Home » Eclipse Projects » Equinox » Export-Package mandatory directive
Export-Package mandatory directive [message #71296] Wed, 02 August 2006 11:15 Go to next message
I have a need for the mandatory directive in the Export-Package statements
but it doesn't work as I expected or perhaps I'm just doing something
wrong. Some input from the equinox gurus would be highly appreciated :)
I put the following in the manifest.mf of the exporting plugin
Export-Package: org.apache.batik;provider="com.id";mandatory:="provider",
and
Require-Bundle: org.apache.batik;provider="com.id",
in the importing plugin.
Now I have a few questions :
1) Is the syntax correct, the OSGi spec is a bit unclear and contains some
typos even :)
2) Is this supposed to work with Require-Bundle or only with Import-Package
3) Would the JDT/PDE build see these dependencies and flag them as errors
or do they ignore these
4) Would self-hosting adhere to these directives or do I need a installed
version
I was looking for the code myself to figure out what I might be doing
wrong or when it would work but got stuck in
org.eclipse.osgi.internal.resolver.isSatisfiedBy() as the only place I
could find that checks the directive. Strangely enough it isn't really
strict on what is inside the attributes.
Re: Export-Package mandatory directive [message #71468 is a reply to message #71296] Thu, 03 August 2006 14:44 Go to previous message
> and Require-Bundle: org.apache.batik;provider="com.id",
The mandatory directive does not apply to Require-Bundle. You get all
packages that are exported by a bundle when you use Require-Bundle
regardless of the mandatory directives. The provider="com.id" attribute
you added to the Require-Bundle header will be ignored for resolution
purposes.
> some typos even :)
It would be correct if you stuck the provider="com.id" matching
attribute on an Import-Package header (i.e Import-Package:
org.apache.batick;rovider="com.id")
Import-Package only.
> errors or do they ignore these
PDE should give you package access errors if you are not allowed to see
the exported package.
> installed version
The behavior should be the same for self-hosting vs. an installed version.
If you really want to restrict the users of a package (even when they
use Require-Bundle) to a limited set of bundles then you can use the
x-friends directive. For example:
Export-Package:
org.apache.batik; x-friends:="org.apache.friend1, org.apache.friend2"
This will only allow the two bundles with the symbolic name of
org.apache.friend1 or org.apache.friend2 to access your package.
This approach has two drawbacks.
1) it is brittle. When you want another bundle (org.apache.friend3) to
have access to the package then you need to update your bundle to
include the new friend.
2) by default the Equinox resolver is not strict WRT the x-friends
directive. You must set the system property osgi.resolverMode=true to
enable strict resolving. But PDE will give you warnings if you are
trying to use a package that you are not a "friend" to at development time.
org.eclipse.osgi.internal.resolver.ImportPackageSpecificatio nImpl.isSatisfiedBy
is where the real work is done WRT the mandatory directives. Note that
matching the attribute values is done before the code where the
mandatory directive is checked. The code that checks the mandatory
directive is only checking for the existence of the matching attribute
on the Import-Package statement not the actual value because that was
already checked above.
HTH
Tom
Previous Topic:plugin startup configuration
Next Topic:using ecore in an equinox runtime
Current Time: Wed Nov 05 13:54:20 EST 2025
Powered by FUDForum. Page generated in 0.03083 seconds
