Home » Archived » XML Schema Definition (XSD) » Can't get XSD graphical editor working...
| Can't get XSD graphical editor working... [message #74309] |
Fri, 25 April 2008 15:31  |
Originally posted by: mike_yeakley.agilent.com
Hi all,
I recently downloaded and installed the EMF along with anything and
everything I thought I would need to enable graphical (GUI-driven) editing
of XML schema (XSD) and XML files.
Unfortunately, I cannot seem to get the graphical design editor tab
("Design") to show up in the list of tabs along the bottom of the file
window currently being edited. I'm expecting this tab to be there based
on the following tutorial:
http://wiki.eclipse.org/index.php/Introduction_to_the_XSD_Ed itor.
I only have the following tabs visible when editing an XSD file: "Source",
"Semantics", "Syntax".
Can some one show me how or tell me what to do to get the graphical editor
to work for XSD files?
Mike
FYI - Here's my config and what I installed wrt EMF:
Eclipse Version: 3.3.0
Build id: I20070621-1340
(Sorry for the cut-n-paste below. Don't know any other easier way to
provide the information)
Apr 22, 2008 11:28:23 AM
Date / Time Target Action Status
Apr 22, 2008 11:28:01 AM
org.eclipse.emf.codegen.ecore.ui_2.3.1.v200802051830 feature-install
success
Apr 22, 2008 11:28:14 AM
org.eclipse.emf.codegen.ecore.ui_2.3.1.v200802051830 feature-enable
success
org.eclipse.emf.codegen.ecore_2.3.2.v200802051830 feature-install
success
Apr 22, 2008 11:28:16 AM
org.eclipse.emf.codegen.ecore_2.3.2.v200802051830 feature-enable success
Apr 22, 2008 11:28:16 AM org.eclipse.emf.codegen.ui_2.3.1.v200802051830
feature-install success
Apr 22, 2008 11:28:17 AM org.eclipse.emf.codegen.ui_2.3.1.v200802051830
Apr 22, 2008 11:28:17 AM org.eclipse.emf.codegen_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.codegen_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.common.ui_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.common_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.converter_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.doc_2.3.2.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.ecore.edit_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.ecore.editor_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.ecore_2.3.2.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.edit.ui_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.edit_2.3.2.v200802051830
org.eclipse.emf.mapping.ecore.editor_2.3.1.v200802051830 feature-install
success
org.eclipse.emf.mapping.ecore.editor_2.3.1.v200802051830 feature-enable
success
org.eclipse.emf.mapping.ecore_2.3.1.v200802051830 feature-install
success
org.eclipse.emf.mapping.ecore_2.3.1.v200802051830 feature-enable success
Apr 22, 2008 11:28:18 AM org.eclipse.emf.mapping.ui_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.mapping_2.3.1.v200802051830
Apr 22, 2008 11:28:18 AM org.eclipse.emf.sdk_2.3.2.v200802051830
Apr 22, 2008 11:28:20 AM org.eclipse.emf_2.3.2.v200802051830
Apr 22, 2008 11:28:20 AM org.eclipse.emf.source_2.3.2.v200802051830
Apr 22, 2008 11:28:20 AM org.eclipse.emf.sdk_2.3.2.v200802051830
org.eclipse.emf.ecore.sdo.doc_2.3.2.v200802051830 feature-install
success
org.eclipse.emf.ecore.sdo.doc_2.3.2.v200802051830 feature-enable success
org.eclipse.emf.ecore.sdo.edit_2.3.1.v200802051830 feature-install
success
org.eclipse.emf.ecore.sdo.edit_2.3.1.v200802051830 feature-enable
success
org.eclipse.emf.ecore.sdo.editor_2.3.1.v200802051830 feature-install
success
org.eclipse.emf.ecore.sdo.editor_2.3.1.v200802051830 feature-enable
success
org.eclipse.emf.ecore.sdo.sdk_2.3.2.v200802051830 feature-install
success
Apr 22, 2008 11:28:21 AM org.eclipse.emf.ecore.sdo_2.3.1.v200802051830
org.eclipse.emf.ecore.sdo.source_2.3.2.v200802051830 feature-enable
success
org.eclipse.emf.ecore.sdo.sdk_2.3.2.v200802051830 feature-enable success
org.eclipse.emf.ecore.sdo.source_2.3.2.v200802051830 feature-install
success
Apr 22, 2008 11:28:21 AM org.eclipse.xsd.doc_2.3.2.v200802051830
Apr 22, 2008 11:28:22 AM org.eclipse.xsd.doc_2.3.2.v200802051830
org.eclipse.xsd.ecore.converter_2.3.2.v200802051830 feature-install
success
org.eclipse.xsd.ecore.converter_2.3.2.v200802051830 feature-enable
success
Apr 22, 2008 11:28:22 AM org.eclipse.xsd.edit_2.3.0.v200802051830
Apr 22, 2008 11:28:22 AM org.eclipse.xsd.editor_2.3.0.v200802051830
org.eclipse.xsd.mapping.editor_2.3.0.v200802051830 feature-install
success
org.eclipse.xsd.mapping.editor_2.3.0.v200802051830 feature-enable
success
Apr 22, 2008 11:28:22 AM org.eclipse.xsd.mapping_2.3.0.v200802051830
Apr 22, 2008 11:28:22 AM org.eclipse.xsd.sdk_2.3.2.v200802051830
Apr 22, 2008 11:28:23 AM org.eclipse.xsd_2.3.2.v200802051830
Apr 22, 2008 11:28:23 AM org.eclipse.xsd.source_2.3.2.v200802051830
Apr 22, 2008 11:28:23 AM org.eclipse.xsd.sdk_2.3.2.v200802051830
org.eclipse.emf.examples.source_2.3.1.v200802051830 feature-install
success
org.eclipse.emf.examples.source_2.3.1.v200802051830 feature-enable
success
Apr 22, 2008 11:28:23 AM org.eclipse.emf.examples_2.3.1.v200802051830
| Re: Can't get XSD graphical editor working... [message #74331 is a reply to message #74309] |
Fri, 25 April 2008 16:11   |
Mike,
The XSD project doesn't directly provide this editor. We only provide a
crude sample editor. You'll want to install
http://www.eclipse.org/webtools/ and ask any questions about the editor
on the WTP newsgroup, which I've added to the "to" list of the reply.
