Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » EMaps and the missing @MapKey annotation
Re: EMaps and the missing @MapKey annotation [message #74439 is a reply to message #74367] |
Thu, 08 March 2007 19:00 |
Jean-Denis Boudreault Messages: 55 Registered: July 2009 |
Member |
thanks for your answer.
im not sure if it get it all, perhaps i dont understand very well how
teneo maps from the hibernate engine to the EMF datatypes.
But if i get it right, Teneo creates a oneToMany/ManyToOne relationship to
the owner object,is that it? then, how dies it define the key? is it
possible to perform this kind of mapping in teneo and define the column
used for the key? (or perhaps the key column is defined automatically?)
<scenario>
TableA
[ID: 1, Name: "entry1"]
TableB (joins table A on ID:ParentID)
[ID: 1, ParentID: 1, name="entry1"]
[ID: 2, ParentID: 1, name="entry2"]
[ID: 3 ParentID: 1, name="entry3"]
then, in code:
class TableAEntity
public Map<Integer, TableBEntity> childs;
</scenario>
where the key of the map is mapped to the ID column of TableB and the
value of the map is the TableB entity for this ID.
thanks for your time!
Re: EMaps and the missing @MapKey annotation [message #74475 is a reply to message #74439] |
Thu, 08 March 2007 20:45 |
Hi JD,
Teneo maps from emf to hibernate (so the other way around). This means that it maps the emap to
hibernate in correspondence to the emf approach. For an emap entry emf (so not teneo but emf itself)
will generate a separate class (for example stringtostringemapentry or something). The emf emap is
not a real map but a list of these map entries (so not a hashmap with map entries). Because it is a
list it can not be mapped easily to a real map-like model in the db.
Teneo takes the separately generated map entry class and creates a mapping for that class as if it
is in the list of the owner. The entry class is modeled as a separate entity with its own primary
key (for example a generated id). This key has nothing to do with the map key (it does not really
need it).
Teneo just follows the emf approach here.
gr. Martin
> to the owner object,is that it? then, how dies it define the key? is it
> <scenario>
> TableA
> then, in code:
> class TableAEntity
> </scenario>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: EMaps and the missing @MapKey annotation [message #74510 is a reply to message #74475] |
Thu, 08 March 2007 23:10 |
Member |
Hi Martin, thanks for your very detailed answers!
I guess where i am confused is how a list can behaves like a map, since how
does it provide the key/value functionality. i explain:
I just found on the EMF FAQ
( http://wiki.eclipse.org/index.php/EMF-FAQ#How_do_i_create_a_ Map_in_EMF.3F)
where they explain about EMaps. it surely concurs with your sayings. I have
two questions from there (i hope these questions dont annoy you, but if i
better understand, perhaps i can help too :))
1. In my ecore diagram, i create an EAttribute of EType EMap <K, V>
[java.util.Map]. When i generate the code, i get a good old java.util.Map. I
guess this is where i get confused. with a java.util.Map, can't we get
hibernate to function like it always did? and from there, wouldn't it be a
good idea to implement the @MapKey annotation?
2. Im pretty sure im not understanding well and you will explain to my why
the java.util.Map thing is wrong. then, if the EMap is a list of custom
mapEntries class, what happens behind the scenes when i do: myMap.ge(2)
specifying a key value? is there a hidden foreach in the implementation
that iterates the list of entries and returns the found result? and if so,
what prevents us from mapping a column in a oneToMany relationship as the
key to the mapEntries? there, the @MapKey annotation would be useful, to
define which column in the entity is to be used for key, instead of forcing
the ID column. am i being clear?
basically, if i get this right, we define a EClass for the EMap entries,
right? so, suppose we take my database example from before:
<scenario>
TableA
[ID: 1, ParentID: 1, name="entry1", someUniqueField=233]
[ID: 2, ParentID: 1, name="entry2", someUniqueField=34456]
[ID: 3 ParentID: 1, name="entry3", someUniqueField=2342]
</scenario>
Then, if we want a map of type tableB with the key being someUniqueField
column, we could have:
SomeUniqueFieldToTableBEntry<Integer, TableBClass>
with this, it would make sense to have @MapKey defined to select the column
to be used to set the key.
am i making any sense?
anyways, i hope im getting this right, since perhaps i really dont know what
goes under the hood.
thanks for your help, this is much appreciated! :)
"Martin Taal" <mtaal@elver.org> wrote in message
news:espslr$uoj$1@utils.eclipse.org...
