Home » Modeling » TMF (Xtext) » [Xtend 2] Access dynamically generated EPackages from Xtend 2 files
[Xtend 2] Access dynamically generated EPackages from Xtend 2 files [message #705126] Fri, 29 July 2011 09:18
I developed a tool that creates various EPackages dynamically and stores them in the EPackage.Registry. Using Xtend 1, I was able to work with models that are instances of the EPackages having nice editor support in Xtend 1.
Is this possible as well in Xtend 2, without generating the Java API for the EPackages? How does a corresponding import statement look like in Xtend 2? In Xtend 1, it was just "import mydsl;"
I hope that it is as simple in Xtend 2, and I just have not figured it out yet ...
Thank you very much in advance,
Christoph
[Updated on: Fri, 29 July 2011 09:19] by Moderator
Previous Topic:Re: Problem generating edit/editor
Next Topic:Re: [Xtend 2] Access dynamically generated EPackages from Xtend 2 files
Current Time: Fri Nov 07 17:23:27 EST 2025
Powered by FUDForum. Page generated in 0.03135 seconds
