Home » Archived » BIRT » BIRT Engine Runtime Error(Tomcat 6)
BIRT Engine Runtime Error [message #694450] Fri, 08 July 2011 12:06 Go to next message
Viewer Version : 2.1.0
Engine Version: 2.1.0
I have been running the above runtime wihtout any issue. Sent the war file to another user whom is running Tomcat 6.0.26. WHen thye try to run a report with report viewer teh follwing error occurs:
org.eclipse.birt.report.service.ReportEngineService.setEngineContext(Unknown Source)
org.eclipse.birt.report.service.BirtViewerReportService.setContect(Unknown Source)
org.eclipse.birt.report.service.ViewerServlet.__getContect(Unknown Source)
org.eclipse.birt.report.service.BirtSoapMessageDispatcherServlet.doGet(Unknown Source)
javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
Can anyone point me in the right direction on how to solve this issue.
Re: BIRT Engine Runtime Error [message #694463 is a reply to message #694450] Fri, 08 July 2011 12:34 Go to previous messageGo to next message
Does the war file just contain the 2.1 viewer? I know with earlier
versions of BIRT there were some issues with Tomcat 6.
http://www.eclipse.org/forums/index.php?t=msg&th=169114&start=0&
Jason
> java.lang.NullPointerException
> Source)
> Source)
> Source)
> Thanks
Re: BIRT Engine Runtime Error [message #694488 is a reply to message #694463] Fri, 08 July 2011 13:35 Go to previous messageGo to next message
Thanks. I tried that and did not help. Plus I am not getting a http 404 error. The server is finding the report. It's just failing for some reason.
Re: BIRT Engine Runtime Error [message #694490 is a reply to message #694488] Fri, 08 July 2011 13:43 Go to previous messageGo to next message
Does the war contain anything other than config.ini in the
web-inf/platform/configuration directory?
Jason
Re: BIRT Engine Runtime Error [message #694503 is a reply to message #694490] Fri, 08 July 2011 13:59 Go to previous messageGo to next message
Yes, on my system that is working.
Folders
org.eclipse.core.runtime
org.eclispe.osgi
org.eclipse.update
As for the installation that is not working, I am not sure and will have to check, but thye used the same birt.war file I used.
Are you thinking it may be missing these folders?
Re: BIRT Engine Runtime Error [message #694525 is a reply to message #694503] Fri, 08 July 2011 14:58 Go to previous message
Make sure that the initial war contains nothing in that directory except
config.ini.
Jason
> Folders org.eclipse.core.runtime
> org.eclispe.osgi
> org.eclipse.update
Previous Topic:secondary Y-axis on the right
Next Topic:Accumulations in CrossTabs 2
Current Time: Tue Aug 19 17:14:33 EDT 2025
Powered by FUDForum. Page generated in 0.04254 seconds