> Hi JD,
> that it maps the emap to hibernate in correspondence to the emf approach.
> For an emap entry emf (so not teneo but emf itself) will generate a
> emap is not a real map but a list of these map entries (so not a hashmap
> with map entries). Because it is a list it can not be mapped easily to a
> for that class as if it is in the list of the owner. The entry class is
> modeled as a separate entity with its own primary key (for example a
> really need it).
> gr. Martin
>> <scenario>
>> TableA
>> then, in code:
>> class TableAEntity
>> </scenario>
> The Netherlands
Re: EMaps and the missing @MapKey annotation [message #74528 is a reply to message #74510] |
Thu, 08 March 2007 23:26 |
Member |
i was just thinking about this and i think i get your point.
so basically if i get what your saying, the mapentry class is defined in a
table of its own (entity), and the key is probably the unique ID of this
class, is that it? the value itself is either a column type or a onetoone
reference to another entity table.
so, following this logic, there would be no way to make direct relationships
to other entity table, without going through this 'intermediary' entity
being the mapentry.
If this is so, could it be possible to eliminate the need to explicitely
define a mapEntry entity and let teneo generate one in the background? foe
example:
KeyToValueEntry<K, V>.
then, there would be no need to have an intermediary table, and we could
directly specify the key column and the entity type. so we could create:
<pseudocode>
ClassA
public EMap<Integer, ClassB> field;
</pseudocode>
and with anotations define the column of the entity that is used as the Key
with @MapKey. in the background, teneo could generate this
KeyToValueEntry<K, V> list and dynamically rebuild an EMap. In the xml.hbm
file, there would be not intermediary entity, just a map from EnityA to
EntityB with a key column defined.
how does that sound? (i could be right off, sorry if i am, jsut trying to
help)
"Jean-Denis Boudreault" <jdboudreault@gmail.com> wrote in message
news:esq552$ekj$1@utils.eclipse.org...
> how does it provide the key/value functionality. i explain:
> have two questions from there (i hope these questions dont annoy you, but
> if i better understand, perhaps i can help too :))
> I guess this is where i get confused. with a java.util.Map, can't we get
> a good idea to implement the @MapKey annotation?
> so, what prevents us from mapping a column in a oneToMany relationship as
> the key to the mapEntries? there, the @MapKey annotation would be useful,
> to define which column in the entity is to be used for key, instead of
> forcing the ID column. am i being clear?
> <scenario>
> TableA
> </scenario>
> column to be used to set the key.
> what goes under the hood.
>> Hi JD,
>> emf emap is not a real map but a list of these map entries (so not a
>> hashmap with map entries). Because it is a list it can not be mapped
>> mapping for that class as if it is in the list of the owner. The entry
>> class is modeled as a separate entity with its own primary key (for
>> does not really need it).
>> gr. Martin
>>> <scenario>
>>> TableA
>>> then, in code:
>>> class TableAEntity
>>> </scenario>
>> The Netherlands
Re: EMaps and the missing @MapKey annotation [message #74582 is a reply to message #74528] |
Fri, 09 March 2007 11:18 |
Member |
Hello again,
i deeply apologize for the verbose, but i think this can actually be very
useful. This post may be long and detailed, but i want to make sure it is
clear.
So, i went a head and took a look at the BasicEList and BasicEMap
implementation files of EMF 2.3. So, now i understand what you were saying
about EMaps. it is in reality just a list, of the type map.entry. Where we
get an object by key in the EMap, it basically loops the list until it
finds the entry for that key. (I guess we should create an EMF feature
request for a EHashmap then since this is not very efficient for large
lists).
but, back to teneo. lets take this POJO scenario:
<code>
public class parent
int ID;
// the key is the GUID
public EMap<String, child>
public class child
int ID;
string GUID;
String name;
</code>
basically, a parent class holds a collection of child class, and to
accelerate lookup, keeps a map where the key is the unique string GUID of
the parent class. the datbase tables might look like this:
<dbschema>
| PARENT |
| Int | ID |
| CHILD |
| Int | ID |
| Int |parentID|
| varchar | GUID |
| varchar | name |
where there is a join in ID/ParentID
</dbschema>
Now, if we created a EList collection instead of a EMap, it would be a
simple thing, we would simply add a manyToOne/OneToMany hibernate
relationship on the collection to get it going.
