Home » Archived » Buckminster » No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster
No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster [message #701753] Mon, 25 July 2011 14:39 Go to next message
Gabriel F. is currently offline Gabriel F.Friend
During an ANT-Task Buckminster shows the following error message.
In our target platform there is org.apache.commons.cli:osgi.bundle$1.2.0.v201105210650
Can anybody give me a hint what I can do to solve this problem?
init actor: jdt.ant[<myproject>:eclipse.feature$1.0.0.qualifier#start.task]
INFO:  [start <myproject>:eclipse.feature$1.0.0.qualifier#start.task]
ERROR: org.eclipse.buckminster.core.metadata.MissingComponentException: No component named org.apache.commons.cli.source:osgi.bundle/[1.2.0.v201105210650,1.2.0.v201105210650](&(buckminster.download.source=true)(!(eclipse.p2.optional=false))) is known to Buckminster
	at org.eclipse.buckminster.core.metadata.WorkspaceInfo.resolveLocal(WorkspaceInfo.java:613)
	at org.eclipse.buckminster.core.metadata.WorkspaceInfo.getResolution(WorkspaceInfo.java:504)
	at org.eclipse.buckminster.core.metadata.ModelCache.findCSpec(ModelCache.java:46)
	at org.eclipse.buckminster.jdt.internal.BMClasspathContainer.addNodeToClassPath(BMClasspathContainer.java:116)
	at org.eclipse.buckminster.jdt.internal.BMClasspathContainer.addNodeToClassPath(BMClasspathContainer.java:117)
	at org.eclipse.buckminster.jdt.internal.BMClasspathContainer.<init>(BMClasspathContainer.java:44)
	at org.eclipse.buckminster.jdt.internal.ClasspathEmitter.appendPaths(ClasspathEmitter.java:115)
	at org.eclipse.buckminster.jdt.internal.ClasspathEmitter.finalClasspathResolve(ClasspathEmitter.java:80)
	at org.eclipse.buckminster.jdt.internal.actor.JdtAntActor.addActorPathGroups(JdtAntActor.java:41)
	at org.eclipse.buckminster.ant.actor.AntActor.internalPerform(AntActor.java:241)
	at org.eclipse.buckminster.core.actor.AbstractActor.perform(AbstractActor.java:195)
	at org.eclipse.buckminster.core.internal.actor.PerformManager$DirectActionInvocation.execute(PerformManager.java:143)
	at org.eclipse.buckminster.core.internal.actor.PerformManager.internalPerform(PerformManager.java:454)
	at org.eclipse.buckminster.core.internal.actor.PerformManager.perform(PerformManager.java:293)
	at org.eclipse.buckminster.core.internal.actor.PerformManager.perform(PerformManager.java:305)
	at org.eclipse.buckminster.core.commands.Perform.internalRun(Perform.java:108)
	at org.eclipse.buckminster.core.commands.WorkspaceCommand.run(WorkspaceCommand.java:91)
	at org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(AbstractCommand.java:200)
	at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:317)
	at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:136)
	at org.eclipse.buckminster.cmdline.Headless.start(Headless.java:156)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Re: No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster [message #701786 is a reply to message #701753] Mon, 25 July 2011 15:39 Go to previous messageGo to next message
Matthew Webber is currently offline Matthew WebberFriend
What ANT-task are you trying to run? How was your target platform materialized?
And this may aound silly, but have you restarted your IDE since you materialized? Buckminster sometimes caches state that has in fact changed.
Re: No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster [message #702393 is a reply to message #701786] Tue, 26 July 2011 09:51 Go to previous messageGo to next message
Materialisation is done via p2 sites.
I have cleared the workspace in jenkins but the problem still persists.
This is my ANT-task:
    <target name="start.mwe.workflow"">
        <java classname="org.eclipse.emf.mwe.core.WorkflowRunner" dir="." classpathref="classpath" output="build.log">
        </java>
    </target>
The .cspex:
<cspecExtension
    xmlns:bc="(..)"