Mike wrote:
> Hi all,
> editing of XML schema (XSD) and XML files.
> based on the following tutorial:
> "Source", "Semantics", "Syntax".
> editor to work for XSD files?
> Mike
> org.eclipse.emf.codegen.ui_2.3.1.v200802051830 feature-install
> success
> org.eclipse.emf.codegen.ui_2.3.1.v200802051830 feature-enable
> success
> org.eclipse.emf.codegen_2.3.1.v200802051830 feature-install
> success
> org.eclipse.emf.codegen_2.3.1.v200802051830 feature-enable
> success
> org.eclipse.emf.common.ui_2.3.1.v200802051830 feature-install
> success
> org.eclipse.emf.common.ui_2.3.1.v200802051830 feature-enable
> success
> org.eclipse.emf.common_2.3.1.v200802051830 feature-install
> success
> org.eclipse.emf.common_2.3.1.v200802051830 feature-enable success
> org.eclipse.emf.converter_2.3.1.v200802051830 feature-install
> success
> org.eclipse.emf.converter_2.3.1.v200802051830 feature-enable
> success
> org.eclipse.emf.ecore.edit_2.3.1.v200802051830 feature-install
> success
> org.eclipse.emf.ecore.edit_2.3.1.v200802051830 feature-enable
> success
> org.eclipse.emf.edit.ui_2.3.1.v200802051830 feature-install
> success
> org.eclipse.emf.edit.ui_2.3.1.v200802051830 feature-enable
> success
> org.eclipse.emf.mapping.ui_2.3.1.v200802051830 feature-install
> success
> org.eclipse.emf.mapping.ui_2.3.1.v200802051830 feature-enable
> success
> org.eclipse.emf.mapping_2.3.1.v200802051830 feature-install
> success
> org.eclipse.emf.mapping_2.3.1.v200802051830 feature-enable
> success
> org.eclipse.emf.source_2.3.2.v200802051830 feature-enable success
> org.eclipse.emf.source_2.3.2.v200802051830 feature-install
> success
> org.eclipse.emf.ecore.sdo_2.3.1.v200802051830 feature-enable
> success
> org.eclipse.emf.ecore.sdo_2.3.1.v200802051830 feature-install
> success
> org.eclipse.xsd.editor_2.3.0.v200802051830 feature-install
> success
> org.eclipse.xsd.editor_2.3.0.v200802051830 feature-enable success
> org.eclipse.xsd.mapping_2.3.0.v200802051830 feature-install
> success
> org.eclipse.xsd.mapping_2.3.0.v200802051830 feature-enable
> success
> org.eclipse.xsd.source_2.3.2.v200802051830 feature-enable success
> org.eclipse.xsd.source_2.3.2.v200802051830 feature-install
> success
> org.eclipse.emf.examples_2.3.1.v200802051830 feature-install
> success
> org.eclipse.emf.examples_2.3.1.v200802051830 feature-enable
> success
| Re: Can't get XSD graphical editor working... [message #74346 is a reply to message #74331] |
Thu, 01 May 2008 13:09  |
You can find the declared builds here:
http://download.eclipse.org/webtools/downloads/
(Grab the required requisites zip, and the wtp zip)
Note that for the latest R3.0 Integration build, because of P2, you can
extract the zips into the dropins folder. See the section "Running WTP"
from the following link for more details:
http://wiki.eclipse.org/WTP/What_we_have_learned_%28to_love% 29_about_P2
> Ed Merks wrote:
> Mike,
> Mike wrote:
>> Hi all,
>> Thanks,
>> Mike
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
| Re: Can't get XSD graphical editor working... [message #602998 is a reply to message #74309] |
Mike,
Mike wrote:
> Hi all,
> Mike
> success
> success
> success
> success
> success
> success
> success
> success
> success
> success
> success
> success
> success
> success
> success
> success
> success
> success
> success
> success
> success
> success
> success
> success
> success
> success
| Re: Can't get XSD graphical editor working... [message #603002 is a reply to message #74331] |
> Ed Merks wrote:
> Mike,
> Mike wrote:
>> Hi all,
>> Thanks,
>> Mike
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
>> success
Current Time: Thu Nov 06 09:41:15 EST 2025
Powered by FUDForum. Page generated in 0.03982 seconds
