Re: Find Function within PHP project [message #74333 is a reply to message #74297] |
Mon, 30 June 2008 19:38 |
Originally posted by: stoyan.dimitrov.homelan.bg
Hi Shawn,
you can use 'Navigate' > 'Open PHP Element' from the main menu or
Shift+Alt+G shortcut. If you need to go to the function declaration just
click on the function name and press F3.
Shawn Clark wrote:
> Hello,
> I have a Drupal project that I am working on through Eclipse 3.4 with
> PDT 1.1. In the PHP Project Outline I noticed that there is a listing of
> all functions from the PHP files on Drupal. As Drupal uses very little
> in the way of classes the function list is very long for each module
> that is used with Drupal. Is there a way to quickly search for a
> function much like you look for a class (Open Type) / file (Open
> Resource)???
> If there is no way, how do I go about making a request to get that
> functionality added? I don't think it would take much more work as the
> list of functions is already being done by the indexer.
> Thanks
> P.S. I know I could do a search through all the php files to find the
> function but that includes all calls to the function. I would much
> rather be able to take advantage of the list that is already in the PHP
> Project Outline.
> Shawn Clark
Stoyan
Re: Find Function within PHP project [message #74369 is a reply to message #74351] |
Mon, 30 June 2008 19:52 |
Shawn Clark wrote:
> Thanks for the quick reply Стоян Димитров...
> I was thinking that functionality must be there as I use to use a
> similar ability with my Java development. Unfortunately with the
> I20080616 build I don't have that 'Open PHP Element' menu item. The
> other thing is pressing F3 while on a function name doesn't take me to
> the declaration. I will grab the latest nightly build to see if it is back.
F3 doesn't work for me with the latest integration build too. Will try
to figure out another way around. Another tip, somehow related, it to
track down something usable with Ctrl+3 - giving you access to nearly
all UI/menu items.
> Shawn Clark
> Стоян Димитров wrote:
>> Hi Shawn,
>> just click on the function name and press F3.
>> Shawn Clark wrote:
>>> Hello,
>>> Resource)???
>>> Thanks
>>> Project Outline.
>>> Shawn Clark
Stoyan
Re: Find Function within PHP project [message #74387 is a reply to message #74369] |
Mon, 30 June 2008 20:24 |
I tried the last two I builds (I20080616, I20080602) and the last two N
(N20080630, N20080623) builds and none of them had the functionality I'm
talking about above (obviously I'm referring to PDT 1.0.3
functionality). That's the reason I stay with 1.0.3 for now. (:
P.S.
Excuse me for the caused version confusion.
>> back.
> all UI/menu items.
>> Shawn Clark
>>> Hi Shawn,
>>> Shawn Clark wrote:
>>>> Hello,
>>>> listing of
>>>> Resource)???
>>>> Thanks
>>>> Project Outline.
>>>> Shawn Clark
Stoyan
Re: Find Function within PHP project [message #74552 is a reply to message #74351] |
Tue, 01 July 2008 13:29 |
I think this is a matter of file network filtering... I'll explain:
F3 will only work if PHP element is accessible from current file. I.e.
there is a resolved 'include' statement in the original file, which
leads to the file where PHP element is declared.
I think this feature must be configurable, and it should be disabled by
default.
What do you think?
Thanks!
> Shawn Clark
>> Hi Shawn,
>> Shawn Clark wrote:
>>> Hello,
>>> Resource)???
>>> Thanks
>>> Project Outline.
>>> Shawn Clark
Re: Find Function within PHP project [message #74791 is a reply to message #74758] |
Thu, 03 July 2008 12:31 |
Of course, that what I was talking about.
Filtering by include() should be optional.
I've just committed a new bug about it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=239431
Thanks!
Shawn Clark wrote:
> Michael,
> I see what you are talking about but this functionality doesn't work
> well with the way Drupal files / includes are organized. This may be
> something a little Drupal specific but it has a fairly active OS
> community and making Eclipse PDT work nicely with it would be beneficial.
> The main thing with Drupal is that it loads modules through dynamic
> include statements. The include statement has a variable for the
> included file and that variable is retrieved from a database call.
> What would need to happen is that if the Open Declaration (F3) command
> doesn't find a function then it would open the 'Open Method / Open PHP
> Element' window with the current selected function name entered into
> this window so the user can see all possible matches and choose which
> one is the actual function declaration.
> Sound feasible?
> Michael Spector wrote:
>> Hi,
>> by default.
>> What do you think?
>> Thanks!
>>> to the declaration. I will grab the latest nightly build to see if it
>>> is back.
>>> Shawn Clark
>>>> Hi Shawn,
>>>> Shawn Clark wrote:
>>>>> Hello,
>>>>> listing of
>>>>> Resource)???
>>>>> Thanks
>>>>> PHP
>>>>> Project Outline.
>>>>> Shawn Clark
FUDForum. Page generated in 0.03369 seconds
