Re: Running different test suite [message #707971 is a reply to message #707954] |
Tue, 02 August 2011 09:35 |
Michel LAURENT Messages: 8 Registered: July 2011 |
Thanks for your fast reply Olivier.
Well, in this case, I think the only think to do is to use TestJob. Even If I have to do 3 times the same things ... It will not be easy to maintain this (the test are the same for win32,win64 and mac version) but the test suite is per AUT ID...
We have 4 versions of our <Program>. Each one have the same base (so I only created 1 AUT) but some test are version specific. For example, you have to do steps before running the 'core' test who is available for each version...
So I defined 12 AUT configuration :
version1_win32
version1_win64
version1_mac
version2_win32
version2_win64
version2_mac
version3_win32
version3_win64
version3_mac
version4_win32
version4_win64
version4_mac
This way, the test suite are for <Program> and I can specify everything in the XML config file for testexecutor.
The solution is to transform my testsuite into test case and this way, I will only have 4 test suite (one for each version) and I only have to run one test suite per system.
I don't really see what's the interest of Test Jobs ... May I miss something ?
Michel
[Updated on: Tue, 02 August 2011 09:47] Report message to a moderator
FUDForum. Page generated in 0.03652 seconds
