[Teneo] Is it possible to modify the value of an EAttribute that is a PK? [message #73528] |
Sun, 04 March 2007 07:08 |
Originally posted by: eclipsenews.cs-guy.com
I have an EClass with an EAttribute marked as an ID attribute. It has come
up that I need to change the value of the ID attribute of an already
persisted instance. However, it seems that after the code changes the value
and saves the resource, the value of the ID on that instance has not changed
in the DB, even though other edits made to the same object were correctly
updated.
Does Teneo disallow chaning the PK of an object once it is saved? Should
it? I am wondering whether I might be doing something wrong, or this
behavior is by design, or I should submit a bug. I am currently using Teneo
v0.7.5.v200701041633.
Chris
Re: [Teneo] Is it possible to modify the value of an EAttribute that is a PK? [message #73634 is a reply to message #73528] |
Mon, 05 March 2007 17:00 |
Chris,
Apparently Hibernate does not allow changing the pk (new for me to):
http://forum.hibernate.org/viewtopic.php?t=965186&highli ght=update+primary+key
For jpox I am not sure but I would think that they do not support changing the pk either (they did
not a few years ago).
I am not sure if you can for your case but at Hibernate they advice to always use a generated id
(like a sequence number). Overall generated (numeric) id's are easier to handle. With as main
disadvantage that import/export of data is more complex.
It all depends on your case ofcourse.
gr. Martin
> updated.
> Chris
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Is it possible to modify the value of an EAttribute that is a PK? [message #603111 is a reply to message #73528] |
Chris,
gr. Martin
> updated.
> Chris
The Netherlands
FUDForum. Page generated in 0.03540 seconds
