Home » Eclipse Projects » Equinox » Bundle ActivatorClass not found in tomcat / servlet-bridge
Bundle ActivatorClass not found in tomcat / servlet-bridge [message #73344] Tue, 19 September 2006 09:48 Go to next message
Originally posted by: ridcully560.yahoo.com
Hallo,
I finally managed to bring my plugins to the tomcat... at least I'm able
to let them run under the bride.war-webapp in the osgi-console. But some
of the plugins can't be started. There is an Exception telling me, that
the Activatorclass can not be found.
BundleException -> ClassNotFoundException
I can see no difference from that project to another one where the
activation is no problem.
osgi>ss in Eclipse tell me, that next to my plugins just the
system.bundle is loaded and active.
osgi>ss unter the comcat lists:
active system.bundle
active org.eclipse.equinox.common
active org.eclipse.update.configurator
active org.eclipse.equinox.servlet.bridge
active org.eclipse.equinox.http.registry
resolved MyPlugin...
active org.eclipse.equinox.registry
resolved org.eclipse.equinox.servlet.bridge.extensionbundle
resolved org.eclipse.osgi.services
Johannes
Re: Bundle ActivatorClass not found in tomcat / servlet-bridge [message #73420 is a reply to message #73344] Wed, 20 September 2006 04:48 Go to previous message
OK, I think I founde the reason: The export-wizard seems to put the
class-files inside the jar-file not just into the "package/..." but
instedt to "/build/classes/package/..." That's the standart output
folder from the main-app. In the little plugin-projects I created, the
outputfolder is just "/bin" and there it works perfectly to get the
class-files in the jar files to the "/package" and not to "/bin/package".
Another thing: Some off the classes need javax.-packages to compile. I
think that those are the ones that are added to the project via the
tomcat-server-libs inside eclipse. Although I added those .jar-files
(for example jsp-api.jar) to the lib-folder in the WEB-INF directory
this doesn't seem to work.
Johannes
Johannes schrieb:
> Hallo,
> Johannes
Previous Topic:How to get ServiceReference from service instance?
Next Topic:demo application integrating JSP/JSTL, Struts...
Current Time: Tue Aug 19 10:46:41 EDT 2025
Powered by FUDForum. Page generated in 0.26938 seconds
