Re: eclipse-maven-plugin 2.6 and AJDT [message #73798 is a reply to message #73778] |
Tue, 05 May 2009 18:07 |
Originally posted by: andrew.eisenberg.springsource.com
eclipse-maven-plugin version 2.6 is incompatible with AJDT. See:
http://jira.codehaus.org/browse/MECLIPSE-538
http://jira.codehaus.org/browse/MECLIPSE-544
This should be addressed in version 2.7.
For now, you must use version 2.5.x.
This works, but does not automatically add aspect libraries to the aspect
path. There is a work around. See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=270554
On 05/05/09 5:00 AM, in article
ee04284b043f19143fc401e6cd7d014b$1@www.eclipse.org, "kaj.hejer@usit.uio.no"
<kaj.hejer@usit.uio.no> wrote:
> Hi!
> I'm not sure if this is the right forum to ask this question, but I give
> it a try :)
> After upgrading to eclipse-maven-plugin version 2.6 I get a
> "java.lang.NoClassDefFoundError: org/aspectj/weaver/BCException" when
> running my unittests from inside eclipse. I have tried to turn on JDT
> weaving but get the same exception. I'm on MacOS X 10.5.6 with java
> 1.6.0_07
> When trying to use the new support for AJDT as described on
> http://jira.codehaus.org/browse/MECLIPSE-200 and
> http://maven.apache.org/plugins/maven-eclipse-plugin/example s/ajdt-projects.ht
> ml
> by using
> <ajdtVersion>1.6</ajdtVersion>
> I don't get aspectjweaver.jar included in my .classpath file and I get the
> stacktrace bellow.
> If I use
> <ajdtVersion>none</ajdtVersion>
> I get spectjweaver.jar included in my .classpath file but then I have to
> add the following manually for spring-aspects after running mvn
> eclipse:eclipse:
> <attributes>
> <attribute name="org.eclipse.ajdt.aspectpath" value="true" />
> </attributes>
> That is why I would like to get the new ajdt support in
> eclipse-maven-plugin to work.
> The stacktrace I get with eclipse eclipse-jee-ganymede-SR2 (3.4.2) is:
> java.lang.IllegalStateException: Failed to load ApplicationContext
> at
> org.springframework.test.context.TestContext.getApplicationC ontext(TestContext
> .java:201)
> at
> org.springframework.test.context.support.DependencyInjection TestExecutionListe
> ner.injectDependencies(DependencyInjectionTestExecutionListe ner.java:109)
> at
> ner.prepareTestInstance(DependencyInjectionTestExecutionList ener.java:75)
> at
> org.springframework.test.context.TestContextManager.prepareT estInstance(TestCo
> ntextManager.java:255)
> at
> org.springframework.test.context.junit4.SpringJUnit4ClassRun ner.createTest(Spr
> ingJUnit4ClassRunner.java:111)
> at
> org.springframework.test.context.junit4.SpringJUnit4ClassRun ner.invokeTestMeth
> od(SpringJUnit4ClassRunner.java:148)
> at
> org.junit.internal.runners.JUnit4ClassRunner.runMethods(JUni t4ClassRunner.java
> :51)
> at
> org.junit.internal.runners.JUnit4ClassRunner$1.run(JUnit4Cla ssRunner.java:44)
> at
> org.junit.internal.runners.ClassRoadie.runUnprotected(ClassR oadie.java:27)
> at
> org.junit.internal.runners.ClassRoadie.runProtected(ClassRoa die.java:37)
> at
> org.junit.internal.runners.JUnit4ClassRunner.run(JUnit4Class Runner.java:42)
> at
> org.springframework.test.context.junit4.SpringJUnit4ClassRun ner.run(SpringJUni
> t4ClassRunner.java:97)
> at
> org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.r un(JUnit4TestRefer
> ence.java:45)
> at
> org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
> at
> org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunn
> er.java:460)
> at
> er.java:673)
> at
> org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.ja
> va:386)
> at
> org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.j
> ava:196)
> Caused by: org.springframework.beans.factory.BeanDefinitionStoreExcepti on:
> Unexpected exception parsing XML document from URL
> [file:src/main/webapp/WEB-INF/applicationContext.xml]; nested exception is
> at
> org.springframework.beans.factory.xml.XmlBeanDefinitionReade r.doLoadBeanDefini
> tions(XmlBeanDefinitionReader.java:420)
> at
> org.springframework.beans.factory.xml.XmlBeanDefinitionReade r.loadBeanDefiniti
> ons(XmlBeanDefinitionReader.java:342)
> at
> ons(XmlBeanDefinitionReader.java:310)
> at
> org.springframework.beans.factory.support.AbstractBeanDefini tionReader.loadBea
> nDefinitions(AbstractBeanDefinitionReader.java:143)
> at
> nDefinitions(AbstractBeanDefinitionReader.java:178)
> at
> nDefinitions(AbstractBeanDefinitionReader.java:149)
> at
> nDefinitions(AbstractBeanDefinitionReader.java:212)
> at
