Re: Eclipse RCP doesn't load bundles with same symbolic name, but different versions [message #1038961 is a reply to message #698071] |
Thu, 11 April 2013 14:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
xyz Mising name![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=dislocated781%40yahoo.com) Messages: 2 Registered: July 2011 |
Sorry for answering so late.
In target platform I have two plugins: org.dep_1.0.1.jar and org.dep_2.0.0.jar (nothing fancy, no code beside Activator - basically the simple plugin project). Both jars have same symbolic name, the only difference is version number. They aren't singletons. Everything is done with Eclipse RCP 3.7.2.
I also created small test application with two workspace plugins:
org.test.main1 (only Activator) - depends on org.dep_2.0.0.jar
org.test.main (Sample RCP application with branding) - depends on org.dep_1.0.1.jar and org.test.main1 (which in turn depends on org.dep_2.0.0)
Now, there are two situations (OSGI console is active in both cases, and -noExit parameter is set):
1) Launch org.test.main RCP as an Eclipse application. Launching fails and "ss org.dep" in console says something like this
Framework is launched.
id State Bundle
8 <<LAZY>> org.dep_2.0.0
Sometimes org.dep_1.0.1 is loaded, but never both at the same time. If I try to install it later using OSGi console, it can be installed.
2) Create new OSGi Framework configuration, add required plugins and start it. Application doesn't start, but "ss org.dep" in console returns
id State Bundle
10 ACTIVE org.dep_1.0.1
22 ACTIVE org.dep_2.0.0
So both bundles are seen by OSGi.
I'm curious to find what is causing this, because I'd like to move from Eclipse 3.4.2 (where this doesn't happen), and I don't know if renaming bundles is the only way to go.
Also, setting resolver/wiring as tracing options doesn't say much about why it didn't recognize the second jar.
JB
FUDForum. Page generated in 0.03628 seconds