but with emaps, its slightly different. to go with EMF, what teneo
currently does (if i correctly understand Martin's explanation) is to add
a third table, which is a 'middleman' joining table that represents the
map.Entry. this table has a field for the key and the value. this im not
sure, but i assume the value could also be a oneToOne join to the child
table. For this reason, the @MapKey is not supported, since there is no
other field to select the key from; just the defined field 'KEY' in that
table.
here is my suggestion: (i hope it makes sense).
when we think of it, a map really is just a list, with a key that
simplifies each entries lookup (hence the EMap design decision). for this
reason, pure hibernate allows for parent/*childs collections to be mapped
either as lists, or as maps where we can define which column can be used
as the key (hence @MapKey).
i belive it could be possible to allow teneo to function the same way, by
eliminating the burden on the developper of maintaining manually the
map.Entry 'KeyToValueEntry' class. Teneo could consider the EMap mapping
to be a EList, with a key column. The table mapping could remain the same
as EList. when rebuilding the list at load time, Teneo could dynamically
create a map.Entry<K,V> for each list entry, and then use the key column
defined to set the key value. this is basically what hibernate does too.
so, we could have in the database:
[parent table]
[child table]
ID: 1; ParentID: 1l GUID: 'whatever', name: 'name1'
ID: 2; ParentID: 1l GUID: 'whatever2', name: 'name2'
ID: 3; ParentID: 1l GUID: 'whatever3', name: 'name3'
then, the runtime loaded class could have a list of childs, and the key
set at the GUID (defiend by @MapKey annotation).
we could then search by key (here GUID) like this:
child chld = parent.childs.Get("whatever2"); // returns the child with ID=2
so, basically, my suggestion is to keep closer to the hibernate
methodology and map it to EMF, rather than map EMF to hibernate. This way
is just as valid, but removes the need to manually create / handle the
keyToValueEntry classes as well as map them to the table schema,
complicating map like options such as defining the key.
so, what do you think?
thanks and i hope this helps
Re: EMaps and the missing @MapKey annotation [message #74618 is a reply to message #74582] |
Fri, 09 March 2007 16:18 |
Hi Jean-Denis,
No problem of being verbose :-).
Just to react on point in your description: you say that the developer manually has to create/handle
the keyToValueEntry class. However these entry classes are also generated by emf. The entry classes
are hidden for the developer using the emf objects. So the developer does not need create/handle
these classes manually. Or am I maybe missing your point here?
For me the real issue is in the current database mapping. From a relational-mapping perspective the
issue with the current approach is that the resulting database model has redundant information: the
key is repeated in a separate field while it can be present in the value-entity. Also the current
approach will always create a join table while this is not always required. In addition the entry
class will always get a synthetic id and version which does not work in case of client-server scenarios.
Your proposal is interesting and certainly something to try out. I can also look again at mapping an
emap as a real map.
Can you enter a separate bugzilla for this (change relational mapping of emap) and copy the contents
of these posting into it? Then I can take it from there. This is some work so it will probably take
some time (number of weeks) before I can spend time on it.
gr. Martin
Jean-Denis Boudreault wrote:
> Hello again,
> very useful. This post may be long and detailed, but i want to make sure
> it is clear.
> saying about EMaps. it is in reality just a list, of the type map.entry.
> Where we get an object by key in the EMap, it basically loops the list
> until it finds the entry for that key. (I guess we should create an EMF
> feature request for a EHashmap then since this is not very efficient for
> large lists).
> <code>
> public class parent
> int ID;
> public class child
> int ID;
> string GUID;
> String name;
> </code>
> of the parent class. the datbase tables might look like this:
> <dbschema>
> | PARENT |
> | Int | ID |
> | CHILD |
> | Int | ID |
> | Int |parentID|
> | varchar | GUID |
> | varchar | name |
> </dbschema>
> add a third table, which is a 'middleman' joining table that represents
> the map.Entry. this table has a field for the key and the value. this im
> not sure, but i assume the value could also be a oneToOne join to the
> child table. For this reason, the @MapKey is not supported, since there
> is no other field to select the key from; just the defined field 'KEY'
> in that table.
