Home » Archived » M2M (model-to-model transformation) » [QVTOM] Deferred resolves
[QVTOM] Deferred resolves [message #73572] Mon, 28 January 2008 07:20 Go to next message
Hi all,
The QVT specification defines an interesting concept called deferred resolve
or late resolve.
Resolution is done after the transformation is completely executed and the
result is stored.
My question is about this storage of the result, the spec says the following
about the execution semantics: A null value is returned instead. In the
meantime, the execution engine stores the following information for the
future variable: the source object, the function representing the filtering
expression and the property or the variable reference to be assigned. This
information is sufficient to allow the assignment to be performed later -
more precisely
Re: [QVTOM] Deferred resolves [message #73592 is a reply to message #73572] Mon, 28 January 2008 10:04 Go to previous messageGo to next message
Hi Alfons,
In principal, you could use late resolve inside any ocl expression as it's
just an expression
of a given type, but this would not make much sense. It just results in
null during normal execution
time and if not used in assignment, there is no place to store the result
of deferred evaluation.
The current implementation supports deferred assignment only with
properties,
as the execution semantics is clear in this case.
Though, if assigning to variables, perhaps, one could assign intermediate
results there and use it in
subsequent deferred assignments, in case that these assignments have that
variable in its scope.
However, the QVT spec is not very clear about this and the QVTO compiler
reports a 'warn' now, saying
you should use late resolve with property assignment to get it assigned at
deferred time.
Radek
On Mon, 28 Jan 2008 13:20:48 +0100, Alfons Laarman
<a.w.laarman@student.utwente.nl> wrote:
> Hi all,
> resolve
> or late resolve.
> the
> result is stored.
> following
> filtering
> This
> more precisely ñ at the end of the execution of the entry operation of
> the
> transformation.
> What use it to store the result to a variable after the transformation
> execution. Can somebody explain this to me?
> Also can a deferred resolve occur inside an ocl expression? From the
> above
> information i can somehow deduce that it should not, otherwise we didnt
> store enough information to execute the ocl expression after the
> execution.
> But this is not explicitely stated.
> Best regards,
> Alfons
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: [QVTOM] Deferred resolves [message #73666 is a reply to message #73592] Mon, 28 January 2008 14:10 Go to previous message
"Radek Dvorak" <radek.dvorak@borland.com> schreef in bericht
news:op.t5naubwehj1a1g@czprl-rdvorak2.emea.borl.net...
> properties,
> deferred time.
Thanks for your answer, Radek.
It just would not make sense to implement it with variables. It will make
QVTOM partly declarative, and the specs claim it is completely
imperative....
Alfons
Previous Topic:problem with programmatically transformation of multiple-file models
Next Topic:ATL - Problem with Enum transformation
Current Time: Sat Nov 08 22:30:00 EST 2025
Powered by FUDForum. Page generated in 0.24564 seconds
