Home » Modeling » OCL » Availability of MDT OCL 1.3M7
Re: Availability of MDT OCL 1.3M7 [message #70700 is a reply to message #70686] |
Mon, 11 May 2009 21:05 |
--=-+Xw/TVHcLiVmCjP3z2f3
Content-Type: text/plain
Hi, Philipp,
AFAIK, there will be no OCL 1.3 M7 build. Since the previous committer
team resigned (having prepared and published the M6 build), there hasn't
been any development that I know of. I don't think the new committer
team is installed, yet, though I know that Adolfo has some work that he
is waiting to commit to address the Galileo common requirement for
Capabilities. I understand from the Modeling PMC that the new team will
be activated, soon.
In the mean-time, M6 effectively is the M7 build.
HTH,
Christian
On Sun, 2009-05-10 at 17:55 +0200, Philipp Kutter wrote:
> Hi.
> Does anyone know when MDT OCL 1.3M7 will be available?
> Is it advisable to use the M6 release with all the surrounding M7
> releases, or should we wait?
> Regards,
> Philipp
Content-Type: text/html; charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.24.1.1">
</HEAD>
<BODY>
Hi, Philipp,<BR>
<BR>
AFAIK, there will be no OCL 1.3 M7 build. Since the previous committer team resigned (having prepared and published the M6 build), there hasn't been any development that I know of. I don't think the new committer team is installed, yet, though I know that Adolfo has some work that he is waiting to commit to address the Galileo common requirement for Capabilities. I understand from the Modeling PMC that the new team will be activated, soon.<BR>
<BR>
In the mean-time, M6 effectively is the M7 build.<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
Hi.
Philipp
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-+Xw/TVHcLiVmCjP3z2f3--
Re: Availability of MDT OCL 1.3M7 [message #70712 is a reply to message #70700] |
Tue, 12 May 2009 13:03 |
Philipp Kutter Messages: 306 Registered: July 2009 |
Hi, Christian.
(I repeat my question on the corresponding EMF components here for
correctness)
Would a M7 release not mean a release compiled against the M7 releases
of all used packages, and thus be completely independent of the question
whether there was something newly developed or not?
If, what I write above is correct:
As I have now an Eclipse comitter in my company (Quentin Glineur, he
started to work 1.Mai), could he checkout the sources, and compile the
M7 release for you?
Please let us know, if we can help with this.
Regards, Philipp
Christian W. Damus wrote:
> Hi, Philipp,
> be activated, soon.
> HTH,
> Christian
>> Hi.
>> Regards,
>> Philipp
Re: Availability of MDT OCL 1.3M7 [message #70743 is a reply to message #70712] |
Wed, 13 May 2009 13:09 |
--=-5qkSKmTZvE3KgO6YoCFx
Hi, Philipp,
Not having login access to Eclipse.org, there would be nothing that I
can do to help. I agree that it is best to at least compile and run
JUnits on the latest milestone (M7 in this case) of dependencies, but
since M6 was the API freeze, and the dependencies in question have very
good track records of stability, I wouldn't be concerned.
In any case, I'm confident that the PMC will have the new committer team
in place in time to produce the RC builds in the ramp-down to the
Galileo release. This component is too important to fall through the
cracks. :-)
Christian
On Tue, 2009-05-12 at 15:03 +0200, Philipp Kutter wrote:
> Hi, Christian.
> correctness)
> M7 release for you?
> Regards, Philipp
> > Hi, Philipp,
> > be activated, soon.
> > HTH,
> > Christian
> >> Hi.
> >> Regards,
> >> Philipp
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Philipp,<BR>
<BR>
Not having login access to Eclipse.org, there would be nothing that I can do to help. I agree that it is best to at least compile and run JUnits on the latest milestone (M7 in this case) of dependencies, but since M6 was the API freeze, and the dependencies in question have very good track records of stability, I wouldn't be concerned.<BR>
<BR>
In any case, I'm confident that the PMC will have the new committer team in place in time to produce the RC builds in the ramp-down to the Galileo release. This component is too important to fall through the cracks. :-)<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<PRE>
Hi, Christian.
correctness)
M7 release for you?
Regards, Philipp
> Hi, Philipp,
> be activated, soon.
> HTH,
> Christian
>> Hi.
>> Regards,
>> Philipp
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-5qkSKmTZvE3KgO6YoCFx--
Re: Availability of MDT OCL 1.3M7 [message #70843 is a reply to message #70743] |
Fri, 15 May 2009 16:53 |
Hi, Christian.
In the meantime I tried with M6, and everything seems to work fine!
> cracks. :-)
I hope so, as we are in the process of moving from an IT company to a
business modeling company, and if we need to maintain it on our own,
this would break our plans.
Alone for us, it is too important to fall through...
Lets keep in touch,
Philipp
Re: Availability of MDT OCL 1.3M7 [message #70858 is a reply to message #70843] |
Fri, 15 May 2009 18:40 |
--=-8EUp/AgLiZg9ycOreh+N
Oh, yeah. I'll still be around. ;-)
cW
On Fri, 2009-05-15 at 18:53 +0200, Philipp Kutter wrote:
-----8>-----
> Lets keep in touch,
> Philipp
<HTML>
<HEAD>
</HEAD>
<BODY>
Oh, yeah. I'll still be around. ;-)<BR>
<BR>
cW<BR>
<BR>
On Fri, 2009-05-15 at 18:53 +0200, Philipp Kutter wrote:<BR>
<BR>
-----8>-----
<PRE>
Lets keep in touch,
Philipp
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-8EUp/AgLiZg9ycOreh+N--
Re: Availability of MDT OCL 1.3M7 [message #70877 is a reply to message #70858] |
Tue, 19 May 2009 14:18 |
--------------060200090309010601040600
Hi Folks,
I might be a little behind things but ... M7 hasn't been built, RC1
probably won't be either ... and I can't for the life of me find _any_
build of the 1.3 stream on the download area.
