Re: Tutorial for setting up PDT + XDebug [message #73229 is a reply to message #73194] |
Thu, 12 June 2008 16:24 |
Originally posted by: robj1_nospam.robsnotebook.com
I would love to add it to the Wiki, but when I try to create an account,
it gives me an error:
Login error:
Incorrect password entered. Please try again.
I entered in the same password in both edit boxes, so I don't understand
why it does that.
Re: Tutorial for setting up PDT + XDebug [message #73399 is a reply to message #73081] |
Fri, 13 June 2008 14:01 |
Originally posted by: user.domain.invalid
> Any comments on it are greatly appreciated!
One thing I would recommend - don't tell people to enable the profiler by
default... set this to 0, not 1:
xdebug.profiler_enable=0
The profiler will produce very large data files very fast. When I first learned
about this xdebug tool, I got hundreds of megabytes worth of data over a short
time and I didn't know where all these cachegrind files were coming from! :)
They come from the profiler.
Explain to people what this setting is and when they would want to set it to 1
(which is when they want to use a tool like KCacheGrind to find bottlenecks in
their code)
Rob Bresalier wrote:
> Hi:
> I created a step by step tutorial for setting up PDT to work with
> XDebug, you may find it here:
> http://robsnotebook.com/php_debugger_pdt_xdebug
> Rob
Re: Tutorial for setting up PDT + XDebug [message #74053 is a reply to message #73751] |
Fri, 27 June 2008 17:35 |
Hi Shaba1:
I don't read this newsgroup that often, so didn't see your message until
now. If you want faster responses from me, its better to post comments
on my tutorial page. Here's my responses to your questions:
> #1 try get a hosting site that does not have a floating advert that you
> view cannot close. I had to resize the window in order to get the advert
> off your text.
I've tested this on IE and Firefox, and there shouldn't be a floating
advert, its position should be fixed on the page. What OS and browser
are you using? I can fix this problem, but I wasn't aware of it until
now, nobody else has said anything about that.
> #2 put the screen shots in the man article even if they are in a smaller
> size the the actual graphic. It was disconcerting to have to go back and
> forth from your tutorial text to the screen shots page just to make sure
> what you were discribing was what I was seeing on my screen.
I can do that, but it is more work for me. Maybe someday.
> Well I follows your tute and I must say it got me farther then any other
> tutorial I have ever read. But when I finally press the debug button on
> the new configuration screen I got a browser window that said "No Input
> file specified" and that was it just that. Not even any html or php code
> in the browsers source window. Any Ideas?
I suspect that you didn't specify the file properly in step 7.i.5, in
the "Run->Open Debug Dialog" window.
Rob
FUDForum. Page generated in 0.04337 seconds
