Home » Modeling » TMF (Xtext) » Local Scope and Shadowing
Local Scope and Shadowing [message #705343] Fri, 29 July 2011 14:55 Go to next message
Hello, I've been reading other posts and blogs about local scoping but I don't getting, I think I am missing something.
Here is my example:
Model:
	A |
	R
A:
	'A' name=ID
R:
	'R' name=ID
	objectReference=ObjectReference
	innerObject=InnerObject
InnerObject:
	'innerObject' name=STRING
ObjectReference:
	object=[ecore::EObject]
My scope provider, where I filter objects by they file extension:
public IScope scope_ObjectReference_object(EObject i, EReference r) {
		return new org.eclipse.xtext.scoping.impl.FilteringScope(delegateGetScope(i, r),new Predicate<IEObjectDescription>() {
			public boolean apply(IEObjectDescription input) {
				return input!=null && input.getEObjectURI()!=null &&  input.getEObjectURI().fileExtension()!=null &&
						(input.getEObjectURI().fileExtension().equals("a")
Now, I want to write this code:
file: R.r
R myr
mya
innerObject 'mya'
file: mya.a
A mya
, but as expected, innerObject 'mya' shadows the object in mya.a, so I get "Couldn't resolve reference to EObject 'mya'".
How should I do this?
Thank you very much for your help and advices.
PD: I noted the filtering does not work since the local object "mya" shadows the global object before the call to the scope_ObjectReference_object method.
[Updated on: Fri, 29 July 2011 14:59] by Moderator
Re: Local Scope and Shadowing [message #705361 is a reply to message #705343] Fri, 29 July 2011 15:31 Go to previous messageGo to next message
Hi, if you want to ref only stuff of yourdsl why don't you state this in the grammar? why referening an eobject?
~Christian
Re: Local Scope and Shadowing [message #705365 is a reply to message #705361] Fri, 29 July 2011 15:42 Go to previous messageGo to next message
Hi, Christian.
How can I do that if I have different types of eobjects I could reference there? For example, if I try:
ObjectReference:
	object= ([A]|[B])
I get " Decision can match input such as "'innerObject'" using multiple alternatives: 1, 2"
Re: Local Scope and Shadowing [message #705386 is a reply to message #705365] Fri, 29 July 2011 16:14 Go to previous messageGo to next message
if you have control over the types: create a common supertype e.g. by adding a rule
AorB : A | B; to your a dsl.
~Christian
Re: Local Scope and Shadowing [message #705426 is a reply to message #705386] Fri, 29 July 2011 17:27 Go to previous message
I guess that would be the easier and less error prone way to go, so the right way.
Thank you very much.
Previous Topic:Creating grammar mixin
Next Topic:[Xtext2.0] Validation
Current Time: Fri Nov 07 17:23:25 EST 2025
Powered by FUDForum. Page generated in 0.04104 seconds