    xmlns="(..)">
    <dependencies>
        <dependency name="org.eclipse.emf.mwe.core" componentType="osgi.bundle" versionDesignator="1.1.0" versionType="OSGi"/>
        <dependency name="org.apache.commons.logging" componentType="osgi.bundle" versionDesignator="1.0.4" versionType="OSGi"/>
        <dependency name="org.eclipse.xtend.typesystem.emf" componentType="osgi.bundle" versionDesignator="1.0.1" versionType="OSGi"/>
        <dependency name="org.eclipse.emf.mwe.utils" componentType="osgi.bundle" versionDesignator="1.1.0" versionType="OSGi"/>
        <dependency name="org.eclipse.xtend.profiler" componentType="osgi.bundle" versionDesignator="1.0.1" versionType="OSGi"/>
        <dependency name="org.eclipse.xtend" componentType="osgi.bundle" versionDesignator="1.1.0" versionType="OSGi"/>
        <dependency name="org.eclipse.emf.ecore.xmi" componentType="osgi.bundle" versionDesignator="2.7.0" versionType="OSGi"/>
        <dependency name="org.eclipse.xtend.util.stdlib" componentType="osgi.bundle" versionDesignator="1.0.1" versionType="OSGi"/>
        <dependency name="org.eclipse.xpand" componentType="osgi.bundle" versionDesignator="1.1.0" versionType="OSGi"/>
    </dependencies>
    <actions>
        <public name="start.task" actor="jdt.ant">
            <actorProperties>
                <property key="buildFile" value="build.xml" />
                <property key="targets" value="start.mwe.workflow" />
            </actorProperties>
            <properties>
            </properties>
            <products alias="destination" base="${buckminster.output}">
                <path path="output/" />
            </products>
        </public>
    </actions>
</cspecExtension>
Re: No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster [message #725253 is a reply to message #702393] Wed, 14 September 2011 11:29 Go to previous messageGo to next message
js Missing name is currently offline js Missing nameFriend
Member
I have a related problem:
http://www.eclipse.org/forums/index.php/t/209520/
and never found a solution Sad I also get this one:
No component named org.apache.commons.logging.source:osgi.bundle/[1.1.1.v201005080502,1.1.1.v201005080502] is known to Buckminster
but cannot find any update sites that have the 1.1.1.v201005080502 version of that plugin.
Could be nice if bucky could produce information on which bundle/feature has a require on the specified version (have tried to save the .cspec file but it does not give any information on this).
[Updated on: Wed, 14 September 2011 11:45]
Report message to a moderator
Re: No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster [message #735976 is a reply to message #725253] Thu, 13 October 2011 09:27 Go to previous messageGo to next message
Andreas Schilling is currently offline Andreas SchillingFriend
I'm also having probably the same problem.
On our Buildserver (Jenkins) everything is fine, however if I want to do a local build from Eclipse (run the respective action that is defined in the CSPEX and that is also used on the buildserver) I get this error for at least one bundle (actually only one error is logged but when using more fine grained logging I see it on several bundles happen).
having a look at the dependency graph shows, that it seems like all *.source bundles of third party libraries are missing, e.g. com.springsource.javax.validation.source
the message then is
No component named com.springsource.javax.validation.source:osgi.bundle$0.0.0#Raw Omni Version is known to Buckminster
I don't really understand why that happens. first I thought that buckminster somehow does not use our target platform (which contains the bundle) when doing the local build but then again it should show ALL bundles to be unresolved and not only the source bundles (or shouldn't it?).
Btw, the manifest of that specific bundle seems to be not 100% correct to me, however for other bundles that also can't be resolved I can see problems on the first glance, so it might have something to do with it or not...
while in theory everything is fine as long as the Jenkins build does not fail I still would like to be able to work with buckminster on my development machine as well Razz
also, I can't tell you why and when things stopped working locally, because some 1 1/2 years ago when we were setting up the buckminster process everything worked from Eclipse as well.
regards,
Andreas
Re: No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster [message #735987 is a reply to message #735976] Thu, 13 October 2011 09:50 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
What version of Buckminster are you running? There's been a recent fix for missing source bundles.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=357060
- thomas
> the message then is
> buckminster on my development machine as well :p
> regards,
> Andreas
Re: No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster [message #736017 is a reply to message #735987] Thu, 13 October 2011 11:14 Go to previous messageGo to next message
I just set up a new eclipse with a fresh buckminster today (from the update site), it says it is 1.4.0.v20110915-1108
I assume the bug should be fixed in there?
Re: No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster [message #736026 is a reply to message #736017] Thu, 13 October 2011 11:32 Go to previous messageGo to next message
It should, yes.
