Ecore to XSD [message #73811] |
Tue, 04 March 2008 17:31 |
Originally posted by: vlalan.csc.com
I want to generate the xsd from an Ecore file. I have written some code
which uses the EcoreSchemaBuilder to create the xsd file.
Here is the code snippet:
EPackage ePackage = getEPackage(ecoreFilePath);
EPackage.Registry.INSTANCE.put(XSDPackageImpl.eNS_URI,
XSDPackageImpl.eINSTANCE);
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(
XSDPackageImpl.eNS_URI, XSDPackageImpl.eINSTANCE);
resourceSet.getResourceFactoryRegistry()
.getExtensionToFactoryMap().put(XSD_EXTENSION,new
XSDResourceFactoryImpl());
ExtendedMetaData extendedMetaData = new BasicExtendedMetaData();
EcoreSchemaBuilder xsdBuilder = new EcoreSchemaBuilder(extendedMetaData);
XSDSchema xsd = xsdBuilder.getSchema(ePackage);
Resource xsdResource = resourceSet.createResource(URI
.createPlatformResourceURI(xsdFilePath.toString()));
xsdResource.getContents().add(xsd);
....code to save the xsd resource.......
My problem is that i donot need any ecore references in the xsd file. It
should be the plain xsd file without any ecore declaration in it.
Any pointers on this will really help.....
Thanks in advance,
Vipul
Re: Ecore to XSD [message #73829 is a reply to message #73811] |
Tue, 04 March 2008 18:17 |
Vipul,
If you don't want references to Ecore.xsd it's best to avoid using
Ecore.ecore's data types. If you you XMLTypePackage's data types
instead, your end result will be uses of XML Schema's built-in types.
Can you change your Ecore model to avoid using Ecore's data types? I
suppose you could specialize protected String getURI(EClassifier
eClassifier) to do the remapping of Ecore's EDataTypes to XML Type
Package's EDataTypes on the fly...
Vipul wrote:
> code which uses the EcoreSchemaBuilder to create the xsd file.
> It should be the plain xsd file without any ecore declaration in it.
> Thanks in advance,
> Vipul
Re: Ecore to XSD [message #73846 is a reply to message #73829] |
Tue, 04 March 2008 20:17 |
Ed Merks wrote:
> Vipul,
> Vipul wrote:
>> Hi,
>> Thanks in advance,
>> Vipul
Hi Ed,
Thanks for such a quick reply.....
I dont know how to supress the Ecore to use the Ecore DataType's. I am
creating the Ecore using XSDEcoreBuilder
The code for it is:
final ExtendedMetaData extendedMetaData = new BasicExtendedMetaData(
resourceSet.getPackageRegistry());
resourceSet.getLoadOptions().put(XMLResource.OPTION_EXTENDED _META_DATA,
extendedMetaData);
XSDEcoreBuilder xsdEcoreBuilder = new XSDEcoreBuilder(extendedMetaData);
Collection ePackageList = xsdEcoreBuilder.generate(fileURI);
if (ePackageList != null && ePackageList.size() > 0
&& ePackageList instanceof ArrayList) {
// taking the first ePackage and building the ecore
if (((ArrayList) ePackageList).get(0) instanceof EPackage) {
final EPackage ePackage = (EPackage) ((ArrayList) ePackageList)
.get(0);
return ePackage;
This method creates an ecore from the specified xsd. I am really not clear
about specializing the getURI method to get the remapping of Ecore's
EDataTypes to XML Type. Which class does have this method?
Re: Ecore to XSD [message #73881 is a reply to message #73846] |
Tue, 04 March 2008 22:00 |
Vipul
Comments below.
Vipul wrote:
> Ed Merks wrote:
>> Vipul,
>> types. Can you change your Ecore model to avoid using Ecore's data
>> types? I suppose you could specialize protected String
>> getURI(EClassifier eClassifier) to do the remapping of Ecore's
>> EDataTypes to XML Type Package's EDataTypes on the fly...
