Re: How to visualize elements programatically [message #713468 is a reply to message #703969] |
Mon, 08 August 2011 14:01 |
Vincent Messages: 35 Registered: December 2009 |
Member |
Here is a part of a class which should help you.
You may perform some refactoring, but all you need should be there.
Take care to respect the copyright.
* Copyright (c) 2010 Atos Origin.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Vincent Hemery (Atos Origin}) {vincent.hemery@atosorigin.com} - Initial API and implementation
package org.topcased.requirement.bundle.papyrus.services;
import java.util.ArrayList;
import java.util.Collection;
import java.util.HashMap;
import java.util.HashSet;
import java.util.List;
import java.util.Map;
import java.util.Map.Entry;
import java.util.Set;
import org.eclipse.core.runtime.IStatus;
import org.eclipse.core.runtime.Status;
import org.eclipse.emf.common.util.WrappedException;
import org.eclipse.emf.ecore.EClassifier;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.edit.domain.EditingDomain;
import org.eclipse.emf.transaction.RollbackException;
import org.eclipse.gef.EditPart;
import org.eclipse.gef.EditPartViewer;
import org.eclipse.gef.editparts.AbstractGraphicalEditPart;
import org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditPart;
import org.eclipse.gmf.runtime.diagram.ui.editparts.DiagramEditPart;
import org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart;
import org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor;
import org.eclipse.gmf.runtime.diagram.ui.parts.IDiagramGraphicalViewer;
import org.eclipse.gmf.runtime.notation.Diagram;
import org.eclipse.gmf.runtime.notation.View;
import org.eclipse.osgi.util.NLS;
import org.eclipse.papyrus.core.editor.IMultiDiagramEditor;
import org.eclipse.papyrus.core.modelsetquery.ModelSetQuery;
import org.eclipse.papyrus.core.utils.EditorUtils;
import org.eclipse.papyrus.diagram.common.util.DiagramEditPartsUtil;
import org.eclipse.papyrus.resource.IModel;
import org.eclipse.papyrus.resource.ModelSet;
import org.eclipse.papyrus.resource.uml.UmlModel;
import org.eclipse.papyrus.sasheditor.contentprovider.IPageMngr;
import org.eclipse.papyrus.sasheditor.editor.AbstractMultiPageSashEditor;
import org.eclipse.papyrus.sasheditor.editor.ISashWindowsContainer;
import org.eclipse.ui.IEditorPart;
import org.topcased.requirement.bundle.papyrus.Activator;
import org.topcased.requirement.bundle.papyrus.internal.Messages;
import org.topcased.requirement.bundle.papyrus.resource.RequirementModel;
import org.topcased.requirement.core.extensions.IEditorServices;
import org.topcased.requirement.core.views.AbstractRequirementPage;
* This class provides services for using requirements with the papyrus core editor. It is intended to be used only by
* extension point org.topcased.requirement.core.supportingEditors.
* @author vhemery
public class PapyrusEditorServices implements IEditorServices
* Get the currently active Papyrus diagram editor.
* @return the editor part or null.
public IEditorPart getActiveEditor()
return EditorUtils.getMultiDiagramEditor();
* Sets the selection state for the editor to reveal the position of the given EObject.<br>
* It searches in the different diagrams the occurrences of the EObject and ask the user to select the destination
* if the given EObject has several graphical representation.
