Home » Language IDEs » ServerTools (WTP) » validating XSLT
validating XSLT [message #72441] Tue, 08 February 2005 18:23 Go to next message
Is there are way to validate a .xsl file as xml? It seems like I can
only run the xml validation on a file with a .xml extension.
I have looked under "validation" and "web and xml" preferences, but
there doesn't seem to be any way to specify file extensions that should
be regarded as xml.
Also, is there a way to test an xslt document against an xml file?
Dan Simmonds
Re: validating XSLT [message #72459 is a reply to message #72441] Tue, 08 February 2005 21:37 Go to previous messageGo to next message
Hi Dan,
>be regarded as xml.
Craig Salter and I spoke about the idea of associating an extension with a
certain file type (which would in turn associate editors and validators
with the file type) but nothing has been done yet. Please open a bug
report for this.
I'm not sure what you mean here. Do you want to test an XSL file against a
schema? Do you want to run an XSL transformation?
Lawrence
Re: validating XSLT [message #72493 is a reply to message #72459] Tue, 08 February 2005 22:24 Go to previous messageGo to next message
Originally posted by: WhiteKnucklesMail-docs.yahoo.com
Altova XML Spy has a free executable that plugs their XML Spy Home
version software into eclipse. It definitely handles xml validation and
I think it may handle xslt as well.
On the downside, it wants to handle many file types - such as .jsp - but
is not nearly as nice as the WTP in that regard. However, you probably
know better than I how to control which plugin handles which file type.
I hope this helps.
Lawrence Mandel wrote:
> Hi Dan,
>>be regarded as xml.
> report for this.
> Lawrence
Re: validating XSLT [message #72511 is a reply to message #72459] Tue, 08 February 2005 22:26 Go to previous message
> report for this.
Thanks, I'll do that.
Sorry, I should have been more clear on this. I want to perform a
transformation from within eclipse, to test my XSLT against some XML.
Testing against a straight XML file would be fine, but testing the XSLT
against the output of a java method would be even better. Also, the
ability to run the xsl transformation through a debugger would be
awesome. I've seen this in Websphere Studio, and I wasn't sure if it
came out of a WTP feature that I haven't discovered.
Dan.
Previous Topic:Q. Formating JSP screws up document
Next Topic:A HowTo about creating a J2EE EAR with WTP
Current Time: Sat Nov 08 22:29:52 EST 2025
Powered by FUDForum. Page generated in 0.05809 seconds
