Home » Eclipse Projects » EclipseLink » uses a non-entity as target entity in the relationship attribute
uses a non-entity as target entity in the relationship attribute [message #707859] Tue, 02 August 2011 02:34 Go to next message
I am getting the following exception, which just started happening and I'm not sure of the problem:
Internal Exception: javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.1.1.v20100817-r8050): org.eclipse.persistence.exceptions.EntityManagerSetupException
Exception Description: Predeployment of PersistenceUnit [XXXcmsPU] failed.
Internal Exception: Exception [EclipseLink-7250] (Eclipse Persistence Services - 2.1.1.v20100817-r8050): org.eclipse.persistence.exceptions.ValidationException
Exception Description: [class com.XXX.data.Wwwwebsites] uses a non-entity [class com.XXX.data.WWWWebsitesCategories] as target entity in the relationship attribute [field categorytypeid].
	at org.eclipse.persistence.exceptions.PersistenceUnitLoadingException.exceptionSearchingForPersistenceResources(PersistenceUnitLoadingException.java:126)
	at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactory(PersistenceProvider.java:136)
	at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactory(PersistenceProvider.java:65)
	at javax.persistence.Persistence.createEntityManagerFactory(Persistence.java:110)
	at javax.persistence.Persistence.createEntityManagerFactory(Persistence.java:83)
This is the WWWWEBSITES class
@Entity
@Table(name = "WWWWEBSITES")
@NamedQueries(
        @NamedQuery(name = "Wwwwebsites.findAll", query = "SELECT w FROM Wwwwebsites w"),
        @NamedQuery(name = "Wwwwebsites.findBySiteownerid", query = "SELECT w FROM Wwwwebsites w WHERE w.siteownerid = :siteownerid"),
        @NamedQuery(name = "Wwwwebsites.findByWebsitetradingname", query = "SELECT w FROM Wwwwebsites w WHERE w.websitetradingname = :websitetradingname"),
        @NamedQuery(name = "Wwwwebsites.findByWebsiteprefereddomainname", query = "SELECT w FROM Wwwwebsites w WHERE w.websiteprefereddomainname = :websiteprefereddomainname"),
        @NamedQuery(name = "Wwwwebsites.findByMetakeywords", query = "SELECT w FROM Wwwwebsites w WHERE w.metakeywords = :metakeywords"),
        @NamedQuery(name = "Wwwwebsites.findByMetadescription", query = "SELECT w FROM Wwwwebsites w WHERE w.metadescription = :metadescription"),
        @NamedQuery(name = "Wwwwebsites.findByAnalyticssiteid", query = "SELECT w FROM Wwwwebsites w WHERE w.analyticssiteid = :analyticssiteid"),
        @NamedQuery(name = "Wwwwebsites.findByCarsalesdealerid", query = "SELECT w FROM Wwwwebsites w WHERE w.carsalesdealerid = :carsalesdealerid"),
        @NamedQuery(name = "Wwwwebsites.findByWebsitetypeid", query = "SELECT w FROM Wwwwebsites w WHERE w.websitetypeid = :websitetypeid"),
        @NamedQuery(name = "Wwwwebsites.findByPermitdeeplinking", query = "SELECT w FROM Wwwwebsites w WHERE w.permitdeeplinking = :permitdeeplinking"),
        @NamedQuery(name = "Wwwwebsites.findByWebsitestatus", query = "SELECT w FROM Wwwwebsites w WHERE w.websitestatus = :websitestatus"),
        @NamedQuery(name = "Wwwwebsites.findByWebsitestatuschangedate", query = "SELECT w FROM Wwwwebsites w WHERE w.websitestatuschangedate = :websitestatuschangedate"),
        @NamedQuery(name = "Wwwwebsites.findByWebsiteupdatedtimestamp", query = "SELECT w FROM Wwwwebsites w WHERE w.websiteupdatedtimestamp = :websiteupdatedtimestamp"),
        @NamedQuery(name = "Wwwwebsites.findByWebsiteprefereddomainnameandcountryid", query = "SELECT w FROM Wwwwebsites w WHERE w.websiteprefereddomainname = :websiteprefereddomainname AND w.countryid.sitecountryid = :sitecountryid"),
        @NamedQuery(name = "Wwwwebsites.findByHomefolder", query = "SELECT w FROM Wwwwebsites w WHERE w.websitehomefolder = :websitehomefolder"),
        @NamedQuery(name = "Wwwwebsites.findByDealerid", query = "SELECT w FROM Wwwwebsites w WHERE w.dealerid = :dealerid")
