Home » Archived » Visual Editor (VE) » VE Unable to parse specific code
VE Unable to parse specific code [message #71229] Wed, 10 November 2004 22:35 Go to next message
Hi, just want to report a strange behaviour from VE:
I have a method "refresh" below which has nothing to do with graphical
edition, but part of a Composite subclass. The strange thing is VE seems
to have difficulty rendering the window if the method is present in the
file. With some investigations, I realize that the 2 combo variables
confuses VE, if I remove one of the 2 "combo" variable, VE comes back to
normal.
private void refresh() {
PatientInterface patient = getPatient();
checkBoxActive.setSelection(patient.isActive());
textFirstname.setText(patient.getFirstname());
textLastname.setText(patient.getLastname());
if (getPatient().getBirthday() != null) {
textBirthday.setText(patient.getBirthday().toString());
Combo combo = comboGender;
List codes = (List) combo.getData();
String value = patient.getGender();
for (int i = 0; i < codes.size(); i++) {
CodeInterface c = (CodeInterface) codes.get(i);
if (c.getCodeKey().getKey().equals(value))
combo.select(i);
Combo combo = comboLanguage;
String value = patient.getLanguage();
combo.select(i);
The "Error Log" view exposes the following errors:
Exception thrown:
org.eclipse.ve.internal.java.codegen.model.BeanPart.createEO bject(BeanPart.java:845)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.createJavaInstances(JavaSourceTranslator.java:693)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.buildCompositionModel(JavaSourceTranslator.java:774)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:881)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:656)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1444)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
Re: VE Unable to parse specific code [message #71444 is a reply to message #71229] Thu, 11 November 2004 11:44 Go to previous message
> normal.
> combo.select(i);
> combo.select(i);
The problem is due to the fact that 'combo' is instantiated in two places. VE scopes goes into methods, not blocks.
so the duplication confused it.
In any case the parsing error was fixed recently (in the maintenance build stream)
Re: VE Unable to parse specific code [message #602993 is a reply to message #71229] Thu, 11 November 2004 11:44 Go to previous message
> normal.
> combo.select(i);
> combo.select(i);
Previous Topic:.. is too complicated to be evaluated
Next Topic:Extension Problem
Current Time: Sun Nov 09 17:19:26 EST 2025
Powered by FUDForum. Page generated in 0.03734 seconds
