Home » Archived » M2M (model-to-model transformation) » ATL - Problem with Enum transformation
ATL - Problem with Enum transformation [message #72287] Thu, 17 January 2008 03:57 Go to next message
I'm doing a transformation to UML and I want to transform an element to
UML Enum.
I have done a rule like:
rule generatePublicVisibility (attr : UMLMMODEL!Property) {
to
o : UMLMMODEL!VisibilityKind
do {
attr.visibility <- o.public;
but it throws an exception:
GRAVE: org.eclipse.emf.ecore.impl.EEnumImpl cannot be cast to
org.eclipse.emf.ecore.EClass
How can I do this ?
Thanks.
Re: ATL - Problem with Enum transformation [message #73719 is a reply to message #72287] Tue, 29 January 2008 05:57 Go to previous message
I have solved it.
If you want to create a UML2 Property and you want to assign it a value to
its attribute visibility you only have to do this.
visibility <- #value
where value can be:
public
private
protected
that's all.
Previous Topic:[QVTOM] Deferred resolves
Next Topic:[ATL] Text wrapped in tags
Current Time: Sat Nov 08 22:29:59 EST 2025
Powered by FUDForum. Page generated in 0.03758 seconds