public class Wwwwebsites implements Serializable {
    private static final long serialVersionUID = 1L;
    @Id
    @Basic(optional = false)
    @Column(name = "Site_owner_id")
    private Integer siteownerid;
    @Column(name = "Website_trading_name")
    private String websitetradingname;
    @Column(name = "Website_prefered_domain_name")
    private String websiteprefereddomainname;
    @Column(name = "Meta_keywords")
    private String metakeywords;
    @Column(name = "Website_homefolder")
    private String websitehomefolder;
    @Column(name = "DealerID")
    private String dealerid;
    @Column(name = "Meta_description")
    private String metadescription;
    @Column(name = "Analytics_site_id")
    private String analyticssiteid;
    @Column(name = "Carsales_dealer_id")
    private String carsalesdealerid;
    @Column(name = "Website_type_id")
    private Integer websitetypeid;
    @Column(name = "Permit_deep_linking")
    private Integer permitdeeplinking;
    @Lob
    @Column(name = "Notes")
    private String notes;
    @Column(name = "Website_status")
    private Integer websitestatus;
    @Column(name = "Website_status_change_date")
    @Temporal(TemporalType.TIMESTAMP)
    private Date websitestatuschangedate;
    @Column(name = "Website_updated_time_stamp")
    private Date websiteupdatedtimestamp;
    @OneToMany(mappedBy = "siteownerid")
    private List<WWWWebsitesDomainNames> wWWWebsitesDomainNamesCollection;
    @JoinColumn(name = "Country_id", referencedColumnName = "Site_country_id")
    @ManyToOne
    private WWWWebsitesCountryType countryid;
    @OneToMany(cascade = CascadeType.ALL, mappedBy = "wwwwebsites")
    private List<WWWWebsitesLocationSequence> wWWWebsitesLocationSequenceCollection;
    private List<WWWWebsitesLogin> wWWWebsitesLoginCollection;
    @JoinColumn(name = "Category_type_id", referencedColumnName = "Category_type_id")
    @ManyToOne
    private WWWWebsitesCategories categorytypeid;
    public Wwwwebsites() {
    public Wwwwebsites(Integer siteownerid) {
        this.siteownerid = siteownerid;
    public Integer getSiteownerid() {
        return siteownerid;
    public void setSiteownerid(Integer siteownerid) {
    public String getWebsitetradingname() {
        return websitetradingname;
    public void setWebsitetradingname(String websitetradingname) {
        this.websitetradingname = websitetradingname;
    public String getWebsiteprefereddomainname() {
        return websiteprefereddomainname;
    public void setWebsiteprefereddomainname(String websiteprefereddomainname) {
        this.websiteprefereddomainname = websiteprefereddomainname;
    public String getMetakeywords() {
        return metakeywords;
    public void setMetakeywords(String metakeywords) {
        this.metakeywords = metakeywords;
    public String getWebsitehomefolder() {
        return websitehomefolder;
    public void setWebsitehomefolder(String hot) {
        this.websitehomefolder = hot;
    public String getDealerID() {
        return dealerid;
    public void setDealerID(String hot) {
        this.dealerid = hot;
    public String getMetadescription() {
        return metadescription;
    public void setMetadescription(String metadescription) {
        this.metadescription = metadescription;
    public String getAnalyticssiteid() {
        return analyticssiteid;
    public void setAnalyticssiteid(String analyticssiteid) {
        this.analyticssiteid = analyticssiteid;
    public String getCarsalesdealerid() {
        return carsalesdealerid;
    public void setCarsalesdealerid(String carsalesdealerid) {
        this.carsalesdealerid = carsalesdealerid;
    public Integer getWebsitetypeid() {
        return websitetypeid;
    public void setWebsitetypeid(Integer websitetypeid) {
        this.websitetypeid = websitetypeid;
