Home » Eclipse Projects » Subversive » Error installing into Java EE Windows 64-bit package
Error installing into Java EE Windows 64-bit package [message #701440] |
Mon, 25 July 2011 05:41 |
I'm getting the following error trying to install latest
Subversive [1] into the Indigo Java EE Windows 64-bit [2]
package:
An error occurred while collecting items to be installed
session context was:(profile=epp.package.jee, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.team.svn.core,0.7.9.I20110724-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn,0.7.9.I20110724-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.help,0.7.9.I20110715-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.ui,0.7.9.I20110715-1700
However it appears to install fine in the Java EE Windows 32-bit
package, and in other Windows 64-bit packages like the pure
Platform Runtime Binary [3] or Eclipse IDE for Java Developers [4].
Is this a problem of the Java EE Windows 64-bit package, or
Subversive one?
[1] http://download.eclipse.org/technology/subversive/0.7/headless-update-site/
[2] http://www.eclipse.org/downloads/packages/eclipse-ide-java-ee-developers/indigor
[3] http://download.eclipse.org/eclipse/downloads/drops/R-3.7-201106131736/index.php#PlatformRuntime
[4] http://www.eclipse.org/downloads/packages/eclipse-ide-java-developers/indigor
Stanimir
Error installing into Java EE Windows 64-bit package [message #706459 is a reply to message #701440] |
Sun, 31 July 2011 10:44 |
[Cross-posting to eclipse.webtools, Followup-To set]
I hope eclipse.webtools is suitable for issues related to the
Eclipse IDE for Java EE Developers package. Do anyone have idea
what the original problem (see below) might be caused from?
I've corrected the actual Subversive [1] reference used, given in
the original post, here:
was: http://download.eclipse.org/technology/subversive/0.7/headless-update-site/
is: http://download.eclipse.org/technology/subversive/0.7/update-site/
-------- Original Message --------
Newsgroups: eclipse.technology.subversive
Subject: Error installing into Java EE Windows 64-bit package
Date: Mon, 25 Jul 2011 08:41:35 +0300
package:
Subversive one?
[1] http://download.eclipse.org/technology/subversive/0.7/update-site/
Stanimir
Re: Error installing into Java EE Windows 64-bit package [message #708756 is a reply to message #706459] |
Wed, 03 August 2011 06:07 |
[Cross-posted to eclipse.technology.subversive, Followup-To:
eclipse.webtools]
Sun, 31 Jul 2011 13:44:53 +0300, /Stanimir Stamenkov/:
> package:
For what is worth, I've now opened:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=353682
Stanimir
Re: Error installing into Java EE Windows 64-bit package [message #777093 is a reply to message #708756] |
Mon, 09 January 2012 20:38 |
Robert Emmons Messages: 29 Registered: July 2009 |
I'm also trying to install subversive through Eclipse's software install, using this site:
Subversive Site - http://download.eclipse.org/technology/subversive/0.7/update-site/
I'm running 64-bit Eclipse Indigo SR1 on Windows 7.
I'm getting the error message below. How can I get Subversive installed?
No repository found containing: osgi.bundle,org.eclipse.team.svn.core,0.7.9.I20111123-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn,0.7.9.I20111123-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.nl1,0.7.9.I20111119-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.nl1.sources,0.7.9.I20111119-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.nl1.sources,0.7.9.I20111119-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.resource.ignore.rules.jdt,0.7.9.I20111119-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.resource.ignore.rules.jdt,0.7.9.I20111119-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.resource.ignore.rules.jdt.source,0.7.9.I20111119-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.resource.ignore.rules.jdt.source,0.7.9.I20111119-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.revision.graph,0.7.9.I20111123-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.revision.graph,0.7.9.I20111123-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.revision.graph.source,0.7.9.I20111123-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.revision.graph.source,0.7.9.I20111123-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.source,0.7.9.I20111123-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.sources,0.7.9.I20111123-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.sources,0.7.9.I20111123-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.ui,0.7.9.I20111123-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.ui.nl1,0.7.9.I20111119-1700
Re: Error installing into Java EE Windows 64-bit package [message #820179 is a reply to message #701440] |
Tue, 13 March 2012 20:34 |
Richard Katz Messages: 2 Registered: March 2012 |
I'm getting this same error on Ubuntu 11.10 with Eclipse 3.7.2 64Bit. However, on Windows 7 64Bit, I did not get this error.
It seems like an odd error. Obviously the repository is actually there, because you have to connect to it before you get this error.
Is there possibly some state or circumstance of Eclipse that causes this?
Thanks.
Rich.
No repository found containing: osgi.bundle,org.eclipse.team.svn.core,0.7.9.I20120210-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn,0.7.9.I20120210-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.help,0.7.9.I20120210-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.nl1,0.7.9.I20120210-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.revision.graph,0.7.9.I20120210-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.ui,0.7.9.I20120210-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.ui.nl1,0.7.9.I20120210-1700
Current Time: Sat Apr 27 01:00:19 GMT 2024
Powered by FUDForum. Page generated in 0.03809 seconds
