Home » Newcomers » Newcomers » ClassNotFoundException
ClassNotFoundException [message #708441] Tue, 02 August 2011 16:19 Go to next message
I have been using Eclipse Galileo for some time. Recently, I installed Europa for Java IDE. I wrote a basic program that imported nothing other than some classes from java.io and java.util. When I tried to run the program, I got a ClassNotFoundException error. It is my understanding that this error occurs when a class needed by the compiler is not on the class path. The problem is that I don't understand what isn't specified on the class path (what I need to add) or where those files are located. The Europa stack trace error is below:
Thread [main] (Suspended)
	ClassNotFoundException(Throwable).<init>(String, Throwable) line: 286
	ClassNotFoundException(Exception).<init>(String, Throwable) line: not available
	ClassNotFoundException(ReflectiveOperationException).<init>(String, Throwable) line: not available
	ClassNotFoundException.<init>(String) line: not available
	URLClassLoader$1.run() line: not available
	AccessController.doPrivileged(PrivilegedExceptionAction<T>, AccessControlContext) line: not available [native method]
	Launcher$ExtClassLoader(URLClassLoader).findClass(String) line: not available
	Launcher$ExtClassLoader(ClassLoader).loadClass(String, boolean) line: not available
	Launcher$AppClassLoader(ClassLoader).loadClass(String, boolean) line: not available
	Launcher$AppClassLoader.loadClass(String, boolean) line: not available
	Launcher$AppClassLoader(ClassLoader).loadClass(String) line: not available
	driver.main(String[]) line: 12
C:\Program Files\Java\jre7\bin\javaw.exe (Aug 1, 2011 2:23:51 AM)
Re: ClassNotFoundException [message #708455 is a reply to message #708441] Tue, 02 August 2011 16:26 Go to previous messageGo to next message
[snip]
(And you backed up by 2 full releases from Galileo because...? The
present current release is the second since Galileo.)
Include the source code to what appears to be driver.main(). There may
be a clue in there.
Re: ClassNotFoundException [message #708463 is a reply to message #708455] Tue, 02 August 2011 16:48 Go to previous messageGo to next message
Oh, maybe it wasn't Galileo (or maybe I was confused when I downloaded Europa). I had to re-install everything recently and went to eclipse.org/downloads to get the Java IDE. For some reason, it took me to Europa as the default download so I assumed it was more recent. I see now that isn't the case.
import java.io.BufferedReader;
import java.io.DataInputStream;
import java.io.FileInputStream;
import java.io.IOException;
import java.io.InputStreamReader;
import java.util.StringTokenizer;
public class driver {
	public static void main(String[] args) throws IOException {
		double oldError;
		NeuralNetwork myNet = new NeuralNetwork("C:\\Users\\Owner\\Documents\\school\\BU\\big data\\independent study\\class24_set1.txt");
		myNet.trainEpoch();
		/*train the network*/
		do {
			oldError = myNet.getTotalError();
			myNet.trainEpoch();
		} while(myNet.getTotalError() < oldError);
		/*get test data*/
		int numEx = myNet.getNumExamples();	//assuming both sets have the same number of examples
		int numIn = myNet.getNumInputs();
		int numOut = myNet.getNumOutputs();
		double[][] data = new double[numEx][numIn];
		FileInputStream fstream;
		fstream = new FileInputStream("C:\\Users\\Owner\\Documents\\school\\BU\\big data\\independent study\\class24_set2.txt");
		DataInputStream in = new DataInputStream(fstream);
		BufferedReader br = new BufferedReader(new InputStreamReader(in));
		String line;
		int i = -1;
		int j;
		while((line = br.readLine()) != null) {
			j = 0;
			i++;
			data[i][j] = 1;	//bias effect
			StringTokenizer st = new StringTokenizer(line, ",");
			while(st.hasMoreTokens()) {
				j++;
				switch(j) {
				case 1:
				case 2:
					data[i][j] = 0.8*(Double.parseDouble(st.nextToken())/3)+0.1;
					break;
				case 4:
				case 5:
					data[i][j-1] = 0.8*(Double.parseDouble(st.nextToken())/3)+0.1;
					break;
				case 14:
					data[i][5] = 0.8*(Double.parseDouble(st.nextToken())/3)+0.1;
		in.close();
		/*generate class output*/
		int r, k;
		int numHid = myNet.getNumHidden();
		double sum = 0;
		double[][] hidden = new double[numEx][numHid+1];
		double[][] output = new double[numEx][numOut];
		for(r = 0; r < numEx; r++) {
			hidden[r][0] = 1;
			for(k = 0; k <= numHid; k++) { //input layer to hidden layer
				sum = 0;
				for(i = 0; i < numIn; i++)
					sum = sum + myNet.getWeight1(k,i)*data[r][i];
				hidden[r][k] = 1 / (1 + Math.exp(-1*sum));
			sum = 0;								//hidden layer to output layer
			for(j = 0; j < numOut; j++) {
					sum = sum + myNet.getWeight2(j,k)*hidden[r][k];
				output[r][j] = 1 / (1 + Math.exp(-1*sum));
			if(output[r][0] > output[r][1])
				System.out.println("2");
			else
				System.out.println("4");
Re: ClassNotFoundException [message #708472 is a reply to message #708463] Tue, 02 August 2011 17:06 Go to previous message
> [snip]
If recent, your download should be Indigo then. That's great.
Okay, a couple of observations...
First, 16 year-old Java practice holds that your class name begin with
an upper-case letter. (This is not your exception.)
Second, you should always subsume your Java class down under a formally
named package. Maybe something like: edu.myschool.cs.exercises (can be
anything you like--this is also not your present exception).
Third, I don't see an import statement defining class NeuralNetwork.
This might be your exception. I'm not certain how the compiler let you
get away with this in the first place or why Eclipse accepted to let you
run it.
Observations 1 and 2 are Java questions that should be answered in your
class, in your book, or in specifically Java forums (like the really
great Java Ranch forums). Observation 3 is probably also a Java
question, but would naturally be asked in this forum as you're running
it in Eclipse and it's unclear why it's crashing.
Someone stronger in Java than I might look at your stack trace and
intuit a better response than I'm giving you. Obviously, it's easier to
diagnose having it in one's own workbench.
Last, did you download and set up a proper JDK in installed JREs? If
it's not clear to you what this is, check out the first half of
http://www.javahotchocolate.com/tutorials/setup-jdk.html. This would
tend to make some of the stack trace clearer in some instances.
Previous Topic:Display image in applet viewer
Next Topic:How do I get CVS working?
Current Time: Sat Jul 05 23:42:58 EDT 2025
Powered by FUDForum. Page generated in 0.09099 seconds