> this reason, pure hibernate allows for parent/*childs collections to be
> mapped either as lists, or as maps where we can define which column can
> be used as the key (hence @MapKey).
> by eliminating the burden on the developper of maintaining manually the
> same as EList. when rebuilding the list at load time, Teneo could
> dynamically create a map.Entry<K,V> for each list entry, and then use
> the key column defined to set the key value. this is basically what
> hibernate does too.
> [parent table]
> [child table]
> way is just as valid, but removes the need to manually create / handle
> the keyToValueEntry classes as well as map them to the table schema,
The Netherlands
Re: EMaps and the missing @MapKey annotation [message #74671 is a reply to message #74636] |
Fri, 09 March 2007 17:03 |
Hi Jean-Denis,
Contributions are always wellcomed ofcourse!
If you are interested to try this out, the main changes (afaics) are:
- In the defaultannotator class there is a method processOneToManyReference. In this method the
target entity name has to be set to the eclass name of the value eclass (not the entry eclass).
- The HibernatePersistableEList is the list handler for hibernate. It extends PersistableElist which
extends DelegatingEcoreEList. The delegate list in these classes is the hibernate list (which
connects to the actual db). A possible solution approach is in the constructor of the
PersistableEList to wrap the hibernate list again in a new EMapEntryConvertingList (or another nice
name) which takes case of converting all calls from and to the hibernate list from/to the correct
map entry class.
At first I would not try to think about to handle the mapkey mapping but just get it working with a
hard coded key.
And ofcourse a test case proving that it all works is a prerequisite...
gr. Martin
> Thanks Martin,
> it will be a pleasure to log a feature request. BTW, should you deem it
> useful, i am ready to help on this topic as it would be most useful for
> my own projects which i am migrating to Teneo.
> in any case, thanks for listening and being open to suggestions :)
The Netherlands
Re: EMaps and the missing @MapKey annotation [message #74811 is a reply to message #74689] |
Sat, 10 March 2007 17:27 |
Member |
Hi Martin, hope you dont mind if i ask a few questions as i
investigate the code. I will try to keep it to a minimum.
so, i got latest sources of teneo, emf and hibernate. i begun
investigating runtime behavior of EMaps and here is where i am at for
the moment:
i found that an EMap type is mapped by teneo as a list in the .hbm.xml.
example mapping:
<class entity-name="someclass" abstract="false" lazy="false"
discriminator-value="someclass" table="`someclass`">
<meta attribute="eclassName">someclass</meta>
<meta attribute="epackage">http://someclass</meta>
<id type="long" name="e_id" column="e_id"
access=" org.eclipse.emf.teneo.hibernate.mapping.identifier.Identifie rPropertyHandler ">
<meta attribute="syntheticId">true</meta>
<generator class="native"/>
</id>
<discriminator column="`dtype`" type="string"/>
<property name="name" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`name`"/>
</property>
/* <list name="somemap" lazy="true"
cascade="merge,persist,save-update,lock,refresh">
<key update="true">
<column name="`*//*somechild_somemap*//*_e_id`"
not-null="false" unique="false"/>
</key>
<list-index column="`somechild_somemap_idx`"/>
<one-to-many entity-name="somekeyToValueEntry"/>
</list>*/
</class>
[/*.hbm.xml]
In the code, the hibernate property is defined as a listType, but
obviously, a map is not a list (at least, a java.util.map is not a
java.util.list). The class PersistableEMap returns a
PersistableDelegatingMap in 'public Map<K, V> map()' for the type, which
does not implement java.util.List. When hibernate tries to persist it
all, it attempts a cast to List on a PersistableDelegatingMap instance,
which fails with exception:
Exception in thread "Thread-1" java.lang.ClassCastException:
org.eclipse.emf.teneo.mapping.elist.PersistableEMap$Persista bleDelegatingMap
at org.hibernate.type.ListType.wrap(ListType.java:40)
Is this normal? (i guess not), but i mean, am i missing something in my
setup or is this a new bug?
besides from that, i was supprised to see how EMF hardcodes the
mechanism to define a map to a class with "key" and "value" (took me a
while to figure it out, didnt expect it to be so 'hardcoded'). Its a
surprising design decision indeed. i will see how we can approach the
problem for the EMap mapping to a <map [...]> hibernate clause.
thanks
> Right-on,
> i will get at it ASAP and post a patch on the bug report when im done.
