| How to let jet/emf codegen generate incorrect java files? [message #71526] |
Wed, 14 February 2007 14:43  |
I am upgrading a code generation project to emf 2.3. Something which seems to have changed is that
when I make a mistake in my template it seems that Jet does not generate the java source file but
instead throws a RuntimeException. Is there a way for me to let jet still generate the source file
and save it? This makes it easier to identify the error in the template.
Also jet does not seem to create a .JETEmitters project anymore.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: How to let jet/emf codegen generate incorrect java files? [message #71582 is a reply to message #71564] |
Wed, 14 February 2007 15:00   |
Ed,
Thanks, I will enter a feature request.
Regarding the jetemitters project. I do this:
final Generator generator = new Generator(registry);
generator.setInput(genModel);
generator.getOptions().codeFormatting = true;
generator.getOptions().dynamicTemplates = true;
generator.getOptions().forceOverwrite = true;
I also tried setting the projectname on the jetemitters but without result.
Before I could see the .JETEmitters project in the java browsing perspective but now its not shown
(because it is not there or it is hidden). To ask a basic eclipse question, how can I make hidden
projects visible?
gr. Martin
Ed Merks wrote:
> Martin,
> A similar type of issue came up in the GMF newsgroup and in that case it
> wasn't really even an error in the generated code but simply a redundant
> semicolon that was configured to be treated as a warning. The issue
> arises *here *in ASTFacadeHelper:
> public ASTJCompilationUnit createCompilationUnit(String name,
> String contents)
> // set source
> char[] contentAsCharArray = contents.toCharArray();
> ASTParser astParser = createASTParser();
> astParser.setSource(contentAsCharArray);
> // parse
> CompilationUnit astCompilationUnit =
> (CompilationUnit)astParser.createAST(null);
> // display errors if any
> *if (astCompilationUnit.getProblems().length > 0)*
> // TODO do a better job with reporting errors
> String problems =
> logCompilationErrors(astCompilationUnit.getProblems());
> // NAME may be passed as name - do not show it
> if (name != null && !"".equals(name) && !"NAME".equals(name))
> problems = name + ":" + problems;
> // stop merging and report problems
> throw new RuntimeException(problems);
> It seems to me it might be best to continue despite errors because a
> whole bunch of times I've needed to set a breakpoint here and look at
> the value of "contents" to see what's gone wrong when it would have been
> easier to see it in the generated result. Please open a bugzilla to
> track this issue. I'd like to discuss this with Marcelo (and Dave) but
> Marcelo is on vacation. You could comment out this block of code in
> your local version in the meantime...
> I tried setting dynamic templates to true in a sample model and the
> ..JETEmitter project is still created as always. You aren't just
> filtering it out are you?
> Martin Taal wrote:
>> seems to have changed is that when I make a mistake in my template it
>> seems that Jet does not generate the java source file but instead
>> generate the source file and save it? This makes it easier to identify
The Netherlands
| Re: How to let jet/emf codegen generate incorrect java files? [message #71637 is a reply to message #71582] |
Wed, 14 February 2007 15:34  |
Martin,
In the Package Explorer the little triangle will bring up a menu that
says "Filters..." and by default .* resources are filtered and hence a
project starting with dot will be filtered.
Martin Taal wrote:
> Ed,
> result.
> perspective but now its not shown (because it is not there or it is
> projects visible?
> gr. Martin
> Ed Merks wrote:
>> Martin,
>> it wasn't really even an error in the generated code but simply a
>> redundant semicolon that was configured to be treated as a
>> warning. The issue arises *here *in ASTFacadeHelper:
>> String contents)
>> // set source
>> // parse
>> String problems =
>> been easier to see it in the generated result. Please open a
>> bugzilla to track this issue. I'd like to discuss this with Marcelo
>> (and Dave) but Marcelo is on vacation. You could comment out this
>> block of code in your local version in the meantime...
>> Martin Taal wrote:
>>> Hi,
>>> it seems that Jet does not generate the java source file but instead
| Re: How to let jet/emf codegen generate incorrect java files? [message #602548 is a reply to message #71526] |
Wed, 14 February 2007 14:56  |
--------------000502000308090307000502
Martin,
String contents)
// set source
// parse
String problems =
Martin Taal wrote:
<html>
<head>
</head>
Martin,<br>
<br>
redundant semicolon that was configured to be treated as a warning.
The issue arises <b>here </b>in ASTFacadeHelper:<br>
<blockquote><small> public ASTJCompilationUnit
createCompilationUnit(String name, String contents)<br>
{<br>
// set source<br>
char[] contentAsCharArray = contents.toCharArray();<br>
ASTParser astParser = createASTParser();<br>
astParser.setSource(contentAsCharArray);<br>
<br>
// parse<br>
(CompilationUnit)astParser.createAST(null);<br>
<br>
// display errors if any<br>
<b>if (astCompilationUnit.getProblems().length > 0)</b><br>
{<br>
// TODO do a better job with reporting errors <br>
String problems =
logCompilationErrors(astCompilationUnit.getProblems());<br>
<br>
// NAME may be passed as name - do not show it<br>
!"NAME".equals(name))<br>
{<br>
problems = name + ":" + problems;<br>
}<br>
<br>
// stop merging and report problems<br>
throw new RuntimeException(problems);<br>
}</small><small></small><br>
</blockquote>
been easier to see it in the generated result. Please open a bugzilla
to track this issue. I'd like to discuss this with Marcelo (and Dave)
but Marcelo is on vacation. You could comment out this block of code
in your local version in the meantime...<br>
<br>
filtering it out are you?<br>
<br>
<br>
Martin Taal wrote:
<blockquote cite="mideqvooc$1gd$1@utils.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------000502000308090307000502--
| Re: How to let jet/emf codegen generate incorrect java files? [message #602553 is a reply to message #71564] |
Ed,
projects visible?
gr. Martin
Ed Merks wrote:
> Martin,
> String contents)
> // set source
> // parse
> String problems =
> Martin Taal wrote:
The Netherlands
| Re: How to let jet/emf codegen generate incorrect java files? [message #602570 is a reply to message #71582] |
Martin,
Martin Taal wrote:
> Ed,
> result.
> projects visible?
> gr. Martin
> Ed Merks wrote:
>> Martin,
>> String contents)
>> // set source
>> // parse
>> String problems =
>> Martin Taal wrote:
>>> Hi,
FUDForum. Page generated in 0.04856 seconds
