Re: Enabling study layout in JavaScript generated axes [message #709269] |
Wed, 03 August 2011 18:03 |
Can you try to reproduce the issue with sample data from the sample db?
If so post the report.
Jason
On 8/3/2011 1:57 PM, vasa.curcin wrote:
> I am using normal grouping on X-axis.
> When I add a second axis using the Designer (using different data for
> the second series, but same starting chart), the behaviour is exactly
> the same, e.g. it appears normal when study view is deselected, but as
> soon as I switch it on the labels disappear from the X-axis and the
> original Y-axis.
Re: Enabling study layout in JavaScript generated axes [message #713588 is a reply to message #713318] |
Mon, 08 August 2011 16:03 |
I do not think a bug was logged for this. Can you open one and post the
number?
Jason
On 8/8/2011 6:40 AM, pickle_supreme wrote:
> The only new thing I managed to deduce is that something happens during
> the rendering phase that causes the axis labels to disappear, and the
> axis origins to separate. There are some study-model specific rendering
> methods in
> org.eclipse.birt.chart.computation.withaxes.PlotWith2DAxes.java that
> look slightly suspicious...
FUDForum. Page generated in 0.03543 seconds
