Home » Language IDEs » Java Development Tools (JDT) » Formatter: Unmanaged Profile
Formatter: Unmanaged Profile [message #709617] Thu, 04 August 2011 01:05 Go to next message
Can anyone explain the intention behind an unmanaged formatter profile? And a workflow that involves it?
I want to share Project Specific Settings across my team, including a formatter profile. I've placed the .settings directory and its contents under source control. Now we all use the same settings. However, I would like any of us to be able to tweak the formatter settings and distribute the changes by committing them. Unfortunately, when one of us opens the Formatter config dialog the Active profile is called "Unmanaged profile 'Blah'" and cannot be edited.
Is there a way to stop my shared profile from appearing as unmanaged?
We're using Indigo.
Cheers
[Updated on: Thu, 04 August 2011 01:06] by Moderator
Re: Formatter: Unmanaged Profile [message #710686 is a reply to message #709617] Fri, 05 August 2011 05:25 Go to previous message
> formatter profile. I've place the .settings directory and its contents
> would like any of use to be able to tweak the formatter settings and
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=325001.
Dani
> We're using Indigo.
> Cheers
Previous Topic:Redirect stdout stderr
Next Topic:build.xml:265: Servlet-api not found.
Current Time: Sat Nov 01 04:28:02 EDT 2025
Powered by FUDForum. Page generated in 0.87517 seconds