> thanks Martin :)
Re: EMaps and the missing @MapKey annotation [message #74943 is a reply to message #74811] |
Sun, 11 March 2007 17:08 |
Member |
Hi!
ok, im done with the fix. i attached the patch in bug 176833. this
would enable @MapKey as well as @Where annotations.
see bug report for more details.
regards,
> the moment:
> .hbm.xml. example mapping:
> </id>
> </property>
> <key update="true">
> </key>
> </list>*/
> </class>
> [/*.hbm.xml]
> which does not implement java.util.List. When hibernate tries to
> persist it all, it attempts a cast to List on a
> PersistableDelegatingMap instance, which fails with exception:
> my setup or is this a new bug?
> thanks
>> Right-on,
>> thanks Martin :)
Re: EMaps and the missing @MapKey annotation [message #603321 is a reply to message #74367] |
Member |
<scenario>
TableA
then, in code:
class TableAEntity
</scenario>
Re: EMaps and the missing @MapKey annotation [message #603327 is a reply to message #74439] |
Hi JD,
need it).
gr. Martin
> <scenario>
> TableA
> then, in code:
> class TableAEntity
> </scenario>
The Netherlands
Re: EMaps and the missing @MapKey annotation [message #603332 is a reply to message #74475] |
Member |
<scenario>
TableA
</scenario>
> Hi JD,
> really need it).
> gr. Martin
>> <scenario>
>> TableA
>> then, in code:
>> class TableAEntity
>> </scenario>
> The Netherlands
Re: EMaps and the missing @MapKey annotation [message #603336 is a reply to message #74510] |
Member |
being the mapentry.
example:
<pseudocode>
ClassA
</pseudocode>
help)
> <scenario>
> TableA
> </scenario>
>> Hi JD,
>> gr. Martin
>>> <scenario>
>>> TableA
>>> then, in code:
>>> class TableAEntity
>>> </scenario>
>> The Netherlands
Re: EMaps and the missing @MapKey annotation [message #603349 is a reply to message #74528] |
Member |
Hello again,
clear.
lists).
<code>
public class parent
int ID;
public class child
int ID;
string GUID;
String name;
</code>
<dbschema>
| PARENT |
| Int | ID |
| CHILD |
| Int | ID |
| Int |parentID|
| varchar | GUID |
| varchar | name |
</dbschema>
table.
[parent table]
[child table]
Re: EMaps and the missing @MapKey annotation [message #603357 is a reply to message #74582] |
Hi Jean-Denis,
emap as a real map.
gr. Martin
> Hello again,
> it is clear.
> large lists).
> <code>
> public class parent
> int ID;
> public class child
> int ID;
> string GUID;
> String name;
> </code>
> <dbschema>
> | PARENT |
> | Int | ID |
> | CHILD |
> | Int | ID |
> | Int |parentID|
> | varchar | GUID |
> | varchar | name |
> </dbschema>
> in that table.
> hibernate does too.
> [parent table]
> [child table]
The Netherlands
Re: EMaps and the missing @MapKey annotation [message #603366 is a reply to message #74636] |
Hi Jean-Denis,
map entry class.
hard coded key.
gr. Martin
> Thanks Martin,
The Netherlands
Re: EMaps and the missing @MapKey annotation [message #603406 is a reply to message #74689] |
Member |
the moment:
example mapping:
</id>
</property>
<key update="true">
</key>
</list>*/
</class>
[/*.hbm.xml]
thanks
> Right-on,
> thanks Martin :)
Re: EMaps and the missing @MapKey annotation [message #603455 is a reply to message #74811] |
Member |
Hi!
regards,
> the moment:
> </id>
> </property>
> <key update="true">
> </key>
> </list>*/
> </class>
> [/*.hbm.xml]
> thanks
>> Right-on,
>> thanks Martin :)
Current Time: Fri Apr 26 16:09:10 GMT 2024
Powered by FUDForum. Page generated in 0.05558 seconds