> org.springframework.test.context.support.AbstractGenericCont extLoader.loadCont
> ext(AbstractGenericContextLoader.java:81)
> at
> ext(AbstractGenericContextLoader.java:42)
> at
> org.springframework.test.context.TestContext.loadApplication Context(TestContex
> t.java:173)
> at
> .java:197)
> ... 17 more
> Caused by: java.lang.NoClassDefFoundError: org/aspectj/weaver/BCException
> at java.lang.Class.forName0(Native Method)
> at java.lang.Class.forName(Class.java:164)
> at
> org.springframework.aop.config.ConfigBeanDefinitionParser.cl ass$(ConfigBeanDef
> initionParser.java:208)
> at
> org.springframework.aop.config.ConfigBeanDefinitionParser.cr eatePointcutDefini
> tion(ConfigBeanDefinitionParser.java:539)
> at
> org.springframework.aop.config.ConfigBeanDefinitionParser.pa rsePointcut(Config
> BeanDefinitionParser.java:476)
> at
> org.springframework.aop.config.ConfigBeanDefinitionParser.pa rse(ConfigBeanDefi
> nitionParser.java:142)
> at
> org.springframework.beans.factory.xml.NamespaceHandlerSuppor t.parse(NamespaceH
> andlerSupport.java:69)
> at
> org.springframework.beans.factory.xml.BeanDefinitionParserDe legate.parseCustom
> Element(BeanDefinitionParserDelegate.java:1297)
> at
> Element(BeanDefinitionParserDelegate.java:1287)
> at
> org.springframework.beans.factory.xml.DefaultBeanDefinitionD ocumentReader.pars
> eBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:13 5)
> at
> org.springframework.beans.factory.xml.DefaultBeanDefinitionD ocumentReader.regi
> sterBeanDefinitions(DefaultBeanDefinitionDocumentReader.java :92)
> at
> org.springframework.beans.factory.xml.XmlBeanDefinitionReade r.registerBeanDefi
> nitions(XmlBeanDefinitionReader.java:507)
> at
> tions(XmlBeanDefinitionReader.java:398)
> ... 27 more
> The stacktrace I get with eclipse 3.5M7 is:
> at
> .java:201)
> at
> at
> at
> at
> at
> at
> :51)
> at
> at
> at
> at
> at
> at
> ence.java:46)
> at
> at
> er.java:467)
> at
> er.java:683)
> at
> va:390)
> at
> ava:197)
> org/aspectj/weaver/reflect/ReflectionWorld$ReflectionWorldEx ception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> t.java:173)
> at
> .java:197)
> ... 17 more
> at java.lang.Class.forName(Class.java:169)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 27 more
> Caused by: java.lang.ClassNotFoundException:
> org.aspectj.weaver.reflect.ReflectionWorld$ReflectionWorldEx ception
> at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
> at java.security.AccessController.doPrivileged(Native Method)
> at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
> at java.lang.ClassLoader.loadClass(ClassLoader.java:316)
> at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:288 )
> at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
> at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:374 )
> ... 40 more
> From my pom.xml:
> <plugin>
> <groupId>org.codehaus.mojo</groupId>
> <artifactId>aspectj-maven-plugin</artifactId>
> <executions>
> <execution>
> <goals>
> <goal>compile</goal>
> <goal>test-compile</goal>
> </goals>
> </execution>
> </executions>
> <dependencies>
> <dependency>
> <groupId>org.aspectj</groupId>
> <artifactId>aspectjrt</artifactId>
> <version>${aspectj.version}</version>
> </dependency>
> <dependency>
> <artifactId>aspectjtools</artifactId>
> </dependency>
> </dependencies>
> <configuration>
> <source>1.5</source>
> <target>1.5</target>
> <encoding>utf-8</encoding>
> <verbose>true</verbose>
> <outxml>false</outxml>
> <showWeaveInfo>false</showWeaveInfo>
> <proceedOnError>true</proceedOnError>
> <aspectLibraries>
> <aspectLibrary>
> <groupId>org.springframework</groupId>
> <artifactId>spring-aspects</artifactId>
> </aspectLibrary>
> </aspectLibraries>
> <weaveDependencies>
> <weaveDependency>
> </weaveDependency>
> </weaveDependencies>
> </configuration>
> </plugin>
> <plugin>
> <groupId>org.apache.maven.plugins</groupId>
> <artifactId>maven-eclipse-plugin</artifactId>
> <version>2.6</version>
> <configuration>
> <downloadSources>true</downloadSources>
> <downloadJavadocs>true</downloadJavadocs>
> <projectnatures>
> <java.lang.String>org.eclipse.ajdt.ui.ajnature</java.lang.String >
> <java.lang.String>org.springframework.ide.eclipse.core.springnature </java.lang
> .String>
> <java.lang.String>org.eclipse.jdt.core.javanature</java.lang.String >
> </projectnatures>
> <buildcommands>
> <buildcommand>org.eclipse.ajdt.core.ajbuilder</buildcommand >
> </buildcommands>
> </configuration>
> </plugin>
> -Kaj :)
FUDForum. Page generated in 0.03526 seconds