* @param editor the editor or null for currently active one
* @param listOfEObjects list of eobjects to select
* @param openDiagramIfNeeded if true, when the object is not in current active diagram, a representing diagram will
* open
public void gotoEObjects(IEditorPart editor, List<EObject> listOfEObjects, boolean openDiagramIfNeeded)
if (editor == null)
editor = getActiveEditor();
if (editor instanceof IMultiDiagramEditor)
List<EditPart> editPartsToSelect = new ArrayList<EditPart>(listOfEObjects.size());
// find appropriate viewer and edit parts to select
EditPartViewer currentViewer = getGraphicalViewer(editor);
Map< ? , ? > currentRegistry = currentViewer.getEditPartRegistry();
if (openDiagramIfNeeded)
* Reference diagrams which represent these elements to know the best one (with most represented
* elements)
Map<Diagram, Integer> numberOfRepresentedElementsByDiagram = new HashMap<Diagram, Integer>();
for (EObject toSelect : listOfEObjects)
Set<Diagram> diagramsRepresentingThisObject = new HashSet<Diagram>();
List< ? > views = DiagramEditPartsUtil.getEObjectViews(toSelect);
for (Object view : views)
if (view instanceof View && !(view instanceof Diagram))
Diagram diagram = ((View) view).getDiagram();
// test if a representation has already been counted for this diagram
if (!diagramsRepresentingThisObject.contains(diagram))
// the element is represented in this diagram
diagramsRepresentingThisObject.add(diagram);
if (!numberOfRepresentedElementsByDiagram.containsKey(diagram))
numberOfRepresentedElementsByDiagram.put(diagram, 0);
Integer num = numberOfRepresentedElementsByDiagram.get(diagram);
numberOfRepresentedElementsByDiagram.put(diagram, num + 1);
// find diagram where the largest number of elements are available
Diagram bestDiagram = null;
int numberOfRepresented = 0;
for (Entry<Diagram, Integer> entry : numberOfRepresentedElementsByDiagram.entrySet())
if (entry.getValue() > numberOfRepresented)
// take better diagram
bestDiagram = entry.getKey();
numberOfRepresented = entry.getValue();
else if (entry.getValue() == numberOfRepresented)
// take the currently opened diagram if it is as good
if (currentRegistry.get(entry.getKey()) != null)
// change active diagram if necessary
if (bestDiagram != null && currentRegistry.get(bestDiagram) == null)
Object pageMngr = editor.getAdapter(IPageMngr.class);
if (pageMngr instanceof IPageMngr)
IPageMngr pageManager = (IPageMngr) pageMngr;
if (pageManager.isOpen(bestDiagram))
// bring to top
pageManager.closePage(bestDiagram);
pageManager.openPage(bestDiagram);
else
// open
// select edit parts in the current viewer
if (currentRegistry.containsKey(view))
Object part = currentRegistry.get(view);
if (part instanceof EditPart)
editPartsToSelect.add((EditPart) part);
// select edit parts if selection has to change
if (!(editPartsToSelect.containsAll(currentViewer.getSelectedEditParts()) && currentViewer.getSelectedEditParts().contains(editPartsToSelect)))
boolean firstSelectedPartInViewer = true;
for (EditPart editPart : editPartsToSelect)
if (firstSelectedPartInViewer)
currentViewer.select(editPart);
firstSelectedPartInViewer = false;
else
currentViewer.appendSelection(editPart);
* Get the graphical viewer of the editor.
* @return the graphical viewer.
public EditPartViewer getGraphicalViewer(IEditorPart editor)
if (editor == null)
Object viewer = editor.getAdapter(IDiagramGraphicalViewer.class);
if (viewer instanceof EditPartViewer)
return (EditPartViewer) viewer;
return null;
Re: How to visualize elements programatically [message #713544 is a reply to message #713468] |
Mon, 08 August 2011 15:27 |
Timothy Marc Messages: 547 Registered: July 2009 |
Hi Vincent,
thanks for your answer. Will be quite hard to obtain a result by just having
this fragment. Please, may I ask you another question on this.
I suppose the method gotoEObject is the core concept for the solution of my
problem, however, it seems to me as if the method goToEObjects would open
the editor where a selected EObject is already present. Is this true? I
glanced over the code and I did not found anything that looked like adding
an EObject to the canvas. Maybe, if your time permits it, you could give me
some more details on how to customize this thing. It would be highly
appreciated, indeed.
Thanks in advance and have your day.
Thanks, Timothy
"Vincent" schrieb im Newsbeitrag news:j1opka$n9u$1@news.eclipse.org...
* Contributors:
* @author vhemery
given EObject.<br>
* open
if (editor == null)
* elements)
HashSet<Diagram>();
List< ? > views =
Diagram))
if
diagram
if
0);
Integer num =
num + 1);
available
good
== null)
// bring to top
else
// open
List< ? > views =
if
else
if (editor == null)
Object viewer =
return null;
FUDForum. Page generated in 0.04437 seconds