- thomas
Re: No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster [message #736040 is a reply to message #736026] Thu, 13 October 2011 12:43 Go to previous messageGo to next message
Sad
but thanks for the help so far!
any further hints how I can debug such an issue? I still feel that I just might be missing some rather simple point. I wouldn't consider myself a buckminster expert, so that's quite likely Smile
EDIT: I just saw that "BJ" seems to have exactly the same problem (the other thread opened today)
regards,
Andreas
[Updated on: Thu, 13 October 2011 12:49]
Re: No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster [message #886703 is a reply to message #736040] Fri, 15 June 2012 13:47 Go to previous messageGo to next message
so, we're still struggling with that error, it's really driving us crazy.
some small progresses have been made though.
in the cquery we can include advisor nodes to skip the strange source bundles.
however, when invoking an action this does not help at all.
what is strange and something we definitely do not understand is, why these source bundles are listed as direct dependencies of our product (if we open the dependencies view in eclipse). in no dependency anywhere in our bundles these source bundles are referenced.
does someone have an idea how that happens?
thanks for any hints in advance!
Re: No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster [message #892258 is a reply to message #886703] Wed, 27 June 2012 14:11 Go to previous messageGo to next message
Dennis Huebner is currently offline Dennis HuebnerFriend
Hi Andreas ,
can you provide an example project, which I can try to run with my buckminster installation?
github or something?
Dennis.
+Dennis Huebner
Get professional support from the Xtext committers at www.typefox.io
Re: No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster [message #1385384 is a reply to message #892258] Fri, 06 June 2014 05:07 Go to previous messageGo to next message
Al B is currently offline Al BFriend
Did anyone find workaround for this? With Juno, we are able to create build artifacts, but when we try with Kepler 4.3, then we get this exception:
Problem during meta-data refresh: No component named _feature_gov.nasa.arc.spife is known to Buckminster
org.eclipse.buckminster.core.metadata.MissingComponentException: No component named _feature_gov.nasa.arc.spife is known to Buckminster
at org.eclipse.buckminster.core.resolver.LocalResolver.fromPath(LocalResolver.java:179)
at org.eclipse.buckminster.core.resolver.LocalResolver.fromPath(LocalResolver.java:185)
at org.eclipse.buckminster.core.metadata.MetadataSynchronizer.refreshProject(MetadataSynchronizer.java:295)
at org.eclipse.buckminster.core.metadata.MetadataSynchronizer.workspaceCatchUp(MetadataSynchronizer.java:394)
at org.eclipse.buckminster.core.metadata.MetadataSynchronizer$WorkspaceCatchUpJob.run(MetadataSynchronizer.java:185)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Re: No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster [message #1385389 is a reply to message #1385384] Fri, 06 June 2014 06:10 Go to previous messageGo to next message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
> exception:
> at
> at
> at
> at
> at
do you get this error in the IDE or during the headless build? Are you
using Buckminster for Kepler?
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster [message #1551499 is a reply to message #701753] Wed, 07 January 2015 17:12 Go to previous messageGo to next message
Abhishek Chakraborty is currently offline Abhishek ChakrabortyFriend
Member
I am gettng this weird error and not able to see why this org.eclipse.emf.ecoretools.design:eclipse.feature is not getting resolved when i have this in my rmap {http://download.eclipse.org/modeling/emf/updates/releases/?importType=binary}
Buildfile: /home/chakraborty/workspace/temp/maps.releng/build.ant
[delete] Deleting: /home/chakraborty/workspace/temp/maps.releng/some.tmp.file
common.cleanup:
install.buckminster.headless:
install.buckminster.headless.internal:
buckminster:
[echo] IMPORTANT: Populating an empty target platform may took over 10 minutes.
