Home » Language IDEs » Java Development Tools (JDT) » Newbie question on JUnit
Newbie question on JUnit [message #73190] Sat, 05 July 2003 14:17 Go to next message
Originally posted by: jcasey.ccs.neu.edu
In the "Eclipse in Action" book, I'm trying out
the Persistence project: the first use of JUnit.
For the project, I go to Properties -> Java Build Path ->
Add Variable, and there I add JUNIT (and its file) and
JUNIT_SRC (and its file), and then associate the source to JUNIT.
Then I create the class FilePersistenceServices.
When I go to the JUnit wizard, I try to create a TestCase
and I get an error:
"JUnit is not on the project's build path. Add the junit.jar to the
project's build path."
Has anyone else seen this problem? I'd appreciate any help.
Hardware: SunBlade 100
Operating system: Solaris
Eclipse: 2.1.0
Re: Newbie question on JUnit [message #73685 is a reply to message #73190] Mon, 07 July 2003 14:21 Go to previous message
> and I get an error:
You defined a variable to point to JUNIT, but did not tell Eclipse to
use that value on your Project's build classpath. Right-click the
Project, choose Properties > Java Build Path > Libraries. There you will
find an "Add Variable..." button which allows you to include the value
of the JUNIT variable on that Project's classpath.
HTH,
Eric
Eric Rizzo
Software Architect
Jibe, Inc.
http://www.jibeinc.com
Previous Topic:Package scope
Next Topic:Launching a configuration
Current Time: Mon Sep 22 19:35:59 EDT 2025
Powered by FUDForum. Page generated in 0.25298 seconds
