Re: an issue when using the xml schema editor to show the reference element... [message #71670 is a reply to message #71650] |
Mon, 05 March 2007 20:39 |
Jackie,
You must be using the XML Schema editor provided by the webtools project
because the crude editor provided by the XSD project doesn't have a
graphical view. Does your schema contain an import of this namespace?
Jackie Zhang wrote:
> The namespace is defined as:
> xmlns:com.fnf="http://www.fnf.com/xes"
> The complex type is defined as the following:
> <xsd:complexType name="PaySvcRq_Type">
> <xsd:sequence>
> <xsd:element ref="RqUID"/>
> <xsd:element ref="MsgRqHdr" minOccurs="0"/>
> <xsd:element ref="AsyncRqUID" minOccurs="0"/>
> <xsd:element ref="SPName" minOccurs="0"/>
> <xsd:sequence maxOccurs="unbounded">
> <xsd:element ref="PmtAddRq" minOccurs="0"/>
> <xsd:element ref="CustPayeeAddRq" minOccurs="0"/>
> <xsd:element ref="com.fnf:CustPayeeInqRq" minOccurs="0"/>
> </xsd:sequence>
> </xsd:sequence>
> <xsd:attribute name="Id" type="xsd:ID"/>
> </xsd:complexType>
> when using the XMLSpy to open the schema file, It shows both
> <xsd:element ref="CustPayeeAddRq" minOccurs="0"/> and <xsd:element
> ref="com.fnf:CustPayeeInqRq" minOccurs="0"/> in the graphic view. but
> when using the xml schema editor to open the same file, it shows only
> <xsd:element ref="CustPayeeAddRq" minOccurs="0"/> in the grapic view.
> Thanks
> Jackie
Re: an issue when using the xml schema editor to show the reference element... [message #71707 is a reply to message #71689] |
Tue, 06 March 2007 14:36 |
Jackie,
Yes, the underlying XSD model supports the full language.
Jackie Zhang wrote:
> Ed, yes, we are using webtools project. We have imported the
> namespace. Dose the XSD schema editor support the substitutionGroup?
> In one schema, for example, we have CustPayeeInfo_Type defined:
> <xsd:complexType name="CustPayeeInfo_Type">
> <xsd:sequence>
> <xsd:element ref="Name" minOccurs="0"/>
> </xsd:sequence>
> </xsd:complexType>
> In another achema, we extended the CustPayeeInfo_Type and used
> �substitutionGroup� like this:
> <xsd:complexContent>
> <xsd:extension base="CustPayeeInfo_Type">
> <xsd:sequence>
> <xsd:element ref="com.fnf:AcctName" minOccurs="0"/>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexContent>
> </xsd:complexType>
> <xsd:element name="CustPayeeInfo" type="com.fnf:CustPayeeInfo_Type"
> substitutionGroup="CustPayeeInfo"/>
> Thanks
> Jackie
Re: an issue when using the xml schema editor to show the reference element... [message #71840 is a reply to message #71820] |
Sun, 11 March 2007 03:12 |
Jackie,
I don't really understand what you are expecting to see. It sounds like
you are expecting to see the substitution group element showing up in
the content model, but I don't think the editor is designed to display
the content model that way.
Jackie Zhang wrote:
> Hi, I finally got time back to this. I created a small example that
> can show the problem. I am hoping that you guys can take a look at it
> first before I open a bug. The example contains 4 schemas, if you open
> IFX150_root.xsd in XML spy, you will see both CustPayeeInfo and
> com.abc:CustPayeeInfo under CustPayeeAddRq, but not in the XML schema
> editor (Eclipse 3.1 and Eclipse 3.2). The com.abc:CustPayeeInfo is
> defined in ABC.base.xsd and substitutionGroup="CustPayeeInfo" is used.
> IFX150_root.xsd � <?xml version="1.0" encoding="UTF-8"?>
> <xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xmlns="http://www.ifxforum.org/IFX_150"
> xmlns:com.abc="http://www.abc.com/xyz"
> targetNamespace="http://www.ifxforum.org/IFX_150"
> elementFormDefault="qualified" attributeFormDefault="unqualified">
> <xsd:include schemaLocation="IFX150_base.xsd"/>
> <xsd:include schemaLocation="IFX150_messages.xsd"/>
> <xsd:import namespace="http://www.abc.com/xyz"
> schemaLocation="ABC_base.xsd"/>
> <xsd:complexType name="BankSvcRq_Type">
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:element name="PaySvcRq" type="PaySvcRq_Type"/>
> </xsd:schema>
> IFX150_base.xsd - <?xml version="1.0" encoding="UTF-8"?>
> <xsd:schema xmlns="http://www.ifxforum.org/IFX_150"
> elementFormDefault="qualified">
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:simpleType name="C">
> <xsd:restriction base="xsd:string"/>
> </xsd:simpleType>
> <xsd:simpleType name="Name_Type">
> <xsd:restriction base="C">
> <xsd:maxLength value="40"/>
> </xsd:restriction>
> </xsd:simpleType>
> <xsd:element name="CustPayeeInfo" type="CustPayeeInfo_Type"/>
> <xsd:element name="Name" type="Name_Type"/>
> </xsd:schema>
> ABC.base.xsd
> <xsd:schema xmlns:com.abc="http://www.abc.com/xyz"
> targetNamespace="http://www.abc.com/xyz" elementFormDefault="qualified">
> <xsd:import namespace="http://www.ifxforum.org/IFX_150"
> <xsd:annotation>
> <xsd:documentation>Cust Payee Info Aggregate</xsd:documentation>
> </xsd:annotation>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> <xsd:element name="CustPayeeInfo" type="com.abc:CustPayeeInfo_Type"
> </xsd:schema>
> IFX150_CustPayeeAdd.xsd
> <xsd:element name="CustPayeeAddRq" type="CustPayeeAddRq_Type"/>
> <xsd:complexType name="CustPayeeAddRq_Type">
> <xsd:sequence>
> <xsd:element ref="Name"/>
> <xsd:element ref="CustPayeeInfo"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
Re: an issue when using the xml schema editor to show the reference element... [message #602156 is a reply to message #71650] |
Ed Merks Messages: 33141 Registered: July 2009 |
Jackie,
> <xsd:sequence>
> </xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> Thanks
> Jackie
Ed Merks
Re: an issue when using the xml schema editor to show the reference element... [message #602178 is a reply to message #71689] |
Jackie,
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> Thanks
> Jackie
Ed Merks
Re: an issue when using the xml schema editor to show the reference element... [message #602235 is a reply to message #71820] |
Jackie,
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:schema>
> ABC.base.xsd
> <xsd:annotation>
> </xsd:annotation>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> </xsd:schema>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
Ed Merks
FUDForum. Page generated in 0.04769 seconds
