java.lang.NoClassDefFoundError: com/mercury/javashared/agentloader/AgentBootstrap [message #695399] |
Mon, 11 July 2011 16:43 |
ash_zah Messages: 1 Registered: July 2011 |
i seem to have a problem opening eclipse.exe, each time i try i get a pop-up message telling me to view the log file, which returns the following:
!SESSION 2011-07-11 15:44:30.045 -----------------------------------------------
eclipse.buildId=I20110613-1736
java.version=1.6.0_24
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.osgi 4 0 2011-07-11 15:44:33.451
!MESSAGE Application error
!STACK 1
at org.eclipse.swt.widgets.Display.<init>(Display.java:480)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.java:711)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:161)
at org.eclipse.ui.internal.ide.application.IDEApplication.createDisplay(IDEApplication.java:153)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:95)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: java.lang.ClassNotFoundException: com.mercury.javashared.agentloader.AgentBootstrap
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
...[/size] 17 more
Did a google on this, and it has something to do with the java environment variables: see: //stackoverflow.com/questions/1042824/not-able-to-run-eclipse-application-cant-even-start-eclipse-ide
From my understanding, it has to do with the HP automation tool I have installed on my machine, so following the above thread, I removed the jar file, eclipse opens BUT not cleanly and when attempting to create a new java project, the application is throwing back errors to do with the path and it only generates the sub folder 'src' and not the '.settings' and 'bin' sub-folders.
i have the latest java jre and jdk files installed on my machine.
Is there a way around this without having to uninstall HP QTP please?
thank you.
FUDForum. Page generated in 0.03091 seconds
