Re: How to get rid of warnings in console? [message #72483 is a reply to message #72448] |
Wed, 04 June 2008 10:18 |
I've just opened an issue request about that:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=235559
For now, I can suggest you to use error_reporting(E_ERROR) somewhere in
the beginning of your code, so you will be notified only on real errors.
Thanks!
kkaal wrote:
> I am developing components for Joomla! 1.5. Joomla! uses singleton
> patterns extensively. That means that the objects have a static field in
> which it stores a instance of itself. A getInstace() function makes this
> own instance awailable globally.
> PDT throws a warning for every occurance of this construct: "Debug
> strict... - Non-static method JLoader::register() should not be called
> statically"
> For my development work it is really not of interest if that is a
> problem or not (I think it is a quite modern design), but it is
> virtually impossible to find my relevant debugging info in tons of (for
> me) unnecessary info.
> Can anybody tell me how to switch that off?
> Thank you very much
> Klaus
FUDForum. Page generated in 0.03955 seconds
