problem with programmatically transformation of multiple-file models [message #73193] |
Wed, 23 January 2008 12:14 |
Originally posted by: guo.mci.sdu.dk
Hi all,
I am running the atl in my Java code using the command line code from
dennis wagelaar. I get succesfully a programmatically transformation on
the Family and Person example.
But it does not work on our models.I got the message from the command
line code that "The EMF4ATL version used does not support referenced
extents (multiple-file models)"
In our case, we have three metamodels in Ecore:
"MooreStatemachine.ecore", "MealyStatemachine.ecore" and "Action.ecore".
The metamodel in "Action.ecore" in referenced by both
"MooreStatemachine.ecore" and "MealyStatemachine.ecore".
In the side of model, we have models "action1.action", "action2.action"
which are used by model "my.moorestatemachine". We want to transform
this "my.moorestatemachine" model (with MooreStatemachine.ecore as
metamodel) to the model with MealyStatemachine.ecore as metamodel. And
both state machine models share the Action models.
We can get this transformation done when use the "Run" in Eclipse, which
means that the ATL can deal with the external referenced objects (both
metamodel and model).
Why cannot we get this done in Java code? Is it possible to transform
mutil-file models by writting Java code?
Yu Guo
Here I list the command I use to invoke the command line tool, and the
message I got:
command line:
--trans
" file:E:\\eclipse-SDK-3.3.1.1-win32\\workspace\\StatemachineT ransform2\\MooreToMealy.asm "
--in
IN=" file:E:\\eclipse-SDK-3.3.1.1-win32\\workspace\\StatemachineT ransform2\\test\\My.moorestatemachine "
MooreStatemachine=" file:E:\\eclipse-SDK-3.3.1.1-win32\\workspace\\StatemachineM odels\\model\\MooreStatemachine.ecore "
EMF
--out
OUT=" file:E:\\eclipse-SDK-3.3.1.1-win32\\workspace\\StatemachineT ransform2\\test\\result.txt "
MealyStatemachine=" file:E:\\eclipse-SDK-3.3.1.1-win32\\workspace\\StatemachineM odels\\model\\MealyStatemachine.ecore "
EMF
message:
--trans
--in
IN=file:E:\\eclipse-SDK-3.3.1.1-win32\\workspace\\Statemachi neTransform2\\test\\My.moorestatemachine
MooreStatemachine=file:E:\\eclipse-SDK-3.3.1.1-win32\\worksp ace\\StatemachineModels\\model\\MooreStatemachine.ecore
EMF Input metamodel MooreStatemachine @
org.eclipse.m2m.atl.engine.AtlEMFModelHandler@1f3aa07 not yet loaded -
loading from
2008-1-23 4:43:37 org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel
addReferencedExtentsFor
warning: Resource for org.eclipse.emf.ecore.impl.EClassImpl@196c1b0
(eProxyURI: StatemachineAction.ecore#//Action) is null; cannot be
referenced
referenced Referenced extents:
[org.eclipse.emf.ecore.xmi.impl.EcoreResourceFactoryImpl$1@1e13d52
uri='http://www.eclipse.org/emf/2002/Ecore']
Using input metamodel MooreStatemachine : MOF
Loading input model IN from
2008-1-23 4:43:38 org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel
loadASMEMFModel
严重: null
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFe atureType(XMLHandler.java:2022)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:1900)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHa ndler.java:131)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1705)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:974)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:953)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:684)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:167)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.scanStartElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.next(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
at
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
at
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1354)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1155)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:256)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:271)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:398)
at
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFMo del(ASMEMFModel.java:327)
at
org.eclipse.m2m.atl.engine.AtlEMFModelHandler.loadModel(AtlE MFModelHandler.java:235)
at dk.sdu.mci.seg.atl.commandline.Main.loadModel(Main.java:97)
at dk.sdu.mci.seg.atl.commandline.Main.addInputModel(Main.java: 215)
at dk.sdu.mci.seg.atl.commandline.Main.parseArgs(Main.java:144)
at dk.sdu.mci.seg.atl.commandline.Main.main(Main.java:72)
java.lang.NullPointerExceptionjava.lang.NullPointerException
at dk.sdu.mci.seg.atl.commandline.Main.addInputModel(Main.java: 216)
The EMF4ATL version used does not support referenced extents
Usage: <this program> --trans <transformation url> [--in <id>=<model>
<id>=<metamodel> <MDR|EMF>] [--out <id>=<model>
<id>=<metamodel> <MDR|EMF>] [--lib <id>=<library url>] [--superimpose
<transformation url>] --next --trans ...
[ATL] Re: problem with programmatically transformation of multiple-file models [message #73553 is a reply to message #73193] |
Mon, 28 January 2008 11:11 |
William Piers Messages: 301 Registered: July 2009 |
--------------060301050902020802060903
Could you please use the [ATL] prefix in your subjects ? Thanks in advance.
Concerning your problem, the command line tool may not be up to date, so
it doesn't embed the same version EMF4ATL version than you use in Eclipse.
We are currently working on a general solution for programmatic launch /
command line use , in order to avoid that compatibility issues.
But at this time, the best thing you have to do is to rebuild your own
command line tool (especially libraries) using the last ATL code.
William
Yu Guo a écrit :
> Hi all,
> Regards,
> Yu Guo
> message I got:
> command line:
> --trans
> --in
> EMF
> --out
> EMF
> message:
> --trans
> --in
> loading from
> referenced
> loadASMEMFModel
> 严重: null
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
name="william_piers.vcf"
filename="william_piers.vcf"
YmVnaW46dmNhcmQNCmZuOldpbGxpYW0gUGllcnMNCm46UGllcnM7V2lsbGlh bQ0Kb3JnOk9i
ZW8NCmFkcjoyIHJ1ZSBSb2JlcnQgU2NodW1hbm47O2xvdCAyNDtOQU5URVM7 OzQ0NDA4O0Zy
YW5jZQ0KZW1haWw7aW50ZXJuZXQ6d2lsbGlhbS5waWVyc0BvYmVvLmZyDQp0 aXRsZTpNREEg
Q29uc3VsdGFudA0KdGVsO3dvcms6KzMzICgwKTIgNTEgMTMgNTEgODINCnRl bDtjZWxsOisz
MyAoMCk2IDIwIDMxIDc1IDk4DQp1cmw6aHR0cDovL3d3dy5vYmVvLmZyDQp2 ZXJzaW9uOjIu
MQ0KZW5kOnZjYXJkDQoNCg==
--------------060301050902020802060903--
FUDForum. Page generated in 0.02972 seconds
