Re: BIRT Engine Runtime Error [message #694463 is a reply to message #694450] |
Fri, 08 July 2011 16:34 |
Does the war file just contain the 2.1 viewer? I know with earlier
versions of BIRT there were some issues with Tomcat 6.
http://www.eclipse.org/forums/index.php?t=msg&th=169114&start=0&
Jason
On 7/8/2011 12:06 PM, forums-noreply@eclipse.org wrote:
> Viewer Version : 2.1.0
> Engine Version: 2.1.0
> I have been running the above runtime wihtout any issue. Sent the war
> file to another user whom is running Tomcat 6.0.26. WHen thye try to run
> a report with report viewer teh follwing error occurs:
> org.eclipse.birt.report.service.ReportEngineService.setEngineContext(Unknown
> Source)
> org.eclipse.birt.report.service.BirtViewerReportService.setContect(Unknown
> Source)
> org.eclipse.birt.report.service.ViewerServlet.__getContect(Unknown Source)
> org.eclipse.birt.report.service.BirtSoapMessageDispatcherServlet.doGet(Unknown
> Source)
> javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
> org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
> javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
> Can anyone point me in the right direction on how to solve this issue.
> Thanks
Re: BIRT Engine Runtime Error [message #694525 is a reply to message #694503] |
Fri, 08 July 2011 18:58 |
Make sure that the initial war contains nothing in that directory except
config.ini.
Jason
On 7/8/2011 1:59 PM, forums-noreply@eclipse.org wrote:
> Yes, on my system that is working.
> Folders org.eclipse.core.runtime
> org.eclispe.osgi
> org.eclipse.update
> As for the installation that is not working, I am not sure and will have
> to check, but thye used the same birt.war file I used.
> Are you thinking it may be missing these folders?
FUDForum. Page generated in 0.03779 seconds
