| XML Catalog and Validation [message #73454] |
Sat, 12 February 2005 05:05  |
I played with the XML Catalog facility of the latest milestone
release of WTP based on the "XMLExamples" project. I simply
followed the tutorial presented at
http://www.eclipse.org/webtools/testtutorials/M2/xml/XMLCata logTutorial.html
I follow the instructions and can use tag completion (typing "<"
and waiting for a list of available tag names). However, I am not
able to validate the document. The DTD example gives a "File not
found: ..." problem and the XSD examples tells me "Cannot find
declaration of element 'c:Catalogue'".
Franz
| Re: XML Catalog and Validation [message #77506 is a reply to message #73824] |
Sat, 26 February 2005 16:30  |
Hello.
rmah@ca.ibm.com (Richard Mah) writes:
> I ran through the tutorial specified by the link with M2 and it worked fine for
> me. Did you use the export and import functionality? There is a note in the
> tutorial which talked about a bug with exporting the catalog.
> If you're still having problems, please specify the steps you went through to
> encounter the problem.
Since my last post, I found another cause that actually gave me
reason to post my original message. The project I wanted the XML
catalog to use for contained a space in its name. In order to
reproduce this situation, Once again, it is time to run through
the tutorial. This time, name the example project "XML Examples".
When the tutorial instructs you to validate the XML document, it
will fail.
This behaviour applies at least for the last milestone release
(M3) of the web tools platform.
Franz.
FUDForum. Page generated in 0.04336 seconds
