Home » Archived » XML Schema Definition (XSD) » XSD to Ecore order attributes
Re: XSD to Ecore order attributes [message #75129 is a reply to message #75112] |
Mon, 04 August 2008 15:55 |
Ed Merks Messages: 33141 Registered: July 2009 |
--------------030700050507040206040608
David,
Your first two sentences seem to contradict each other. The attributes
have always been alphabetically sorted and will always be alphabetically
sorted until we add an option to support the alternative that was added
for Tuscany which is not enabled by default. That's because the code as
below. The attribute uses of a complex type in the XSD model are
sorted. Only by reordering them to respect the order in the attribute
contents will they appear in the XSD source's order.
protected boolean useSortedAttributes()
return true;
protected List<XSDAttributeUse>
getAttributeUses(XSDComplexTypeDefinition xsdComplexTypeDefinition)
if (useSortedAttributes())
return xsdComplexTypeDefinition.getAttributeUses();
else
List<XSDAttributeUse> result = new
ArrayList<XSDAttributeUse>(xsdComplexTypeDefinition.getAttributeUses());
reorderAttributeUses(result,
xsdComplexTypeDefinition.getAttributeContents());
return result;
So basically you can get what you want.
David wrote:
> For me since XSD 2.2.1, when we generate Ecore and Genmodel, the
> attributes are not alphabetical sorted, but they are sorted according
> to the XSD file. Nevertheless I can't generate with XSD order, I
> always keep alpabetical order. But I would like to get the XSD order.
> Regards,
> David.
<html>
<head>
http-equiv="Content-Type">
</head>
David,<br>
<br>
Ed Merks
Re: XSD to Ecore order attributes [message #75216 is a reply to message #75180] |
Tue, 05 August 2008 13:06 |
David,
The other bugzilla only has the configurable support without making that
the default. If you modified the source and set what that method
returns to false, you'd get what you want.
David wrote:
> Ed,
> Sorry if I have contradiction in what I say, and thanks for your help.
> I understand what you say to get the order of XSD file to my
> attributes. But I would like to know if it exists a version of the XSD
> plugin which propose this order, or I have to get the plugin and do
> the modification in the source. Because currently I use XSD 2.4 and I
> get alphabetical order, and I have seen the bug 151123 in the xsd
> releases :
> http://www.eclipse.org/modeling/mdt/news/relnotes.php?projec t=xsd&version=2.2.x&types=R
> Regards,
> David.
Ed Merks
Re: XSD to Ecore order attributes [message #603165 is a reply to message #74938] |
Mon, 04 August 2008 12:03 |
--------------060906070802050301040404
David,
EMF's implementation will always sort attributes because XSDEcoreBuilder has
return true;
And https://bugs.eclipse.org/bugs/show_bug.cgi?id=236609 is open to
request EMF not sort the attributes. So I'm not sure how it's possible
for you to have unsorted attributes. Are you using Tuscany?
David wrote:
> Hello,
> I use XSD Converter 2.4, EMF SDO 2.4 and the XSD 2.4 plugin. My
> problem is when I create my Ecore and Genmodel with my XSD file, the
> attributes are not sorted. I have seen that this porblem is corrected
> since XSD 2.2.1, but I always have not sorted attributes.
> How can I correct this?
> Thx,
> David.
<html>
<head>
</head>
David,<br>
<br>
XSDEcoreBuilder has<br>
<blockquote><small>
Ed Merks
Re: XSD to Ecore order attributes [message #603174 is a reply to message #75078] |
Mon, 04 August 2008 15:29 |
--------------040509090009080204030007
David,
In this note you talk about "not sorted as in the XSD file" which to me
is the exact opposite of "my attributes are not sorted" from your
original note. The fact is that the attributes are always sorted
alphabetically. Until 236609
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=236609> is supported,
likely in EMF/XSD 2.5.0, it will continue to be that way.
David wrote:
> thanks for your answer.
> I have seen the bug151123
> (https://bugs.eclipse.org/bugs/show_bug.cgi?id=151123) which speak
> about this subject, but when I create my Ecore and my Genmodel, the
> attributes are not sorted as in the XSD file. And I don't use Tuscany.
> I use Eclipse 3.4 (Eclipse for RCP/Plug-in Developers package) and
> java 1.5
> I don't understand what can be the problem.
> Regards,
> David.
<html>
<head>
</head>
David,<br>
<br>
original note.
Ed Merks
Re: XSD to Ecore order attributes [message #603183 is a reply to message #75112] |
David,
return true;
else
return result;
David wrote:
> Regards,
> David.
<html>
<head>
</head>
David,<br>
<br>
Ed Merks
Re: XSD to Ecore order attributes [message #603206 is a reply to message #75180] |
David,
David wrote:
> Ed,
> releases :
> Regards,
> David.
Ed Merks
Current Time: Fri Apr 26 05:24:05 GMT 2024
Powered by FUDForum. Page generated in 0.04806 seconds
