Re: Birt, Cloudbase and java.sql.SQLException: Method not supported [message #699943 is a reply to message #699809] |
Fri, 22 July 2011 15:34 |
From the error it looks like the jdbc driver you are using for
cloudbase does not support the prepare method. There are a couple of w
ways to ignore unsupported jdbc calls, but it would be best to know
which are not supported first. Do you have a small jdbc java client
that shows access to the datasource?
Jason
On 7/22/2011 7:10 AM, dmnk_89 wrote:
> I'm trying to create report with JDBC connecting to my cloudbase(you can
> find it at sourceforge) server. When I test connection in Data Source
> it's working. When i'm trying to create a simple select I'm getting an
> exception.
> I'm using Eclipse IDE for Java and Report Developers - fresh downloaded
> version
> SEVERE: Failed to prepare the following query for the data set type
> (org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet). [select TITLE
> from JSON_TABLE1 ]
> org.eclipse.birt.report.data.oda.jdbc.JDBCException: Error preparing SQL
> statement.
> SQL error #1:Method not supported
> at
> org.eclipse.birt.report.data.oda.jdbc.Statement.prepare(Statement.java:135)
> at
> org.eclipse.birt.report.data.oda.jdbc.bidi.BidiStatement.prepare(BidiStatement.java:52)
> at
> org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.doPrepare(OdaQuery.java:229)
> at
> org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.prepare(OdaQuery.java:186)
> at
> org.eclipse.birt.data.engine.odaconsumer.Connection.prepareOdaQuery(Connection.java:290)
> at
> org.eclipse.birt.data.engine.odaconsumer.Connection.prepareStatement(Connection.java:197)
> at
> org.eclipse.birt.data.engine.executor.DataSource.prepareStatement(DataSource.java:302)
> at
> org.eclipse.birt.data.engine.executor.DataSourceQuery.prepare(DataSourceQuery.java:281)
> at
> org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.prepareOdiQuery(PreparedOdaDSQuery.java:455)
> at
> org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:343)
> at
> org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(PreparedQuery.java:455)
> at
> org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.produceQueryResults(PreparedDataSourceQuery.java:190)
> at
> org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:178)
> at
> org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute(PreparedOdaDSQuery.java:145)
> at
> org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:159)
> at
> org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:142)
> at
> org.eclipse.birt.report.data.adapter.impl.QueryExecutionHelper.executeQuery(QueryExecutionHelper.java:136)
> at
> org.eclipse.birt.report.data.adapter.impl.QueryExecutionHelper.executeQuery(QueryExecutionHelper.java:118)
> at
> org.eclipse.birt.report.data.adapter.impl.QueryExecutionHelper.executeQuery(QueryExecutionHelper.java:102)
> at
> org.eclipse.birt.report.data.adapter.impl.DataSetMetaDataHelper.getRuntimeMetaData(DataSetMetaDataHelper.java:194)
> at
> org.eclipse.birt.report.data.adapter.impl.DataSetMetaDataHelper.getRealMetaData(DataSetMetaDataHelper.java:153)
> at
> org.eclipse.birt.report.data.adapter.impl.DataSetMetaDataHelper.getDataSetMetaData(DataSetMetaDataHelper.java:115)
> at
> org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.getDataSetMetaData(DataRequestSessionImpl.java:236)
> at
> org.eclipse.birt.report.designer.data.ui.util.DataSetProvider.populateAllOutputColumns(DataSetProvider.java:216)
> at
> org.eclipse.birt.report.designer.data.ui.dataset.OutputColumnsPage.populateOutputColums(OutputColumnsPage.java:401)
> at
> org.eclipse.birt.report.designer.data.ui.dataset.OutputColumnsPage.updateOutputColumns(OutputColumnsPage.java:345)
> at
> org.eclipse.birt.report.designer.data.ui.dataset.OutputColumnsPage.pageActivated(OutputColumnsPage.java:244)
> at
> org.eclipse.birt.report.designer.data.ui.property.AbstractPropertyDialog.showPage(AbstractPropertyDialog.java:588)
> at
> org.eclipse.birt.report.designer.data.ui.property.AbstractPropertyDialog.showSelectionPage(AbstractPropertyDialog.java:482)
> at
> org.eclipse.birt.report.designer.data.ui.dataset.DataSetEditor.showSelectionPage(DataSetEditor.java:911)
> at
> org.eclipse.birt.report.designer.data.ui.property.AbstractPropertyDialog$2$1.run(AbstractPropertyDialog.java:438)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> org.eclipse.birt.report.designer.data.ui.property.AbstractPropertyDialog$2.selectionChanged(AbstractPropertyDialog.java:433)
> at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:164)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
> at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer.java:162)
> at
> org.eclipse.jface.viewers.StructuredViewer.updateSelection(StructuredViewer.java:2188)
> at
> org.eclipse.jface.viewers.StructuredViewer.handleSelect(StructuredViewer.java:1211)
> at
> org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected(StructuredViewer.java:1241)
> at
> org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenStrategy.java:239)
> at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.java:233)
> at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:403)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3588)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3209)
> at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
> at org.eclipse.jface.window.Window.open(Window.java:801)
> at
> org.eclipse.birt.report.designer.ui.dialogs.BaseDialog.open(BaseDialog.java:111)
> at
> org.eclipse.birt.report.designer.data.ui.providers.EditableDataSetNodeProvider.performEdit(EditableDataSetNodeProvider.java:102)
> at
> org.eclipse.birt.report.designer.internal.ui.views.DefaultNodeProvider.performRequest(DefaultNodeProvider.java:442)
> at
> org.eclipse.birt.report.designer.internal.ui.views.actions.EditAction.doAction(EditAction.java:90)
> at
> org.eclipse.birt.report.designer.internal.ui.views.actions.AbstractElementAction.run(AbstractElementAction.java:70)
> at
> org.eclipse.birt.report.designer.internal.ui.views.RenameListener.doubleClick(RenameListener.java:214)
> at
> org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:845)
> at
> org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:843)
> at
> org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1462)
> at
> org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1246)
> at
> org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:249)
> at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:246)
> at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:307)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
> at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at java.lang.reflect.Method.invoke(Method.java:616)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
> Caused by: java.sql.SQLException: Method not supported
> at
> com.business.cloudbase.CBConnection.prepareStatement(CBConnection.java:249)
> at
> org.eclipse.birt.report.data.oda.jdbc.Statement.prepare(Statement.java:131)
> ... 90 more
Re: Birt, Cloudbase and java.sql.SQLException: Method not supported [message #702013 is a reply to message #701452] |
Mon, 25 July 2011 20:43 |
I looked into this a bit and I am not certain why the cloudbase driver
does not support the prepareStatement method. BIRT uses this to setup
parameters etc.
Jason
On 7/25/2011 2:16 AM, dmnk_89 wrote:
> I'm using JDBC driver for the first time and I don't think that I have
> "a small jdbc java client that shows access to the datasource".
> I know that this driver is open-source but i don't know is this helping.
> (Source is in the package with release -
> sourceforge.net/projects/cloudbase/)
FUDForum. Page generated in 0.03680 seconds
