| Operation lockout after starting multiple operations [message #75076] |
Mon, 07 July 2008 12:22 |
I'm not sure whether or not this is a PDT issue or something deeper in
Ecplise, but since I started using Eclipse I've been very aware of the
absolute danger of having more than one operation running at a time. With
operation I mean almost anything given that can be "run in background".
You are often tempted by this, I mean it should in theory mean you could
continue to work. But very often what I end up with is a operation that is
going nowhere (Eclipse is using 0% of the CPU) while I have other
operations, such as file saving, behind waiting for it to finish. At times
I have had Eclipse standing in this state for an entire weekend without it
getting anywhere. Stopping the operations helps little as it seems Eclipse
are unable to really kill it (this might be a Windows issue).
I'm using the 1.0.3 Release Build on Windows XP SP 2 but have been having
this problem for as long as I can remember with Eclipse and PHP.
Rinman
FUDForum. Page generated in 0.03172 seconds