>> Vipul wrote:
>>> Hi,
>>> file. It should be the plain xsd file without any ecore declaration
>>> in it.
>>> Thanks in advance,
>>> Vipul
> Hi Ed,
If you started with a schema why are you generating a schema? I
wouldn't expect this result to use Ecore data types at all. I'd expect
it to use types from the XMLTypePackage.
> The code for it is: ResourceSet resourceSet = new ResourceSetImpl();
> extendedMetaData);
> .get(0);
> return ePackage;
> clear about specializing the getURI method to get the remapping of
> Ecore's EDataTypes to XML Type. Which class does have this method?
This is going in a different direction than you mentioned before. This
is converting a schema to an Ecore instance. I'm a little confused
now. Maybe an example is worth a thousand words...
Re: Ecore to XSD [message #73899 is a reply to message #73881] |
Tue, 04 March 2008 22:51 |
Hi Ed,
The requirement is that we have a xsd from which we first create an Ecore
and using the Ecore Diagram we edit that ecore and then we can reexport
the ecore to create the new xsd.
Its something that you first convert xsd to ecore and edit that ecore
using GMF diagram editor and then again create the xsd back from the
edited ecore.
In this whole process i am able to generate the xsd back but it do have
ecore references which i do not need.
Vipul
Re: Ecore to XSD [message #73917 is a reply to message #73899] |
Tue, 04 March 2008 23:48 |
Vipul,
When you edit, be sure the things you add to your *.ecore model only
come from XMLType.ecore, and not from Ecore.ecore, so you end with with
only references to things you do need.
Vipul wrote:
> Hi Ed,
> Ecore and using the Ecore Diagram we edit that ecore and then we can
> reexport the ecore to create the new xsd.
> edited ecore.
> have ecore references which i do not need.
> Vipul
Re: Ecore to XSD [message #74006 is a reply to message #73917] |
Wed, 12 March 2008 14:35 |
Originally posted by: Nicolas.Dufault.techsolcom.ca
I'm trying to do the same thing. Making an XSD out of a Ecore file.
Would it be possible for you to show me a working exemple of how you are
doing it ?
It would be greatly appreciated.
NickDuff
Re: Ecore to XSD [message #74024 is a reply to message #74006] |
Wed, 12 March 2008 15:14 |
Nick,
I don't have any examples. Looking at how it's used in XSDExporter is
the best I can do in terms of pointing at an example.
NickDuff wrote:
> Hello,
> are doing it ?
> NickDuff
Re: Ecore to XSD [message #602877 is a reply to message #73811] |
Ed Merks Messages: 33142 Registered: July 2009 |
Vipul,
Vipul wrote:
> Thanks in advance,
> Vipul
Ed Merks
Re: Ecore to XSD [message #602882 is a reply to message #73829] |
Vipul Messages: 6 Registered: July 2009 |
Ed Merks wrote:
> Vipul,
> Vipul wrote:
>> Hi,
>> Thanks in advance,
>> Vipul
Hi Ed,
The code for it is:
extendedMetaData);
.get(0);
return ePackage;
Re: Ecore to XSD [message #602889 is a reply to message #73846] |
Vipul
Comments below.
Vipul wrote:
> Ed Merks wrote:
>> Vipul,
>> Vipul wrote:
>>> Hi,
>>> in it.
>>> Thanks in advance,
>>> Vipul
> Hi Ed,
> extendedMetaData);
> .get(0);
> return ePackage;
Ed Merks
Re: Ecore to XSD [message #602902 is a reply to message #73899] |
Vipul,
Vipul wrote:
> Hi Ed,
> edited ecore.
> Vipul
Ed Merks
Re: Ecore to XSD [message #602922 is a reply to message #73917] |
doing it ?
NickDuff
Re: Ecore to XSD [message #602926 is a reply to message #74006] |
Nick,
NickDuff wrote:
> Hello,
> are doing it ?
> NickDuff
Ed Merks
FUDForum. Page generated in 0.05540 seconds