    public Integer getPermitdeeplinking() {
        return permitdeeplinking;
    public void setPermitdeeplinking(Integer permitdeeplinking) {
        this.permitdeeplinking = permitdeeplinking;
    public String getNotes() {
        return notes;
    public void setNotes(String notes) {
        this.notes = notes;
    public Integer getWebsitestatus() {
        return websitestatus;
    public void setWebsitestatus(Integer websitestatus) {
        this.websitestatus = websitestatus;
    public Date getWebsitestatuschangedate() {
        return websitestatuschangedate;
    public void setWebsitestatuschangedate(Date websitestatuschangedate) {
        this.websitestatuschangedate = websitestatuschangedate;
    public Date getWebsiteupdatedtimestamp() {
        return websiteupdatedtimestamp;
    public void setWebsiteupdatedtimestamp(Date websiteupdatedtimestamp) {
        this.websiteupdatedtimestamp = websiteupdatedtimestamp;
    public List<WWWWebsitesDomainNames> getWWWWebsitesDomainNamesCollection() {
        return wWWWebsitesDomainNamesCollection;
    public void setWWWWebsitesDomainNamesCollection(List<WWWWebsitesDomainNames> wWWWebsitesDomainNamesCollection) {
        this.wWWWebsitesDomainNamesCollection = wWWWebsitesDomainNamesCollection;
    public WWWWebsitesCountryType getCountryid() {
        return countryid;
    public void setCountryid(WWWWebsitesCountryType countryid) {
        this.countryid = countryid;
    public List<WWWWebsitesLocationSequence> getWWWWebsitesLocationSequenceCollection() {
        return wWWWebsitesLocationSequenceCollection;
    public void setWWWWebsitesLocationSequenceCollection(List<WWWWebsitesLocationSequence> wWWWebsitesLocationSequenceCollection) {
        this.wWWWebsitesLocationSequenceCollection = wWWWebsitesLocationSequenceCollection;
    public List<WWWWebsitesLogin> getWWWWebsitesLoginCollection() {
        return wWWWebsitesLoginCollection;
    public void setWWWWebsitesLoginCollection(List<WWWWebsitesLogin> wWWWebsitesLoginCollection) {
        this.wWWWebsitesLoginCollection = wWWWebsitesLoginCollection;
    public WWWWebsitesCategories getCategorytypeid() {
        return categorytypeid;
    public void setCategorytypeid(WWWWebsitesCategories categorytypeid) {
        this.categorytypeid = categorytypeid;
    public int hashCode() {
        int hash = 0;
        hash += (siteownerid != null ? siteownerid.hashCode() : 0);
        return hash;
    public boolean equals(Object object) {
        // TODO: Warning - this method won't work in the case the id fields are not set
        if (!(object instanceof Wwwwebsites)) {
            return false;
        Wwwwebsites other = (Wwwwebsites) object;
        if ((this.siteownerid == null && other.siteownerid != null) || (this.siteownerid != null && !this.siteownerid.equals(other.siteownerid))) {
            return false;
        return true;
    public String toString() {
        return "com.XXX.data.Wwwwebsites[siteownerid=" + siteownerid + "]";
This is the WWWWebsitesCategories class:
@Entity
@Table(name = "WWWWebsites_Categories")
@NamedQueries({@NamedQuery(name = "WWWWebsitesCategories.findAll", query = "SELECT w FROM WWWWebsitesCategories w"), @NamedQuery(name = "WWWWebsitesCategories.findByCategorytypeid", query = "SELECT w FROM WWWWebsitesCategories w WHERE w.categorytypeid = :categorytypeid"), @NamedQuery(name = "WWWWebsitesCategories.findByCategorytypename", query = "SELECT w FROM WWWWebsitesCategories w WHERE w.categorytypename = :categorytypename"), @NamedQuery(name = "WWWWebsitesCategories.findByCategorytypestatus", query = "SELECT w FROM WWWWebsitesCategories w WHERE w.categorytypestatus = :categorytypestatus")})
public class WWWWebsitesCategories implements Serializable {
    @Id
    @Column(name = "Category_type_id")
    private Integer categorytypeid;
    @Column(name = "Category_type_name")
