(no subject) [message #701783 is a reply to message #701667] |
Mon, 25 July 2011 15:20 |
To build a simple Java application just add the jars from the
reportruntime download to your classpath. If you are using Eclipse to
build the application use these steps.
1 - download the birt runtime
2 - create a new java project in Eclipse
3 - right click on the project in the Package view and select Build
Path->configure build path.
4 - Select the libraries tab and click on the add external Jars.
5 - Add all the jars from the birtruntime download/reportengine/lib
directory.
6 - create your class. For example look at the following.
package REAPI;
import java.util.logging.Level;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EXCELRenderOption;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.PDFRenderOption;
public class RunAndRenderTask {
public void runReport() throws EngineException
IRunAndRenderTask task=null;
IReportEngine engine=null;
EngineConfig config = null;
try{
config = new EngineConfig( );
config.setLogConfig("c:/dwn", Level.SEVERE);
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
IReportRunnable design = null;
//Open the report design
design = engine.openReportDesign("Reports/TopNPercent.rptdesign");
task = engine.createRunAndRenderTask(design);
task.setParameterValue("Top Count", (new Integer(5)));
task.validateParameters();
HTMLRenderOption options = new HTMLRenderOption();
options.setImageDirectory("./");
options.setOutputFileName("output/resample/out.html");
options.setOutputFormat("html");
task.setRenderOption(options);
task.run();
task.close();
engine.destroy();
}catch( Exception ex){
ex.printStackTrace();
Platform.shutdown( );
System.out.println("Finished");
* @param args
try
RunAndRenderTask ex = new RunAndRenderTask( );
ex.runReport();
System.exit(0);
catch ( Exception e )
e.printStackTrace();
A couple of extras to note. The openReportDesign method in the above
example is looking for a report named TopNPercent.rptdesign in a folder
in the project named Reports. You could specify the complete path to a
report instead. The output file out.html is generating the report in a
folder in the project named output. A full path could have been used
as well. Finally, if you want to the code to run multiple reports only
start up the platform once and just create new task for each report.
Jason
On 7/25/2011 8:22 AM, fixed-term.georgios.mavridis wrote:
> hello,
> i want to create a birt report with a simple java application.
> i found some code examples on the internet but my problem is, how do i
> use the classes and methods?
> i thought there would be a libary (jar-file) which i have to include,
> but there is not (or i just did not found it)
> is there an other way how to include the classes and methods which i
> need to create a birt report in a java project?
> thx!
(no subject) [message #701784 is a reply to message #701783] |
Mon, 25 July 2011 15:21 |
BTW the code sample was for BIRT 3.7.
Jason
> directory.
> package REAPI;
> try{
> task.run();
> task.close();
> engine.destroy();
> * @param args
> public static void main(String[] args) {
> try
> ex.runReport();
> System.exit(0);
> folder in the project named output. A full path could have been used as
> Jason
>> hello,
>> thx!
FUDForum. Page generated in 0.03551 seconds
