[JET] Select (with dynamic variable) difference from v0.8.1 to v1.1.1 error No Children [message #705932] |
Sat, 30 July 2011 15:50 |
Stu Plu Messages: 44 Registered: July 2009 |
Member |
Been a while since I've used JET and taking a working template (that worked with JET version 0.8.1) it doesn't work with JET v1.1.1.
Version 0.8:-
<c:load url="{$org.eclipse.jet.resource.project.name}{$directories}/{$compoundResourceName}.mygmf" var="{$compoundResourceName}" urlContext="workspace" type="mygmf_diagram"/>
<c:dump select="${$compoundResourceName}/*"/>
I added the new loader (as file is a gmf/emf file)
so my Version 1.1.1:-
<c:load url="{$org.eclipse.jet.resource.project.name}{$directories}/{$compoundResourceName}.mygmf" var="{$compoundResourceName}" urlContext="workspace" type="mygmf_diagram" loader="org.eclipse.jet.emf"/>
But I get the following error in the dump:-
Status ERROR: org.eclipse.jet code=0 Errors occurred during execution null children=[Status ERROR: org.eclips
e.jet code=0 Could not find value for attribute "ChangeResult/*" Could not find value for attribute "ChangeResult/*"]
If I hard code the variable name like so:-
<c:dump select="$ChangeResult/*" format="true" entities="true"/>
Everything is ok !!
Been a bit stuck on this for a while any help
[Updated on: Mon, 01 August 2011 05:17] Report message to a moderator
FUDForum. Page generated in 0.03397 seconds
