)
... 78 more
Root exception:
org.eclipse.core.internal.resources.ResourceException: Resource
Source)
Source)
Source)
Source)
Source)
Source)
!ENTRY org.eclipse.jface 4 2 2008-07-08 10:15:29.187
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
java.lang.NoClassDefFoundError:
org/eclipse/php/internal/core/util/preferences/IXMLPreferenc esStorable
Source)
Source)
Source)
Source)
Source)
Caused by:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
... 63 more
Caused by: org.osgi.framework.BundleException: Exception in
... 73 more
Source)
... 78 more
Toshihiro wrote:
> You can investigate workspace/.metadata/.log file.
> See also
> http://dev.eclipse.org/newslists/news.eclipse.tools.pdt/msg0 1331.html
> [news.eclipse.tools.pdt] Re: Where is PDT's preferences file? - Regards
> Bug #204525
> Otherwise, try creating new workspace.
| Re: Unable to define servers [message #75243 is a reply to message #75178] |
Tue, 08 July 2008 10:24  |
Fixed by removing all pdt preference files and installing today's
integration build- thanks!
Current Time: Fri Nov 07 05:33:01 EST 2025
Powered by FUDForum. Page generated in 0.04026 seconds
