Home » Modeling » GMF (Graphical Modeling Framework) » How to introduce new Element inside GMF Generated PALETTE after Diagram Code Generation
How to introduce new Element inside GMF Generated PALETTE after Diagram Code Generation [message #703365] Wed, 27 July 2011 09:50 Go to next message
I am using the Eclipse Shape example(provided in 15minutes...).
Now I created and got the Diagram Generated Code and I did a lot of modifications.
Now I got the requirement of adding more components/elements inside the Palette.
But if I start the process from Ecore generation , I am going to loose all my modifications.
So is there any way to add or introduce any new Components/Element which extends Shape directly in .gmfgen or any way which won't hurt my modifications in the generated Diagram codes.
Re: How to introduce new Element inside GMF Generated PALETTE after Diagram Code Generation [message #703451 is a reply to message #703365] Wed, 27 July 2011 11:12 Go to previous messageGo to next message
> modifications. Now I got the requirement of adding more
That's exactly the reason why it is not a good idea to modify generated
code. You'd rather have either used gmf runtime extension point to
override the behavior of the generated editor, or use custom templates
to modify the way code is generated.
http://wiki.eclipse.org/Graphical_Modeling_Framework/Tutorial/Part_3
Generated code methods should be prefixed by a "@generated" comment. You
should replace it by "@generated NOT" on methods you've modified. Then
when regenerating your diagram on the same code, the generated won't
override these classes.
> Quote:
The good practice it to have a customization plugin and use a
org.eclipse.gmf.runtime.diagram.ui.editpartProviders extension to
override the editPart (and then the figure) for a given model element.
HTH
http://mickaelistria.wordpress.com
http://twitter.com/#!/mickaelistria
http://www.petalslink.com
Re: How to introduce new Element inside GMF Generated PALETTE after Diagram Code Generation [message #703520 is a reply to message #703451] Wed, 27 July 2011 12:48 Go to previous messageGo to next message
@Mickael Istria
Can you please provide me any working example for -
Re: How to introduce new Element inside GMF Generated PALETTE after Diagram Code Generation [message #704043 is a reply to message #703520] Thu, 28 July 2011 03:41 Go to previous message
http://www.bonitasoft.org/websvn/listing.php?repname=Bonita+Open+Solution&path=%2Fbonita-studio%2Ftrunk%2Fplugins%2Forg.bonitasoft.studio.diagram.custom%2F#path_bonita-studio_trunk_plugins_org.bonitasoft.studio.diagram.custom_
HTH
Previous Topic:Unable to create editor ID error
Next Topic:Unifying Connections/Links
Current Time: Fri Aug 22 00:36:16 EDT 2025
Powered by FUDForum. Page generated in 0.05273 seconds
