APIs error conection [message #699705] |
Fri, 22 July 2011 07:01 |
Hi people,
i really need help , i am new in this things from BIRT , and i am trying to do my first API , i used the exemple API from the eclipse webseit but i got the next error. I used the new version from Eclipse and the last Version from BIRT
i will post the error and the code that i used
Thank you
error:
Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/core/runtime/CoreException
at org.eclipse.birt.core.framework.Platform.createPlatformLauncher(Platform.java:115)
at org.eclipse.birt.core.framework.Platform.startup(Platform.java:74)
at DeDemo.buildReport(DeDemo.java:80)
at DeDemo.main(DeDemo.java:43)
Caused by: java.lang.ClassNotFoundException: org.eclipse.core.runtime.CoreException
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
... 4 more
CODE:
import java.io.IOException;
import java.util.ArrayList;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.model.api.CellHandle;
import org.eclipse.birt.report.model.api.DataItemHandle;
import org.eclipse.birt.report.model.api.DesignConfig;
import org.eclipse.birt.report.model.api.ElementFactory;
import org.eclipse.birt.report.model.api.IDesignEngine;
import org.eclipse.birt.report.model.api.IDesignEngineFactory;
import org.eclipse.birt.report.model.api.LabelHandle;
import org.eclipse.birt.report.model.api.OdaDataSetHandle;
import org.eclipse.birt.report.model.api.OdaDataSourceHandle;
import org.eclipse.birt.report.model.api.PropertyHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.RowHandle;
import org.eclipse.birt.report.model.api.SessionHandle;
import org.eclipse.birt.report.model.api.StructureFactory;
import org.eclipse.birt.report.model.api.TableHandle;
import org.eclipse.birt.report.model.api.activity.SemanticException;
import org.eclipse.birt.report.model.api.elements.structures.ComputedColumn;
import com.ibm.icu.util.ULocale;
* Dynamic Table BIRT Design Engine API (DEAPI) demo.
public class DECreateDynamicTable
ReportDesignHandle designHandle = null;
ElementFactory designFactory = null;
StructureFactory structFactory = null;
public static void main( String[] args )
try
DECreateDynamicTable de = new DECreateDynamicTable();
ArrayList al = new ArrayList();
al.add("OFFICECODE");
al.add("CITY");
al.add("COUNTRY");
de.buildReport(al, "From Offices" );
catch ( IOException e )
e.printStackTrace();
catch ( SemanticException e )
void buildDataSource( ) throws SemanticException
OdaDataSourceHandle dsHandle = designFactory.newOdaDataSource(
"Data Source", "org.eclipse.birt.report.data.oda.jdbc" );
dsHandle.setProperty( "odaDriverClass",
"org.eclipse.birt.report.data.oda.sampledb.Driver" );
dsHandle.setProperty( "odaURL", "jdbc:classicmodels:sampledb" );
dsHandle.setProperty( "odaUser", "ClassicModels" );
dsHandle.setProperty( "odaPassword", "" );
designHandle.getDataSources( ).add( dsHandle );
void buildDataSet(ArrayList cols, String fromClause ) throws SemanticException
OdaDataSetHandle dsHandle = designFactory.newOdaDataSet( "ds",
"org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" );
dsHandle.setDataSource( "Data Source" );
String qry = "Select ";
for( int i=0; i < cols.size(); i++){
qry += " " + cols.get(i);
if( i != (cols.size() -1) ){
qry += ",";
qry += " " + fromClause;
dsHandle.setQueryText( qry );
designHandle.getDataSets( ).add( dsHandle );
void buildReport(ArrayList cols, String fromClause ) throws IOException, SemanticException
//Configure the Engine and start the Platform
DesignConfig config = new DesignConfig( );
config.setProperty("BIRT_HOME", "C:/birt-runtime-2_1_1/birt-runtime-2_1_1/ReportEngine");
IDesignEngine engine = null;
try{
Platform.startup( config );
IDesignEngineFactory factory = (IDesignEngineFactory) Platform
.createFactoryObject( IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY );
engine = factory.createDesignEngine( config );
}catch( Exception ex){
ex.printStackTrace();
SessionHandle session = engine.newSessionHandle( ULocale.ENGLISH ) ;
try{
//open a design or a template
designHandle = session.openDesign("c:/tmp/testdeapi.rptdesign");
designFactory = designHandle.getElementFactory( );
buildDataSource();
buildDataSet(cols, fromClause);
TableHandle table = designFactory.newTableItem( "table", cols.size() );
table.setWidth( "100%" );
table.setDataSet( designHandle.findDataSet( "ds" ) );
PropertyHandle computedSet = table.getColumnBindings( );
ComputedColumn cs1 = null;
cs1 = StructureFactory.createComputedColumn();
cs1.setName((String)cols.get(i));
cs1.setExpression("dataSetRow[\"" + (String)cols.get(i) + "\"]");
computedSet.addItem(cs1);
// table header
RowHandle tableheader = (RowHandle) table.getHeader( ).get( 0 );
LabelHandle label1 = designFactory.newLabel( (String)cols.get(i) );
label1.setText((String)cols.get(i));
CellHandle cell = (CellHandle) tableheader.getCells( ).get( i );
cell.getContent( ).add( label1 );
// table detail
RowHandle tabledetail = (RowHandle) table.getDetail( ).get( 0 );
CellHandle cell = (CellHandle) tabledetail.getCells( ).get( i );
DataItemHandle data = designFactory.newDataItem( "data_"+(String)cols.get(i) );
data.setResultSetColumn( (String)cols.get(i));
cell.getContent( ).add( data );
designHandle.getBody( ).add( table );
// Save the design and close it.
designHandle.saveAs( "c:/temp/sample.rptdesign" ); //$NON-NLS-1$
designHandle.close( );
System.out.println("Finished");
}catch (Exception e){
i also add and screen schot
Thank you comunity!!!
Re: APIs error conection [message #699942 is a reply to message #699705] |
Fri, 22 July 2011 15:31 |
Can you start a new workspace in Eclipse and import the attached
project? Make sure to unzip it first and when it is imported update the
build path to point at the jars from the birt
3.7runtime/reportengine/lib jars.
Jason
On 7/22/2011 3:01 AM, richard wrote:
> Hi people,
> i really need help , i am new in this things from BIRT :d , and i am trying to do my first API , i used the exemple API from the eclipse webseit but i got the next error. I used the new version from Eclipse and the last Version from BIRT
> Thank you
> error:
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> ... 4 more
> CODE:
> try
> al.add("CITY");
> al.add("COUNTRY");
> for( int i=0; i< cols.size(); i++){
> qry += ",";
> try{
> try{
> buildDataSource();
> // table header
> // table detail
Attachment: APIs.zip
(Size: 43.63KB, Downloaded 408 times)
FUDForum. Page generated in 0.02934 seconds