[echo] build.properties: /home/chakraborty/workspace/temp/maps.releng/build.properties
[java] INFO: setpref 'targetPlatformPath=/home/chakraborty/workspace/temp/buildroot/target.platform'
[java] INFO: resolve '/home/chakraborty/workspace/temp/maps.releng/build.cquery'
[java] ERROR [0002] : No suitable provider for component org.eclipse.emf.ecoretools.design:eclipse.feature was found in resourceMap file:/home/chakraborty/workspace/temp/maps.releng/build.rmap
[java] ERROR [0002] : No suitable provider for component org.eclipse.emf.ecoretools.design:eclipse.feature was found in searchPath eclipse
[java] ERROR [0002] : Rejecting provider p2({0}[http://download.eclipse.org/releases/juno]): No component match was found
[java] ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/modeling/emf/updates/releases/?importType=binary[http://download.eclipse.org/modeling/emf/updates/releases/?importType=binary]): No component match was found
[java] ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/modeling/mdt/ocl/updates/releases/?importType=binary[http://download.eclipse.org/modeling/mdt/ocl/updates/releases/?importType=binary]): No component match was found
[java] ERROR [0002] : Rejecting provider p2(http://update.toem.de/?importType=binary[http://update.toem.de/?importType=binary]): No component match was found
[java] ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/birt/update-site/4.3/?importType=binary[http://download.eclipse.org/birt/update-site/4.3/?importType=binary]): No component match was found
[java] ERROR [0002] : Rejecting provider p2({0}[http://download.eclipse.org/tools/cdt/releases/8.5]): No component match was found
[java] WARNING [0018] : Component request org.apache.commons.codec:osgi.bundle/[1.3.0.v201101211617,1.3.0.v201101211617] is in conflict with request org.apache.commons.codec:osgi.bundle/[1.4.0.v201209201156,1.4.0.v201209201156]
[java] WARNING [0036] : Component request org.junit:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100] is in conflict with request org.junit:osgi.bundle/[4.10.0.v4_10_0_v20120426-0900,4.10.0.v4_10_0_v20120426-0900]
[java] WARNING [0040] : Component request org.apache.commons.logging:osgi.bundle/[1.1.1.v201101211721,1.1.1.v201101211721] is in conflict with request org.apache.commons.logging:osgi.bundle/[1.0.4.v201101211617,1.0.4.v201101211617]
[java] WARNING [0085] : Component request org.junit.source:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100] is in conflict with request org.junit.source:osgi.bundle/[4.10.0.v4_10_0_v20120426-0900,4.10.0.v4_10_0_v20120426-0900]
[java] WARNING [0036] : Component request org.junit:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100] is in conflict with request org.junit:osgi.bundle/4.8.1
[java] WARNING [0036] : Component request org.junit:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100] is in conflict with request org.junit:osgi.bundle/4.7.0
[java] WARNING [0014] : Component request org.w3c.dom.smil:osgi.bundle/[1.0.0.v200806040011,1.0.0.v200806040011] is in conflict with request org.w3c.dom.smil:osgi.bundle/[1.0.1.v200903091627,1.0.1.v200903091627]
[java] INFO: TAG-ID 0002 = Query for maps.releng:buckminster, path: maps.releng:buckminster$1.0.0
[java] TAG-ID 0014 = Query for maps.releng:buckminster, path: maps.releng:buckminster$1.0.0 -> org.eclipse.e4.rcp:eclipse.feature$1.1.2.v20130130-191718-91FUvGP7GIX2Kgz-z-gvjMvXV1NS
[java] TAG-ID 0018 = Query for maps.releng:buckminster, path: maps.releng:buckminster$1.0.0 -> org.eclipse.net4j:eclipse.feature$4.1.2.v20121028-0914
[java] TAG-ID 0036 = Query for maps.releng:buckminster, path: maps.releng:buckminster$1.0.0 -> org.eclipse.jdt:eclipse.feature$3.8.2.v20130116-090414-8-8nFu3FNOfwKLRuqgXKIy9z0I83
[java] TAG-ID 0040 = Query for maps.releng:buckminster, path: maps.releng:buckminster$1.0.0 -> org.eclipse.net4j.util:eclipse.feature$4.1.2.v20121028-0914
[java] TAG-ID 0085 = Query for maps.releng:buckminster, path: maps.releng:buckminster$1.0.0 -> org.eclipse.sdk:eclipse.feature$4.2.2.v20130116-114742-7T7oDVDQ23Iosz-vkFwNncmx7z-9Rts4b0m1FotkYacO5 -> org.eclipse.jdt.source:eclipse.feature$3.8.2.v20130116-090414-8-8nFu3FNOfwKLRuqgXKIy9z0I83
Re: No component named org.apache.commons.cli.source:osgi.bundle/ known to Buckminster [message #1552749 is a reply to message #1551499] Thu, 08 January 2015 09:45 Go to previous message
Why do you append ?importType=binary ?
Xtext Book:
Previous Topic:Angular Js Eclipse Plugin Issue
Next Topic:No component named de.toem.impulse.installation:osgi.bundle$null is known to Buckminster
Current Time: Sat Jun 10 19:14:49 GMT 2023
Powered by FUDForum. Page generated in 0.02529 seconds
