Home » Modeling » OCL » Validating superclass constraints in OCL
Validating superclass constraints in OCL [message #694240] Fri, 08 July 2011 03:32 Go to next message
I created an OCL document containing invariants against a certain metamodel. The meta model contains a class Foo and a class Bar which is derived from Foo. (So Bar inherits from Foo.)
When I create a model (according to the meta model) and I let the CompleteOCLEObjectValidator perform the validations, it turns out that given a constraint for Foo, any object of type Bar is not validated.
To make it specific.
The metamodel:
package zoo : zoo = 'http://zoo.walb.com'
	class Foo
		attribute name : String[?] { ordered };
	class Bar extends Foo
		attribute id : String[?] { ordered };
The ocl document:
import 'http://zoo.walb.com'
package zoo
context Foo
inv AlwaysFalseFoo: false
endpackage
I would expect that when I validate a model containing a Bar object, that the validator would indicate that the AlwaysFalseFoo constraint is not fulfilled.
Am I misunderstanding the OCL specification or did I trigger a bug in the tool?
Greetings,
Wilbert.
Re: Validating superclass constraints in OCL [message #694417 is a reply to message #694240] Fri, 08 July 2011 10:30 Go to previous message
Hi Wilbert
Yeah. A pretty simple one too:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=351578: should be fixed in
SR1. Thanks for the repro.
Ed Willink
Previous Topic:Unable to perform OCL validation outside eclipse
Next Topic:OCL Interactive Query fails for large file
Current Time: Mon Jun 16 19:29:42 EDT 2025
Powered by FUDForum. Page generated in 0.03892 seconds