    private String categorytypename;
    @Column(name = "Category_type_status")
    private Integer categorytypestatus;
    @OneToMany(mappedBy = "categorytypeid")
    private List<Wwwwebsites> wwwwebsitesList;
    public WWWWebsitesCategories() {
    public WWWWebsitesCategories(Integer categorytypeid) {
    public Integer getCategorytypeid() {
    public void setCategorytypeid(Integer categorytypeid) {
    public String getCategorytypename() {
        return categorytypename;
    public void setCategorytypename(String categorytypename) {
        this.categorytypename = categorytypename;
    public Integer getCategorytypestatus() {
        return categorytypestatus;
    public void setCategorytypestatus(Integer categorytypestatus) {
        this.categorytypestatus = categorytypestatus;
    public List<Wwwwebsites> getWwwwebsitesList() {
        return wwwwebsitesList;
    public void setWwwwebsitesList(List<Wwwwebsites> wwwwebsitesList) {
        this.wwwwebsitesList = wwwwebsitesList;
        int hash = 0;
        hash += (categorytypeid != null ? categorytypeid.hashCode() : 0);
        return hash;
        if (!(object instanceof WWWWebsitesCategories)) {
            return false;
        WWWWebsitesCategories other = (WWWWebsitesCategories) object;
        if ((this.categorytypeid == null && other.categorytypeid != null) || (this.categorytypeid != null && !this.categorytypeid.equals(other.categorytypeid))) {
            return false;
        return true;
        return "com.XXX.data.WWWWebsitesCategories[categorytypeid=" + categorytypeid + "]";
What have I done wrong?
Re: uses a non-entity as target entity in the relationship attribute [message #708152 is a reply to message #707859] Tue, 02 August 2011 10:09 Go to previous messageGo to next message
What did you change to make it start happening?
What is your persistence.xml, have you listed all of the class? Are all of your classes in your jar, did they all compile and deploy correctly?
(no subject) [message #708161 is a reply to message #707859] Tue, 02 August 2011 10:09 Go to previous messageGo to next message
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
Re: (no subject) [message #708540 is a reply to message #708152] Tue, 02 August 2011 19:09 Go to previous messageGo to next message
This is what my persistence.xml looks like. There is nothing that I can remember doing to cause this. Yes, I have all my classes listed, they are in my jar and they compiled properly.
<persistence version="1.0" xmlns="http://java.sun.com/xml/ns/persistence" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_1_0.xsd">
  <persistence-unit name="XXXcmsPU" transaction-type="RESOURCE_LOCAL">
    <provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
    <class>com.xxx.data.Wwwwebsites</class>
	<class>com.xxx.data.WWWWebsitesCategories</class>
    <properties>
      <property name="javax.persistence.jdbc.password" value="XXXX"/>
      <property name="javax.persistence.jdbc.user" value="XXXX"/>
      <property name="javax.persistence.jdbc.driver" value="net.sourceforge.jtds.jdbc.Driver"/>
      <property name="javax.persistence.jdbc.url" value="jdbc:jtds:sqlserver://XXXXXXXXXXXXXX"/>
	  <property name="eclipselink.cache.shared.default" value="false"/>
	  <property name="eclipselink.allow-zero-id" value="true"/>
    </properties>
  </persistence-unit>
</persistence>
Re: (no subject) [message #713494 is a reply to message #708540] Mon, 08 August 2011 10:39 Go to previous message
What environment are you running in? (Glassfish, JEE, Tomcat, JSE, Spring, OSGi, etc?)
(no subject) [message #713520 is a reply to message #708540] Mon, 08 August 2011 10:39 Go to previous message
Previous Topic:(no subject)
Next Topic:JPA2: how access entity name for projection query
Current Time: Fri Nov 07 04:42:07 EST 2025
Powered by FUDForum. Page generated in 0.03697 seconds