The download page
http://www.eclipse.org/modeling/mdt/downloads/?project=ocl doesn't have
any "1.3" link, the direct link
http://download.eclipse.org/modeling/mdt/ocl/downloads/drops /1.3.0/S200903171143/mdt-ocl-SDK-1.3.0M6.zip
yields a 404, and this is empty :
http://emft.eclipse.org/modeling/mdt/ocl/downloads/drops/1.3 .0/ .
I know builds of OCl dependent component can retrieve the 1.3.0M6 just
fine (I just launched a build of Acceleo with it). Is there a way for us
to retrieve that zip from somewhere?
Laurent Goubet
Obeo
> cW
> -----8>-----
>> Lets keep in touch,
>> Philipp
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyLyI+T2JlbzwvYT4NCmVtYWls O2ludGVybmV0
OmxhdXJlbnQuZ291YmV0QG9iZW8uZnINCnVybDpodHRwOi8vd3d3Lm9iZW8u ZnINCnZlcnNp
b246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------060200090309010601040600--
Re: Availability of MDT OCL 1.3M7 [message #70916 is a reply to message #70877] |
Tue, 19 May 2009 16:51 |
--=-Wi7o9uN4kdGajqC45OEA
Content-Type: text/plain; charset="UTF-8"
Content-Transfer-Encoding: quoted-printable
Hi, Laurent,
Indeed, it appears that someone has been too eager in reclaiming server
space since I published the 1.3 M6 build. Probably, you can still find
it in the MDT milestones p2 repos (update site). However, it probably
is worth a bug report to Modeling Releng component to restore the
downloads (as I think that ZIPs are still a supported distribution
vehicle).
Your builds can still access the M6 zip because the build system caches
it locally (as it does all of the dependencies that it downloads). So,
check the /home/www-data/build/downloads/ directory or wherever it is
that the build system caches its dependencies (I have forgotten the
location). You'll find the OCL zip in there.
Christian
On Tue, 2009-05-19 at 16:18 +0200, laurent Goubet wrote:
> Hi Folks,
>=20
> I might be a little behind things but ... M7 hasn't been built, RC1=20
> probably won't be either ... and I can't for the life of me find _any_=20
>=20
> The download page=20
> http://www.eclipse.org/modeling/mdt/downloads/?project=3Docl doesn't have=
=20
> any "1.3" link, the direct link=20
> http://download.eclipse.org/modeling/mdt/ocl/downloads/drops /1.3.0/S20090=
3171143/mdt-ocl-SDK-1.3.0M6.zip=20
> yields a 404, and this is empty :=20
>=20
> I know builds of OCl dependent component can retrieve the 1.3.0M6 just=20
> fine (I just launched a build of Acceleo with it). Is there a way for us=20
>=20
> Laurent Goubet
> Obeo
>=20
> Christian W. Damus a =C3=A9crit :
> >=20
> > cW
> >=20
> >=20
> > -----8>-----
> >> Lets keep in touch,
> >> Philipp
>=20
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Laurent,<BR>
<BR>
Indeed, it appears that someone has been too eager in reclaiming server space since I published the 1.3 M6 build. Probably, you can still find it in the MDT milestones p2 repos (update site). However, it probably is worth a bug report to Modeling Releng component to restore the downloads (as I think that ZIPs are still a supported distribution vehicle).<BR>
<BR>
Your builds can still access the M6 zip because the build system caches it locally (as it does all of the dependencies that it downloads). So, check the /home/www-data/build/downloads/ directory or wherever it is that the build system caches its dependencies (I have forgotten the location). You'll find the OCL zip in there.<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
Hi Folks,
The download page
<A HREF="http://www.eclipse.org/modeling/mdt/downloads/?project=ocl">http://www.eclipse.org/modeling/mdt/downloads/?project=ocl</A> doesn't have
<A HREF=" http://download.eclipse.org/modeling/mdt/ocl/downloads/drops /1.3.0/S200903171143/mdt-ocl-SDK-1.3.0M6.zip"> http://download.eclipse.org/modeling/mdt/ocl/downloads/drops /1.3.0/S200903171143/mdt-ocl-SDK-1.3.0M6.zip</A>
<A HREF=" http://emft.eclipse.org/modeling/mdt/ocl/downloads/drops/1.3 .0/"> http://emft.eclipse.org/modeling/mdt/ocl/downloads/drops/1.3 .0/</A> .
Laurent Goubet
Obeo
> cW
> -----8>-----
>> Lets keep in touch,
>> Philipp
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-Wi7o9uN4kdGajqC45OEA--
Re: Availability of MDT OCL 1.3M7 [message #70955 is a reply to message #70942] |
Tue, 19 May 2009 20:28 |
--------------040405000407080601030203
Hi Anthony,
Thanks for the bug report, I didn't take enough time myself to raise it
as I was in quite a rush and wanted to confirm things beforehand :). I
won't have any way to access the builds until monday though ... I'll try
and catch up with what's been done for RC1 when I return.
Laurent Goubet
Obeo
Anthony Hunter a
Current Time: Fri Apr 26 23:03:00 GMT 2024
Powered by FUDForum. Page generated in 0.04014 seconds
