Android Developer Tools can not be installed [message #699129] |
Wed, 20 July 2011 22:09 |
cceal Messages: 1 Registered: July 2011 |
i have installed the other components using eclipse except for Android Developer Tools how do i solve this problem?
this message keeps on appearing:
Cannot complete the install because one or more required items could not be found.
Software being installed: Android Development Tools 12.0.0.v201106281929-138431 (com.android.ide.eclipse.adt.feature.group 12.0.0.v201106281929-138431)
Missing requirement: Android Development Tools 12.0.0.v201106281929-138431 (com.android.ide.eclipse.adt.feature.group 12.0.0.v201106281929-138431) requires 'org.eclipse.gef 0.0.0' but it could not be found
[Updated on: Wed, 20 July 2011 22:09] Report message to a moderator
Re: Android Developer Tools can not be installed [message #702973 is a reply to message #699510] |
Wed, 27 July 2011 02:12 |
nickbrower Messages: 1 Registered: July 2011 |
I am having this problem too.
I am trying to follow the "Installing the ADT Plugin" for the android from the android setup guide at <cant post a link cause im a noob>
and they give you two routes to follow:
1.
Start Eclipse, then select Help > Install New Software....
Click Add, in the top-right corner.
In the Add Repository dialog that appears, enter "ADT Plugin" for the Name and the following URL for the Location:
Click OK
Note: If you have trouble acquiring the plugin, try using "http" in the Location URL, instead of "https" (https is preferred for security reasons).
In the Available Software dialog, select the checkbox next to Developer Tools and click Next.
In the next window, you'll see a list of the tools to be downloaded. Click Next.
Read and accept the license agreements, then click Finish.
Note: If you get a security warning saying that the authenticity or validity of the software can't be established, click OK.
When the installation completes, restart Eclipse.
OR 2.
If you are having trouble downloading the ADT plugin after following the steps above, here are some suggestions:
If Eclipse can not find the remote update site containing the ADT plugin, try changing the remote site URL to use http, rather than https. That is, set the Location for the remote site to:
If you are behind a firewall (such as a corporate firewall), make sure that you have properly configured your proxy settings in Eclipse. In Eclipse, you can configure proxy information from the main Eclipse menu in Window (on Mac OS X, Eclipse) > Preferences > General > Network Connections.
If you are still unable to use Eclipse to download the ADT plugin as a remote update site, you can download the ADT zip file to your local machine and manually install it:
Download the current ADT Plugin zip file from the table below (do not unpack it).
Name Package Size MD5 Checksum
ADT 12.0.0 ADT-12.0.0.zip 5651973 bytes 8ad85d0f3da4a2b8dadfddcc2d66dbcb
Follow steps 1 and 2 in the default install instructions (above).
BUT both ways lead to the same error. please help.
FUDForum. Page generated in 0.09866 seconds
